DataArts Fabric
Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
Help Center/ Object Storage Service/ SDK Reference/ Java/ Object Download (SDK for Java)/ Downloading an Object - Conditional (SDK for Java)
Updated on 2024-12-11 GMT+08:00
Function
This API returns the objects that meet one or more conditions. If there are no objects that meet the specified conditions, an error is returned.
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
Method
obsClient.getObject(GetObjectRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
GetObjectRequest
Yes
Explanation:
Request parameters for downloading an object. For details, see Table 2.
Table 2 GetObjectRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain periods (.) and hyphens (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
String
Yes
Explanation:
Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
versionId
String
No
Explanation:
Object version ID.
Value range:
The value must contain 32 characters.
Default value:
None
imageProcess
String
No
Explanation:
Image processing command or style. Example for resizing and rotating an image: image/resize,m_fixed,w_100,h_100/rotate,90
Value range:
Command format: image/commands
Style format: style/style name
For details about image processing parameters, see Processing Images.
Default value:
If no commands are entered, the original image is returned.
rangeStart
Long
No
Explanation:
Start position for object download.
Value range:
A non-negative integer.
Default value:
None
rangeEnd
Long
No
Explanation:
End position for object download.
Restrictions:
The upper limit of the value is the object length minus 1, in bytes.
Default value:
None
ifMatchTag
String
No
Explanation:
  1. The ETag of an object is the MD5 value of the object. Preset ETag. If the ETag of the object to be downloaded is the same as the preset ETag, the object is returned. Otherwise, an error is returned.
  2. If a request includes If-Unmodified-Since or If-Match and the specified condition is not met, 412 Precondition Failed will be returned.
Value range:
Default value:
None
ifNoneMatchTag
String
No
Explanation:
  1. Preset ETag. If the ETag of the object to be downloaded is different from the preset ETag, the object is returned. Otherwise, an error is returned.
  2. If a request includes If-Modified-Since or If-None-Match, and the specified condition is not met, 304 Not Modified will be returned.
Value range:
Default value:
None
IfModifiedSince
Date
No
Explanation:
  1. The object is returned if it has been modified since the specified time; otherwise, an error is returned.
Default value:
None
IfUnmodifiedSince
Date
No
Explanation:
  1. The object is returned if it has not been modified since the specified time; otherwise, an error is returned.
Default value:
None
sseCHeader
SseCHeader
No
Explanation:
Server-side decryption header. For details, see Table 7.
replaceMetadata
ObjectRepleaceMetadata
No
Explanation:
Additional information about the object. For details, see Table 3.
progressListener
ProgressListener
No
Explanation:
Data transmission listener for obtaining the progress. For details, see Table 4.
encodeHeaders
boolean
No
Explanation:
Whether to enable OBS to automatically encode request headers.
Due to HTTP coding restrictions, only ASCII characters can be sent. If your request headers contain full-width characters, the SDK will URL encode these characters before sending the request. When you use a browser to access the object metadata, the browser automatically decodes the data.
Value range:
true: Encoding with SDK is enabled.
false: Encoding with SDK is disabled.
Default value:
true
Table 3 ObjectRepleaceMetadata
Type
Mandatory (Yes/No)
contentType
String
No
Explanation:
MIME type of the object file. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Value range:
See What Is Content-Type (MIME)? (Java SDK)
Default value:
None
contentLanguage
String
No
Explanation:
Language or language combination for visitors to customize and use. For details, see the definition of ContentLanguage in the HTTP protocol.
Default value:
None
expires
String
No
Explanation:
Expires header in the response. It specifies the cache expiration time of the web page when the object is downloaded.
Default value:
None
cacheControl
String
No
Explanation:
Cache-Control header in the response. It specifies the cache behavior of the web page when an object is downloaded.
Default value:
None
contentDisposition
String
No
Explanation:
Provides a default file name for the requested object. When the object with the default file name is being downloaded or accessed, the content is displayed as part of a web page in the browser or as an attachment in a download dialog box.
Default value:
None
contentEncoding
String
No
Explanation:
Content-Encoding header in the response. It specifies which encoding is applied to the object in a download.
Default value:
None
Table 4 ProgressListener
Method
Return Value Type
Mandatory (Yes/No)
progressChanged
void
Yes
Explanation:
Used for obtaining the progress. For details, see Table 5.
Default value:
None
Table 5 progressChanged
Type
Mandatory (Yes/No)
status
ProgressStatus
Yes
Explanation:
Progress data. For details, see Table 6.
Default value:
None
Table 6 ProgressStatus
Method
Return Value Type
getAverageSpeed()
double
Average transmission rate.
getInstantaneousSpeed()
double
Instantaneous transmission rate.
getTransferPercentage()
int
Transmission progress, in percentage.
getNewlyTransferredBytes()
long
Number of the newly transmitted bytes.
getTransferredBytes()
long
Number of bytes that have been transmitted.
getTotalBytes()
long
Number of the bytes to be transmitted.
Table 7 SseCHeader
Type
Mandatory (Yes/No)
algorithm
ServerAlgorithm
Yes
Explanation:
SSE-C is used for encrypting objects on the server side.
Value range:
AES256, indicating Advanced Encryption Standard (AES) is used to encrypt the object in SSE-C. For details, see Table 9.
Default value:
None
sseAlgorithm
SSEAlgorithmEnum
No
Explanation:
Encryption algorithm.
Restrictions:
Only AES256 is supported.
Value range:
See Table 8.
Default value:
None
sseCKey
byte[]
Yes
Explanation:
Key used for encrypting the object when SSE-C is used, in byte[] format.
Default value:
None
sseCKeyBase64
String
No
Explanation:
Base64-encoded key used for encrypting the object when SSE-C is used.
