Restoring an Archive Object (SDK for Java)
Function
Archive objects must first be restored before you can download them. Archive objects can be restored in either of the following ways.
Option | Description | Value in OBS Java SDK |
Expedited | Data can be restored within 1 to 5 minutes. | RestoreTierEnum.EXPEDITED |
Standard | Data can be restored within 3 to 5 hours. This is the default option. | RestoreTierEnum.STANDARD |
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To restore an Archive object, you must be the bucket owner or have the required permission (obs:object:RestoreObject in IAM or RestoreObject in a bucket policy.) For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- To prolong the validity period of the Archive data restored, you can repeatedly restore the data, but you will be billed for each restore. After a second restore, the validity period of Standard object copies will be prolonged, and you need to pay for storing these copies during the prolonged period.
- The object specified in ObsClient.restoreObject must be in the Archive storage class. Otherwise, an exception will be thrown when you call this API.
Method
obsClient.restoreObject(RestoreObjectRequestrequest)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
request | Yes | Explanation: Request parameters for downloading an object. For details, see Table 2. |
bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
versionId | String | No | Explanation: Version ID of the Archive object to restore. Default value: None. If this parameter is left blank, the latest version of the object is specified. |
days | int | Yes | Explanation: After an object is restored, a Standard copy of it is generated. This parameter specifies how long the Standard copy can be retained, that is, the validity period of the restored object. Restrictions: The value must be a positive integer. Value range: The value ranges from 1 to 30, in days. Default value: None |
tier | No | Explanation: The restore option, which indicates the time spent on restoring the object. Value range: For details, see Table 3. Default value: Standard |
Responses
Parameter | Type | Description |
statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders | Map<String, Object> | Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example restores object objectname from the Archive storage class using ObsClient.restoreObject and downloads it using ObsClient.getObject.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.ObsObject; import com.obs.services.model.RestoreObjectRequest; import com.obs.services.model.RestoreTierEnum; public class GetObject007 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Restore the Archive object. RestoreObjectRequest request = new RestoreObjectRequest(); request.setBucketName("examplebucket"); request.setObjectKey("objectname"); request.setDays(1); request.setRestoreTier(RestoreTierEnum.EXPEDITED); obsClient.restoreObject(request); // Wait for the object to be restored. Thread.sleep(60 * 6 * 1000); // Download the object. ObsObject obsObject = obsClient.getObject("examplebucket", "objectname"); System.out.println("getObject successfully"); obsObject.getObjectContent().close(); } catch (ObsException e) { System.out.println("getObject failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("getObject failed"); // Print other error information. e.printStackTrace(); } } } |
Helpful Links
- Obtaining Object Metadata (SDK for Java) (Note: View the restoration status of an object through the x-obs-restore response header.) and Viewing the Restoration Status of an Object
- Restoring Objects
- (GitHub) Sample Code for Restoring an Archive Object
- OBS Error Codes
