Aborting a Multipart Upload (SDK for Java)
Function
This API aborts a multipart upload using the multipart upload ID.
After a multipart upload is aborted, the upload ID cannot be used to upload any part. The storage occupied by any uploaded parts will be released. If any part uploads are in progress, aborting the multipart upload might or might not make the uploads successful. To release the storage occupied by all uploaded parts, you can only abort the multipart upload after all parts have been uploaded.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To abort a multipart upload, you must be the bucket owner or have the required permission (obs:object:AbortMultipartUpload in IAM or AbortMultipartUpload in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.abortMultipartUpload(AbortMultipartUploadRequestrequest)
Request Parameters
Parameter | Type | Mandatory (Yes/No) | Description |
request | Yes | Explanation: Request parameters for aborting a multipart upload. For details, see Table 2. |
bucketName | String | Yes | Bucket name. Explanation: Bucket name. Restrictions:
Default value: None |
objectKey | String | Yes | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Value range: The value must contain 1 to 1,024 characters. Default value: None |
uploadId | String | Yes | Explanation: Multipart upload ID, for example, 000001648453845DBB78F2340DD460D8. Value range: The value must contain 32 characters. Default value: None |
Responses
Parameter | Type | Description |
statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example calls ObsClient.abortMultipartUpload to abort the multipart upload of object objectname in bucket examplebucket based on the upload ID obtained during the multipart upload initiation.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.AbortMultipartUploadRequest; public class AbortMultipartUpload001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { String uploadId = "upload id from initiateMultipartUpload"; // Abort the multipart upload request. AbortMultipartUploadRequest request = new AbortMultipartUploadRequest("examplebucket", "objectname", uploadId); // Abort the multipart upload API. obsClient.abortMultipartUpload(request); System.out.println("AbortMultipartUpload successfully"); } catch (ObsException e) { System.out.println("AbortMultipartUpload failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("AbortMultipartUpload failed"); // Print other error information. e.printStackTrace(); } } } |
