Obtaining an Object ACL (SDK for Java)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. If an object is encrypted with SSE-KMS, the ACL configured for it is not in effect in the cross-tenant case.
For more information, see ACLs.
This API obtains the ACL of an object in a specified bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To obtain an object ACL, you must be the bucket owner or have the required permission (obs:object:GetObjectAcl in IAM or GetObjectAcl in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getObjectAcl(GetObjectAclRequestrequest)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
request | GetObjectAclRequest | Yes | Explanation: Request parameters for obtaining an object ACL. For details, see Table 2. |
bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
versionId | String | No | Explanation: Object version ID. Value range: The value must contain 32 characters. Default value: None |
Responses
Parameter | Type | Description |
statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
owner | Explanation: Object owner. For details, see Table 8. | |
grants | Set<GrantAndPermission> | Explanation: Grantee information. For details, see Table 4. |
delivered | boolean | Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
grantee | Yes | Explanation: Grantees (users or user groups). For details, see Table 5. | |
permission | Yes | Explanation: Permissions to grant. Value range: See Table 9. Default value: None | |
delivered | boolean | No | Explanation: Whether the bucket ACL is applied to all objects in the bucket. Value range: true: The bucket ACL is applied to all objects in the bucket. false: The bucket ACL is not applied to any objects in the bucket. Default value: false |
Yes | Explanation: Grantee (user) information. For details, see Table 6. | ||
Yes | Explanation: Grantee (user group) information. Value range: See Table 7. Default value: None |
grantId | String | Yes if Type is set to GranteeUser | Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName | String | No | Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Constant | Description |
ALL_USERS | All users. |
AUTHENTICATED_USERS | Authorized users. This constant is deprecated. |
LOG_DELIVERY | Log delivery group. This constant is deprecated. |
id | String | Yes | Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
displayName | String | No | Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
Constant | Default Value | Description |
PERMISSION_READ | READ | Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
PERMISSION_WRITE | WRITE | Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
PERMISSION_READ_ACP | READ_ACP | Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
PERMISSION_WRITE_ACP | WRITE_ACP | Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
PERMISSION_FULL_CONTROL | FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
Code Examples
This example returns the ACL information of object objectname in bucket examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.AccessControlList; public class GetObjectAcl001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Obtain the object ACL. AccessControlList acl = obsClient.getObjectAcl("examplebucket", "objectname"); System.out.println("getObjectAcl successfully"); System.out.println(acl); } catch (ObsException e) { System.out.println("getObjectAcl failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("getObjectAcl failed"); // Print other error information. e.printStackTrace(); } } } |
