Creating a Parallel File System (SDK for Java)
Function
Parallel File System (PFS), a sub-product of OBS, is a high-performance file system with only milliseconds of latency. PFS supports TB/s bandwidth and millions of IOPS, which make it ideal for processing high-performance computing (HPC) workloads.
You can access data in a PFS using standard OBS APIs. You can also read and write data using obsfs, a PFS client that supports POSIX. obsfs can be deployed on a Linux ECS. Then, you can use obsfs to mount a PFS to the ECS and perform a series of operations online, including creating, deleting, and renaming files or directories, and modifying files.
This API creates a PFS.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To create a PFS, you must have the obs:bucket:CreateBucket permission. IAM is recommended for granting permissions. For details, see IAM Custom Policies.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
- An existing bucket cannot be changed to a PFS.
- PFSs do not support quota configuration. By default, there is no quota limit.
- A maximum of 100 buckets and parallel file systems in total can be created globally for an account. There is no limit on the number or size of objects stored in a bucket.
- The name of a PFS must be unique in OBS. If you repeatedly create PFSs with the same name in the same region, an HTTP status code 200 will be returned. In other cases, creating a PFS with an existing PFS name will have an HTTP status code 409 returned, indicating that such a PFS already exists.
- The name of a deleted PFS can be reused for another bucket or PFS about 30 minutes after the deletion.
- Not all regions support the creation of multi-AZ PFSs. You can check whether a region allows you to create multi-AZ PFSs by referring to Product Pricing Details.
Method
obsClient.createBucket(CreateBucketRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| request | Yes | Explanation: Request parameters for creating a PFS. For details, see Table 2. |
| bucketName | String | Yes | Explanation: PFS name. Restrictions:
Default value: None |
| location | String | Yes if the region where the OBS service resides is not the default region | Explanation: Region where the PFS is to be created. Restrictions: If the specified endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoints are specified, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
| acl | No | Explanation: An ACL that can be specified at PFS creation. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs. Value range:
Default value: AccessControlList.REST_CANNED_PRIVATE | |
| storageClass | No | Explanation: Default storage class. This parameter is not available when creating a PFS. To configure a storage class for the PFS, call an API by referring to Configuring a Storage Class for a Bucket (SDK for Java). Default value: None | |
| extensionPermissionMap | Map<ExtensionBucketPermissionEnum, Set<String>> | No | Explanation: An ACL for granting PFS permissions to one or more accounts. ExtensionBucketPermissionEnum specifies the permissions to grant, and Set<String> describes the list of account IDs (indicated by domain_id) the granted permissions apply to. Value range:
| epid | String | No | Explanation: Enterprise project ID that can be specified at PFS creation. If you have enabled EPS, you can obtain the project ID from the EPS console. Restrictions: The value of epid is a UUID. epid is not required if you have not enabled EPS yet. Example: 9892d768-2d13-450f-aac7-ed0e44c2585f Default value: None |
| availableZone | No | Explanation: Data redundancy type that can be specified at PFS creation. Restrictions: Multi-AZ redundancy is not available for the Archive storage. If the region where the PFS is located does not support multi-AZ storage, the PFS adopts single-AZ storage by default. Value range: To configure multi-AZ storage for the PFS, set this parameter to MULTI_AZ. To configure single-AZ storage (default value assigned by OBS) for the PFS, you do not need to specify this parameter. Default value: If this parameter is left blank, single AZ is specified by default. | |
| bucketType | BucketTypeEnum | No | Explanation: Type of the bucket to be created. Value range: PFS Default value: None |
| Constant | Description |
| AccessControlList.REST_CANNED_PRIVATE | Private read/write. A bucket or object can only be accessed by its owner. |
| AccessControlList.REST_CANNED_PUBLIC_READ | Public read. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket. If this permission is granted on an object, anyone can read the content and metadata of the object. |
| AccessControlList.REST_CANNED_PUBLIC_READ_WRITE | Public read/write. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart upload tasks. If this permission is granted on an object, anyone can read the content and metadata of the object. |
| AccessControlList.REST_CANNED_PUBLIC_READ_DELIVERED | Public read on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart tasks, and bucket metadata, and can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
| AccessControlList.REST_CANNED_PUBLIC_READ_WRITE_DELIVERED | Public read/write on a bucket as well as objects in the bucket. If this permission is granted on a bucket, anyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart upload tasks, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket. This permission cannot be granted on objects. |
| AccessControlList.REST_CANNED_BUCKET_OWNER_FULL_CONTROL | If this permission is granted on an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket owned by another user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x. |
| GRANT_READ | Grants the READ permission to an account ID. The account with the READ permission can list objects, multipart uploads, and object versions in the bucket you are creating, and can obtain bucket metadata. |
| GRANT_WRITE | Grants the WRITE permission to an account ID. The account with the WRITE permission can create, delete, and overwrite objects in the bucket you are creating, and can initiate or abort multipart uploads, as well as upload, copy, and assemble parts. |
| GRANT_READ_ACP | Grants the READ_ACP permission to an account ID. The account with the READ_ACP permission can read the ACL of the bucket you are creating. |
