Obtaining the Storage Class of a Bucket (SDK for Java)
Function
OBS provides the following storage classes: Standard, Infrequent Access, and Archive. Choose the storage class that can meet your requirements for performance and cost.
This API returns the storage class of a bucket.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To obtain a bucket's storage class, you must be the bucket owner or have the required permission (obs:bucket:GetBucketStoragePolicy in IAM or GetBucketStoragePolicy in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getBucketStoragePolicy(String bucketName)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| bucketName | String | Yes | Explanation: Bucket name. Restrictions:
Default value: None |
Responses
| Parameter | Type | Description |
| storageClass | Explanation: Storage class of the bucket. For details, see Table 3. |
Code Examples
This example configures a storage class for bucket exampleBucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 | import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.BucketStoragePolicyConfiguration; public class GetBucketStoragePolicy001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one currently in use. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use a permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk, endPoint); // Use a temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Example bucket name String exampleBucket = "examplebucket"; // Obtain the bucket's storage class. BucketStoragePolicyConfiguration storagePolicy = obsClient.getBucketStoragePolicy(exampleBucket); System.out.println("GetBucketStoragePolicy successfully"); System.out.println("GetBucketStorageClass:" + storagePolicy.getBucketStorageClass()); } catch (ObsException e) { System.out.println("GetBucketStoragePolicy failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("GetBucketStoragePolicy failed"); // Print other error information. e.printStackTrace(); } } } |
