Downloading an Object - Resumable (SDK for Java)
Function
- Downloading large files often fails due to an unstable network or program breakdown. It is a waste of resources to download files again. Moreover, the restarted download may still fail due to an unstable network. To resolve such issues, the resumable download API splits the file to be downloaded into multiple parts and downloads them separately. The download result of each part is recorded in a checkpoint file in real time. Only when all parts are downloaded is a message indicating the download is successful returned. If any parts fail to be downloaded, a message is returned telling you to call the API again to download the failed parts. Since the checkpoint file contains the progress of all parts, it helps you avoid downloading all parts in re-downloads, so that you can enjoy a cost-effective, efficient download.
- The resumable download API is an encapsulated and enhanced version of the API for partial download. For details about the partial download, see Downloading an Object - Range-Based (SDK for Java).
- This API saves resources and improves efficiency upon the re-download, and speeds up the download process by concurrently downloading parts. You do not need to worry about internal service details, such as the creation and deletion of checkpoint files, division of objects, or concurrent downloads of parts.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To download an object, you must be the bucket owner or have the required permission (obs:object:GetObject in IAM or GetObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.downloadFile(DownloadFileRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for downloading a large object. For details, see Table 2. |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
| downloadFile | String | No | Explanation: Full path of the local directory to which the object is downloaded. Default value: If the value of this parameter is left blank, the downloaded object is saved in the directory where the program is executed. |
| partSize | long | No | Explanation: Part size. Value range: The value ranges from 100 KB to 5 GB, in bytes. Default value: 9 MB |
| taskNum | int | No | Explanation: Maximum number of parts that can be downloaded concurrently in a multipart download Value range: The value must be greater than 0, but not exceed the file size divided by the part size, rounded up. Default value: 1, indicating concurrent downloads are not used. |
| enableCheckpoint | boolean | No | Explanation: Whether to enable the resumable mode. Value range: true: The resumable mode is enabled. false: The resumable mode is disabled. Default value: false |
| checkpointFile | String | No | Explanation: Path of a file generated for recording the progress of a resumable download. The file contains the information about parts and progress. Restrictions: This parameter is valid only in the resumable mode. Default value: If this parameter is left blank, the checkpoint file will be saved in the current directory. |
| enableCheckSum | boolean | No | Explanation: Whether to verify the file to download. If this function is enabled, before each task restarts, the system verifies whether the file to download is the one used during task initialization. Restrictions: This parameter is valid only in the resumable mode. Value range: true: The file is verified. false: The file is not verified. Default value: false |
| versionId | String | No | Explanation: Object version ID, for example, G001117FCE89978B0000401205D5DC9. Value range: The value must contain 32 characters. Default value: None. If this parameter is left blank, the latest version of the object is obtained. |
| encodeHeaders | boolean | No | Explanation: Whether to automatically decode the response headers. Default value: None |
| needCalculateCRC64 | boolean | No | Explanation: Whether to automatically calculate and verify the CRC64 value of the downloaded data. Restrictions: This parameter is not supported for POSIX or SFS objects. Value range: true: The SDK calculates and verifies CRC64. false: CRC64 is not calculated. Default value: false |
| ifModifiedSince | Date | No | Explanation: Returns the object if it has been modified since the specified time; otherwise, an error is returned. Default value: None |
| ifUnmodifiedSince | Date | No | Explanation: Returns the object if it has not been modified since the specified time; otherwise, an error is returned. Default value: None |
| ifMatchTag | String | No | Explanation: Returns the object content if the object's ETag is the same as the value of this parameter. Otherwise, an error is reported. Default value: None |
| ifNoneMatchTag | String | No | Explanation: Returns the object content if the object's ETag is different from the value of this parameter. Otherwise, an error is reported. Default value: None |
| progressListener | No | Explanation: Data transmission listener for obtaining the download progress. For details, see Table 3. | |
