Updated on 2026-08-14 GMT+08:00
Configuring an Object ACL (SDK for Java)
Function
Access control lists (ACLs) allow resource owners to grant other accounts the permissions to access resources. By default, only the resource owner has full control over resources when a bucket or object is created. That is, the bucket creator has full control over the bucket, and the object uploader has full control over the object. Other accounts do not have the permissions to access resources. If resource owners want to grant other accounts the read and write permissions on resources, they can use ACLs. ACLs grant permissions to accounts. After an account is granted permissions, both the account and its IAM users can access the resources. If an object is encrypted with SSE-KMS, the ACL configured for it is not in effect in the cross-tenant case.
For more information, see ACLs.
If you have any questions during development, post them on the Issues page of GitHub.
An object ACL can be configured in any of the following ways:
  1. Code Example: Setting a Pre-defined ACL When Uploading the Object
  2. Code Example: Setting a Pre-defined ACL for the Object
  3. Code Example: Setting an ACL for the Object Directly
Restrictions
Method
obsClient.setObjectAcl(SetObjectAclRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
SetObjectAclRequest
Yes
Explanation:
Request parameters for setting an object ACL. For details, see Table 2.
Table 2 SetObjectAclRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
String
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
versionId
String
No
Explanation:
Object version ID.
Value range:
The value must contain 32 characters.
Default value:
None
acl
AccessControlList
Yes
Explanation:
An ACL specified for the object. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs.
Value range:
  • To use a pre-defined ACL, see Table 3 for the available options.
  • To use a user-defined ACL, see Table 4 to configure the required parameters.
Default value:
AccessControlList.REST_CANNED_PRIVATE
Table 3 Pre-defined ACL
Constant
Private read/write.
A bucket or object can only be accessed by its owner.
AccessControlList.REST_CANNED_PUBLIC_READ
Public read.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket.
If this permission is granted on an object, anyone can read the content and metadata of the object.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE
Public read/write.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks.
AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED
Public read on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket.
This permission cannot be granted on objects.
AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED
Public read/write on a bucket as well as objects in the bucket.
If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket.
AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL
If this permission is granted on an object, only the bucket and object owners have the full control over the object.
By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object.
For example, if user A uploads object x to user B's bucket, user B does not have control over object x. If user A sets bucket-owner-full-control for object x, user B then has control over object x.
Table 4 AccessControlList
Type
Mandatory (Yes/No)
owner
Owner
Yes
Explanation:
Bucket owner information. For details, see Table 5.
delivered
boolean
No
Explanation:
Whether the bucket ACL is applied to all objects in the bucket.
Value range:
true: The bucket ACL is applied to all objects in the bucket.
false: The bucket ACL is not applied to any objects in the bucket.
Default value:
false
grants
Set<GrantAndPermission>
No
Explanation:
Grantee information. For details, see Table 6.
Table 5 Owner
Type
Mandatory (Yes/No)
id
String
Yes
Explanation:
Account (domain) ID of the bucket owner.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
displayName
String
No
Explanation:
Account name of the owner.
Value range:
To obtain the account name, see How Do I Get My Account ID and User ID?
Default value:
None
Table 6 GrantAndPermission
Type
Mandatory (Yes/No)
grantee
CanonicalGrantee or GroupGrantee
Yes
Explanation:
Grantees (users or user groups).
Value range:
Grantee (user) information. For details, see Table 7.
Grantee (user group) information. For details, see Table 8.
permission
Permission
Yes
Explanation:
Permissions to grant.
Value range:
See Table 9.
Default value:
None
delivered
boolean
No
Explanation:
Value range:
Default value:
false
Table 7 CanonicalGrantee
Type
Mandatory (Yes/No)
grantId
String
Yes if Type is set to GranteeUser
Explanation:
Account (domain) ID of the grantee.
Value range:
Default value:
None
displayName
String
No
Explanation:
Account name of the grantee.
Value range:
Default value:
None
Table 8 GroupGrantee
Constant
ALL_USERS
All users.
AUTHENTICATED_USERS
Authorized users. This constant is deprecated.
LOG_DELIVERY
Log delivery group. This constant is deprecated.
Table 9 Permission
Constant
Default Value
PERMISSION_READ
READ
Read permission.
A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket.
A grantee with this permission for an object can obtain the object content and metadata.
PERMISSION_WRITE
WRITE
Write permission.
A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket.
This permission is not available for objects.
PERMISSION_READ_ACP
READ_ACP
Permission to read an ACL.
A grantee with this permission can obtain the ACL of a bucket or object.
A bucket or object owner has this permission for their bucket or object by default.
PERMISSION_WRITE_ACP
WRITE_ACP
Permission to modify an ACL.
A grantee with this permission can update the ACL of a bucket or object.
This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object.
PERMISSION_FULL_CONTROL
FULL_CONTROL
Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL.
A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket.
A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object.
Responses
Table 10 Common response headers
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
This example uploads localfile to bucket examplebucket as object objectname, and specifies a pre-defined ACL during the upload.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.AccessControlList;
import com.obs.services.model.PutObjectRequest;
import java.io.File;
public class PutObject012 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use a permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        // Use a temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // Specify a pre-defined ACL during object upload.
            PutObjectRequest request = new PutObjectRequest();
            request.setBucketName("examplebucket");
            request.setObjectKey("objectname");
            request.setFile(new File("localfile"));
            // Set the object ACL to private read and write.
            request.setAcl(AccessControlList.REST_CANNED_PRIVATE);
            obsClient.putObject(request);
            System.out.println("putObject successfully");
        } catch (ObsException e) {
            System.out.println("putObject failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
This example specifies a pre-defined ACL of private read and write for object objectname in examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
public class SetObjectAcl001 {
        try {
            // Set a predefined ACL for the object.
            obsClient.setObjectAcl("examplebucket", "objectname", AccessControlList.REST_CANNED_PRIVATE);
            System.out.println("setObjectAcl successfully");
            System.out.println("setObjectAcl failed");
This example configures an ACL for object objectname in bucket examplebucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
import com.obs.services.model.CanonicalGrantee;
import com.obs.services.model.GroupGrantee;
import com.obs.services.model.Owner;
import com.obs.services.model.Permission;
public class SetObjectAcl002 {
        try {
            AccessControlList acl = new AccessControlList();
            Owner owner = new Owner();
            owner.setId("ownerid");
            // (Mandatory) Owner ID
            acl.setOwner(owner);
            //Retain the owner's full control permissions. (Note that if this permission is not set, the owner does not have the access permission.)
            acl.grantPermission(new CanonicalGrantee("ownerid"), Permission.PERMISSION_FULL_CONTROL);
            // Grant the full control permission to a specified user.
            acl.grantPermission(new CanonicalGrantee("userid"), Permission.PERMISSION_FULL_CONTROL);
            // Grant the read permission to all users.
            acl.grantPermission(GroupGrantee.ALL_USERS, Permission.PERMISSION_READ);
            obsClient.setObjectAcl("examplebucket", "objectname", acl);
            System.out.println(acl);
