Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
Help Center/ Object Storage Service/ SDK Reference/ Java/ Versioning (SDK for Java)/ Configuring Versioning for a Bucket (SDK for Java)
Updated on 2024-12-11 GMT+08:00
Function
You can enable versioning to automatically maintain previous versions of an object. When versioning is enabled, you can access earlier versions of an object to recover your data in the event of accidental actions or application failures. For more information, see Versioning.
This API configures the versioning status for a bucket.
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.setBucketVersioning(final SetBucketVersioningRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
Yes
Explanation:
Request parameters for bucket versioning configuration. For details, see Table 2.
Table 2 SetBucketVersioningRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
status
VersioningStatusEnum
Yes
Explanation:
Versioning status of the bucket.
Value range:
See Table 3.
Table 3 VersioningStatusEnum
Constant
Default Value
SUSPENDED
Suspended
Versioning is suspended.
ENABLED
Enabled
Versioning is enabled.
Responses
Table 4 Common response headers
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Code Examples
This example enables and suspends versioning of bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.BucketVersioningConfiguration;
import com.obs.services.model.VersioningStatusEnum;
public class SetBucketVersioning001 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // Enable versioning.
                    "examplebucket", new BucketVersioningConfiguration(VersioningStatusEnum.ENABLED));
            // Suspend versioning.
                    "examplebucket", new BucketVersioningConfiguration(VersioningStatusEnum.SUSPENDED));
            System.out.println("setBucketVersioning successfully");
        } catch (ObsException e) {
            System.out.println("setBucketVersioning failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