| encodeHeaders | boolean | No | Explanation: Whether to enable OBS to automatically encode request headers. Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data. Value range: true: Encoding with SDK is enabled. false: Encoding with SDK is disabled. Default value: true |
| Method | Return Value Type | Mandatory (Yes/No) | Description |
| void | Yes | Explanation: Used for obtaining the progress. For details, see Table 4. Default value: None |
| status | Yes | Explanation: Progress data. For details, see Table 5. Default value: None |
| Method | Return Value Type | Description |
| getAverageSpeed() | double | Average transmission rate. |
| getInstantaneousSpeed() | double | Instantaneous transmission rate. |
| getTransferPercentage() | int | Transmission progress, in percentage. |
| getNewlyTransferredBytes() | long | Number of the newly transmitted bytes. |
| getTransferredBytes() | long | Number of bytes that have been transmitted. |
| getTotalBytes() | long | Number of the bytes to be transmitted. |
| Constant | Default Value | Description |
| STANDARD | STANDARD | Standard storage class |
| WARM | WARM | Infrequent Access storage class. |
| COLD | COLD | Archive storage class. |
| contentLength | Long | No | Explanation: Object size. Default value: If this parameter is not specified, the SDK automatically calculates the size of the object. |
| contentType | String | No | Explanation: MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Value range: See What Is Content-Type (MIME)? (Java SDK) Default value: If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file. |
| contentEncoding | String | No | Explanation: Content-Encoding header in the response. It specifies which encoding is applied to the object. Default value: None |
| contentDisposition | String | No | Explanation: Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box. Default value: None |
| cacheControl | String | No | Explanation: Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded. Default value: None |
| contentLanguage | String | No | Explanation: Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol. Default value: None |
| expires | String | No | Explanation: The time a cached web page object expires. Restrictions: The time must be in the GMT format. Default value: None |
| contentMd5 | String | No | Explanation: Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the object data. If the two values are not the same, HTTP status code 400 is returned. Restrictions:
Value range: Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864. Example: n58IG6hfM7vqI4K0vnWpog== Default value: None |
| storageClass | No | Explanation: Storage class of an object that can be specified at object creation. If this header is not set, the default storage class of the bucket is used as the storage class of the object. Value range: See Table 6. Default value: None | |
| webSiteRedirectLocation | String | No | Explanation: If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to. The request is redirected to an object anotherPage.html in the same bucket: WebsiteRedirectLocation:/anotherPage.html The request is redirected to an external URL http://www.example.com/: WebsiteRedirectLocation:http://www.example.com/ Restrictions:
| nextPosition | long | No | Explanation: Start position for the next append upload. Value range: 0 to the object length, in bytes. Default value: None |
| appendable | boolean | No | Explanation: Whether the object is appendable. Value range: true: The object is appendable. false: The object is not appendable. Default value: None |
| userMetadata | Map<String, Object> | No | Explanation: User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java). Restrictions:
Responses
| Parameter | Type | Description |
| objectMetadata | Explanation: Object metadata. For details, see Table 7. |
Code Examples
This example downloads object objectname from bucket examplebucket to localfile using the resumable download.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.DownloadFileRequest; import com.obs.services.model.DownloadFileResult; public class DownloadFile001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { DownloadFileRequest request = new DownloadFileRequest("examplebucket", "objectname"); // Set the local path the object will be downloaded to. request.setDownloadFile("localfile"); // Set the maximum number of parts that can be concurrently downloaded. request.setTaskNum(5); // Set the part size to 10 MB. request.setPartSize(10 * 1024 * 1024); // Enable the resumable upload. request.setEnableCheckpoint(true); // Perform a resumable download. DownloadFileResult result = obsClient.downloadFile(request); System.out.println("downloadFile successfully"); System.out.println("Etag:" + result.getObjectMetadata().getEtag()); } catch (ObsException e) { System.out.println("downloadFile failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("downloadFile failed"); // Print other error information. e.printStackTrace(); } } } |
