Deleting a Bucket Inventory Rule (SDK for Java)
Function
This API deletes an inventory rule (identified by configurationId) from the bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To delete a bucket inventory rule, you must be the bucket owner or have the required permission (obs:bucket:DeleteBucketInventoryConfiguration in IAM or DeleteBucketInventoryConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.deleteInventoryConfiguration(DeleteInventoryConfigurationRequest request)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
| configurationId | String | Yes | Explanation: ID of the inventory rule to be deleted. The ID can be up to 64 bytes long and allows letters (a–z, A–Z), digits (0–9), hyphens (-), underscores (_), and periods (.). Default value: None |
Responses
| Parameter | Type | Description |
| statusCode | int | Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
| responseHeaders | Map<String, Object> | Explanation: HTTP response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
Code Examples
This example deletes the inventory rule whose ID is exampleConfigId001 for bucket example-bucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.HeaderResponse; import com.obs.services.model.inventory.DeleteInventoryConfigurationRequest; import com.obs.services.model.inventory.GetInventoryConfigurationRequest; import com.obs.services.model.inventory.GetInventoryConfigurationResult; import com.obs.services.model.inventory.InventoryConfiguration; public class DeleteInventoryConfiguration001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. // String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use a permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Use a temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Set the following parameters. String exampleBucketName = "example-bucket"; String exampleConfigurationId = "exampleConfigId001"; DeleteInventoryConfigurationRequest request = new DeleteInventoryConfigurationRequest(exampleBucketName, exampleConfigurationId); // Delete the inventory rule. HeaderResponse result = obsClient.deleteInventoryConfiguration(request); // Print the HTTP status code. System.out.println("HTTP Code: " + result.getStatusCode()); System.out.println("DeleteInventoryConfiguration succeeded"); } catch (ObsException e) { System.out.println("DeleteInventoryConfiguration failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code: " + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); } catch (Exception e) { System.out.println("DeleteInventoryConfiguration failed"); // Print other error information. e.printStackTrace(); } } } |
