Updated on 2026-08-14 GMT+08:00
Obtaining Lifecycle Rules (SDK for Java)
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API returns the lifecycle rules of a bucket.
Restrictions
Method
obsClient.getBucketLifecycle(final BaseBucketRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
BaseBucketRequest
Yes
Explanation:
Request parameter for obtaining lifecycle rules. For details, see Table 2.
Table 2 BaseBucketRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
Table 3 GetBucketLifecycleRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
Default value:
None
Responses
Table 4 LifecycleConfiguration
Type
rules
List<Rule>
Explanation:
List of lifecycle rules. For details, see Table 5.
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Table 5 Rule
Type
Mandatory (Yes/No)
id
String
No
Explanation:
Lifecycle rule ID.
Value range:
The value must contain 1 to 255 characters.
Default value:
None
prefix
String
Yes
Explanation:
Object name prefix. It identifies the objects the rule applies to. You can leave this parameter blank to apply the rule to all objects in the bucket.
Assume that you have the following objects: logs/day1, logs/day2, logs/day3, and ExampleObject.jpg. If you set prefix to ExampleObject.jpg, the rule applies to object ExampleObject.jpg only. If you set prefix to logs/, the rule applies to the three objects with name starting with logs/. If you leave prefix blank, the rule applies to all objects in the bucket.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
enabled
boolean
Yes
Explanation:
Whether the rule is enabled.
Value range:
true: The rule is enabled.
false: The rule is disabled.
Default value:
None
expiration
Expiration
No
Explanation:
Expiration time of an object. For details, see Table 7.
Default value:
None
tagSet
TagSet
No
Explanation:
Object tags that identify the objects the rule applies to. For details, see Table 8.
Default value:
None
noncurrentVersionExpiration
NoncurrentVersionExpiration
No
Explanation:
Expiration time of noncurrent object versions. For details, see Table 9.
Restrictions:
  • This parameter is only available for noncurrent object versions.
  • Versioning must be enabled (or suspended after being enabled) for the bucket.
Default value:
None
transitions
List<Transition>
No
Explanation:
Policies for storage class transition, including transition time and the storage class after transition. For details, see Table 10.
Restrictions:
This parameter is only available for the current object version.
Default value:
None
noncurrentVersionTransitions
List<NoncurrentVersionTransition>
No
Explanation:
Policies for storage class transition of noncurrent versions, including transition time and the storage class after transition. For details, see Table 12.
Restrictions:
Default value:
None
Table 6 Tag
Type
Mandatory (Yes/No)
key
String
Yes
Explanation:
Name of a tag.
Restrictions:
  • This parameter must not be left blank or contain unprintable ASCII characters (0–31) or the following special characters: *<>\=
  • The tag keys in the same bucket must be unique.
  • The value can be up to 36 characters long.
Default value:
None
value
String
Yes
Explanation:
Tag value.
Restrictions:
  • This parameter can be left blank, but if specified, cannot include unprintable ASCII characters (0–31) and the following special characters: *<>\=
  • The value can be up to 43 characters long.
Default value:
None
Table 7 Expiration
Type
Mandatory (Yes/No)
days
Integer
Yes if date is absent during object storage class transition
Yes if date or expiredObjectDeleteMarker is absent during object deletion
Explanation:
Number of days (since the last update was made to the object) after which the lifecycle rule takes effect (the object will be deleted).
Restrictions:
Value range:
A positive integer, in days.
Default value:
None
date
Date
Yes if days is absent during object storage class transition.
Yes if days or expiredObjectDeleteMarker is absent during object deletion
Explanation:
The value must conform to the ISO8601 standards and indicate UTC 00:00. For example, 2018-01-01T00:00:00.000Z indicates only objects that were last modified before the specified time are transitioned to the specified storage class or deleted.
Default value:
None
Boolean
Yes if days or date is absent
Explanation:
Whether to delete expired delete markers. The value can be true or false. If tags are configured in a lifecycle rule, this element cannot be configured.
Default value:
None
Table 8 TagSet
Type
Mandatory (Yes/No)
tags
List<Tag>
Yes
Explanation:
Object tag list. For details, see Table 6.
Table 9 NoncurrentVersionExpiration
Type
Mandatory (Yes/No)
days
Integer
Yes
Explanation:
Number of days an object is noncurrent before it expires.
Restrictions:
Value range:
Default value:
None
Table 10 Transition
Type
Mandatory (Yes/No)
days
Integer
This parameter is mandatory if date is not configured.
Explanation:
Number of days after its creation when the object is transitioned.
Restrictions:
Value range:
Default value:
None
date
Date
This parameter is mandatory if days is not configured.
Explanation:
Date when the object will be transitioned.
Default value:
None
storageClass
StorageClassEnum
Yes
Explanation:
Storage class the object is transitioned to.
Restrictions:
Restrictions on storage class transitions:
  • Only transitions from the Standard storage class to the Infrequent Access storage class are supported. To transition objects from Infrequent Access to Standard, you must manually do it.
  • Only transitions from the Standard or Infrequent Access storage class to the Archive storage class are supported. To transition objects from Archive to Standard or Infrequent Access, you must first restore these objects and then manually change their storage classes.
  • Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
Value range:
See Table 11.
Default value:
None
Table 11 StorageClassEnum
Constant
Default Value
STANDARD
STANDARD
Standard storage class.
WARM
WARM
Infrequent Access storage class.
COLD
COLD
Archive storage class.
Table 12 NoncurrentVersionTransition
Type
Mandatory (Yes/No)
days
Integer
Explanation:
Restrictions:
Value range:
Default value:
None
storageClass
StorageClassEnum
Yes
Explanation:
Restrictions:
Value range:
See Table 11.
Default value:
None
Code Examples
This example returns the lifecycle configuration of bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.LifecycleConfiguration;
public class GetBucketLifecycle001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use a permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        // Use a temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // View the lifecycle rules
            LifecycleConfiguration config = obsClient.getBucketLifecycle("examplebucket");
            System.out.println("getBucketLifecycle successfully");
            for (LifecycleConfiguration.Rule rule : config.getRules()) {
                System.out.println(rule.getId());
                System.out.println(rule.getPrefix());
                for (LifecycleConfiguration.Transition transition : rule.getTransitions()) {
                    System.out.println(transition.getDays());
                    System.out.println(transition.getStorageClass());
                System.out.println(rule.getExpiration() != null ? rule.getExpiration().getDays() : "");
                for (LifecycleConfiguration.NoncurrentVersionTransition noncurrentVersionTransition :
                        rule.getNoncurrentVersionTransitions()) {
                    System.out.println(noncurrentVersionTransition.getDays());
                    System.out.println(noncurrentVersionTransition.getStorageClass());
                System.out.println(
                        rule.getNoncurrentVersionExpiration() != null
                                ? rule.getNoncurrentVersionExpiration().getDays()
        } catch (ObsException e) {
            System.out.println("getBucketLifecycle failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