Default value:
None
Table 8 SSEAlgorithmEnum
Constant
Default Value
KMS
kms
AES256
AES256
Table 9 ServerAlgorithm
Constant
Default Value
AES256
AES256
Table 10 Owner
Type
Mandatory (Yes/No)
id
String
Yes
Explanation:
Account (domain) ID of the bucket owner.
Value range:
To obtain the account ID, see How Do I Get My Account ID and User ID?
Default value:
None
displayName
String
No
Explanation:
Account name of the owner.
Value range:
To obtain the account name, see How Do I Get My Account ID and User ID?
Default value:
None
Table 11 StorageClassEnum
Constant
Default Value
STANDARD
STANDARD
Standard storage class
WARM
WARM
Infrequent Access storage class.
COLD
COLD
Archive storage class.
Table 12 ObjectMetadata
Type
Mandatory (Yes/No)
contentLength
Long
No
Explanation:
Object size.
Default value:
If this parameter is not specified, the SDK automatically calculates the size of the object.
contentType
String
No
Explanation:
Value range:
Default value:
If this parameter is not specified, the SDK determines the file type based on the suffix of the object name and assigns a value to the parameter. For example, if the suffix of the object name is .xml, the object is an application/xml file. If the suffix is .html, the object is a text/html file.
contentEncoding
String
No
Explanation:
Content-Encoding header in the response. It specifies which encoding is applied to the object.
Default value:
None
contentDisposition
String
No
Explanation:
Default value:
None
cacheControl
String
No
Explanation:
Default value:
None
contentLanguage
String
No
Explanation:
Default value:
None
expires
String
No
Explanation:
The time a cached web page object expires.
Restrictions:
The time must be in the GMT format.
Default value:
None
contentMd5
String
No
Explanation:
Base64-encoded MD5 value of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the object data. If the two values are not the same, HTTP status code 400 is returned.
Restrictions:
  • The MD5 value of the object must be Base64 encoded.
  • If the MD5 value is not specified, the OBS server will not verify the MD5 value of the object.
Value range:
Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864.
Example: n58IG6hfM7vqI4K0vnWpog==
Default value:
None
storageClass
StorageClassEnum
No
Explanation:
Storage class of an object that can be specified at object creation. If this header is not set, the default storage class of the bucket is used as the storage class of the object.
Value range:
See Table 11.
Default value:
None
webSiteRedirectLocation
String
No
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL. This parameter specifies the address the request for the object is redirected to.
The request is redirected to an object anotherPage.html in the same bucket:
WebsiteRedirectLocation:/anotherPage.html
The request is redirected to an external URL http://www.example.com/:
WebsiteRedirectLocation:http://www.example.com/
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Default value:
None
nextPosition
long
No
Explanation:
Start position for the next append upload.
Value range:
0 to the object length, in bytes.
Default value:
None
appendable
boolean
No
Explanation:
Whether the object is appendable.
Value range:
true: The object is appendable.
false: The object is not appendable.
Default value:
None
userMetadata
Map<String, Object>
No
Explanation:
User-defined metadata of the object. To define it, you can add a header starting with x-obs-meta- in the request. In Map, the String key indicates the name of the user-defined metadata that starts with x-obs-meta-, and the Object value indicates the value of the user-defined metadata. To obtain the user-defined metadata of an object, use ObsClient.getObjectMetadata. For details, see Obtaining Object Metadata (SDK for Java).
Restrictions:
  • An object can have multiple pieces of metadata. The size of the metadata cannot exceed 8 KB in total.
  • When you call ObsClient.getObject to download an object, its user-defined metadata will also be downloaded.
Default value:
None
Responses
Table 13 ObsObject
Type
bucketName
String
Explanation:
Bucket name.
Restrictions:
  • A bucket name:
Default value:
None
objectKey
String
Explanation:
Value range:
Default value:
None
owner
Owner
Explanation:
Owner of the object. For details, see Table 10.
metadata
ObjectMetadata
Explanation:
Object metadata. For details, see Table 12.
objectContent
InputStream
Explanation:
Object data stream.
Default value:
None
Code Examples
This example downloads objectname from examplebucket based on a specific condition. In this example, objectname can be downloaded only when it is modified after 00:00:00 on January 1, 2016.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.GetObjectRequest;
import com.obs.services.model.ObsObject;
import java.text.SimpleDateFormat;
public class GetObject004 {
        // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage.
        // Obtain an AK/SK pair on the management console.
        // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage.
        // Obtain an AK/SK pair and a security token using environment variables or import them in other ways.
        // String securityToken = System.getenv("SECURITY_TOKEN");
        // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
        String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com";
        // Obtain an endpoint using environment variables or import it in other ways.
        //String endPoint = System.getenv("ENDPOINT");
        // Create an ObsClient instance.
        // Use the permanent AK/SK pair to initialize the client.
        ObsClient obsClient = new ObsClient(ak, sk,endPoint);
        // Use the temporary AK/SK pair and security token to initialize the client.
        // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint);
        try {
            // Perform a conditional download.
            GetObjectRequest request = new GetObjectRequest("examplebucket", "objectname");
            request.setRangeStart(0l);
            request.setRangeEnd(1000l);
            request.setIfModifiedSince(new SimpleDateFormat("yyyy-MM-dd").parse("2016-01-01"));
            ObsObject obsObject = obsClient.getObject(request);
            System.out.println("getObject successfully");
            obsObject.getObjectContent().close();
        } catch (ObsException e) {
            System.out.println("getObject failed");
            // Request failed. Print the HTTP status code.
            System.out.println("HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            System.out.println("Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            System.out.println("Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            System.out.println("Request ID:" + e.getErrorRequestId());
            System.out.println("Host ID:" + e.getErrorHostId());
            e.printStackTrace();
        } catch (Exception e) {
            // Print other error information.