| GRANT_WRITE_ACP | Grants the WRITE_ACP permission to an account ID. The account with the WRITE_ACP permission can modify the ACL of the bucket you are creating. |
| GRANT_FULL_CONTROL | Grants the FULL_CONTROL permission to an account ID. The account with the FULL_CONTROL permission can perform any operation on the bucket you are creating. |
| GRANT_READ_DELIVERED | Grants the READ permission to an account ID. By default, this READ permission applies to all objects in the bucket. |
| GRANT_FULL_CONTROL_DELIVERED | Grants the FULL_CONTROL permission to an account ID. By default, this FULL_CONTROL permission applies to all objects in the bucket. |
| owner | No | Explanation: PFS owner information. For details, see Table 6. | |
| delivered | boolean | No | Explanation: Whether the PFS ACL is applied to all objects in the PFS. Value range: true: The PFS ACL is applied to all objects in the PFS. false: The PFS ACL is not applied to any objects in the PFS. Default value: false |
| grants | Set<GrantAndPermission> | No | Explanation: Grantee information. For details, see Table 7. |
| id | String | Yes | Explanation: Account (domain) ID of the bucket owner. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the owner. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| grantee | Yes | Explanation: Grantees (users or user groups). For details, see Table 8. | |
| permission | Yes | Explanation: Permissions to grant. Value range: See Table 11. Default value: None | |
| Yes | Explanation: Grantee (user) information. For details, see Table 9. | ||
| Yes | Explanation: Grantee (user group) information. Value range: See Table 10. Default value: None |
| grantId | String | Yes if Type is set to GranteeUser | Explanation: Account (domain) ID of the grantee. Value range: To obtain the account ID, see How Do I Get My Account ID and User ID? Default value: None |
| displayName | String | No | Explanation: Account name of the grantee. Value range: To obtain the account name, see How Do I Get My Account ID and User ID? Default value: None |
| ALL_USERS | All users. |
| AUTHENTICATED_USERS | Authorized users. This constant is deprecated. |
| LOG_DELIVERY | Log delivery group. This constant is deprecated. |
| Constant | Default Value | Description |
| PERMISSION_READ | READ | Read permission. A grantee with this permission for a bucket can obtain the list of objects, multipart uploads, bucket metadata, and object versions in the bucket. A grantee with this permission for an object can obtain the object content and metadata. |
| PERMISSION_WRITE | WRITE | Write permission. A grantee with this permission for a bucket can upload, overwrite, and delete any object or part in the bucket. This permission is not available for objects. |
| PERMISSION_READ_ACP | READ_ACP | Permission to read an ACL. A grantee with this permission can obtain the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. |
| PERMISSION_WRITE_ACP | WRITE_ACP | Permission to modify an ACL. A grantee with this permission can update the ACL of a bucket or object. A bucket or object owner has this permission for their bucket or object by default. This permission allows the grantee to change the access control policies, meaning the grantee has full control over a bucket or object. |
| PERMISSION_FULL_CONTROL | FULL_CONTROL | Full control access, including read and write permissions for a bucket and its ACL, or for an object and its ACL. A grantee with this permission for a bucket has READ, WRITE, READ_ACP, and WRITE_ACP permissions for the bucket. A grantee with this permission for an object has READ, READ_ACP, and WRITE_ACP permissions for the object. |
| STANDARD | STANDARD | Standard storage class. |
| WARM | WARM | Infrequent Access storage class. |
| COLD | COLD | Archive storage class. |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
| bucketName | String | Explanation: PFS name. Restrictions:
| owner | Explanation: PFS owner information. For details, see Table 6. | |
| creationDate | java.util.Date | Explanation: Time when the PFS was created. Default value: None |
| location | String | Explanation: Region where the PFS was created. Restrictions: If the specified endpoint is obs.myhuaweicloud.com, this parameter is not required. If any other endpoints are specified, this parameter is required. Value range: To learn about valid regions and endpoints, see Regions and Endpoints. An endpoint is the request address for calling an API. Endpoints vary depending on services and regions. To obtain the regions and endpoints, contact the enterprise administrator. Default value: If obs.myhuaweicloud.com is used as the endpoint and no region is specified, cn-north-1 (the CN North-Beijing1 region) is used by default. |
| storageClass | Explanation: Default storage class. This parameter is not available when creating a PFS. To configure a storage class for the PFS, call an API by referring to Configuring a Storage Class for a Bucket (SDK for Java). Default value: None | |
| acl | Explanation: An ACL that can be specified at PFS creation. You can use either a pre-defined or a user-defined ACL. For more information about ACLs, see ACLs. Value range:
| bucketTypeEnum | BucketTypeEnum | Explanation: Type of the bucket. Value range: PFS Default value: None |
Code Examples
This example creates parallel file system examplebucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.BucketTypeEnum; import com.obs.services.model.CreateBucketRequest; import com.obs.services.model.HeaderResponse; public class CreateBucket001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // The parallel file system is successfully created. CreateBucketRequest request = new CreateBucketRequest(); request.setBucketName("examplebucket"); request.setBucketType(BucketTypeEnum.PFS); // Set the location. location must match the endpoint. request.setLocation("your_region"); HeaderResponse response = obsClient.createBucket(request); System.out.println("CreateBucket successfully"); System.out.println("StatusCode:" + response.getStatusCode()); System.out.println("RequestId:" + response.getRequestId()); } catch (ObsException e) { System.out.println("CreateBucket failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("CreateBucket failed"); // Print other error information. e.printStackTrace(); } } } |
