Obtaining Storage Information of a Bucket (SDK for Java)
Function
This API returns the storage information of a bucket, including the number of objects and the space occupied by the objects in the bucket.
OBS measures bucket storage statistics in the background and does not update the storage information in real time. So, you are advised not to perform real-time verification on the storage information.
If you have any questions during development, post them on the Issues page of GitHub.
Restrictions
- To obtain the storage information of a bucket, you must be the bucket owner or have the required permission (obs:bucket:GetBucketStorageInfo in IAM or GetBucketStorage in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
obsClient.getBucketStorageInfo(String bucketName)
Request Parameters
Parameter |
Type |
Mandatory (Yes/No) |
Description |
bucketName |
String |
Yes |
Explanation: Bucket name. Restrictions:
Default value: None |
Responses
Parameter |
Type |
Description |
statusCode |
int |
Explanation: HTTP status code. Value range: A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response. For more information, see Status Code. Default value: None |
responseHeaders |
Map<String, Object> |
Explanation: Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header. Default value: None |
size |
long |
Explanation: Size of the space occupied by objects in the bucket. Value range: A non-negative integer, in bytes. Default value: None |
objectNum |
long |
Explanation: Number of objects in the bucket. Default value: None |
Code Examples
This example returns the storage information of bucket exampleBucket.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 |
import com.obs.services.ObsClient; import com.obs.services.exception.ObsException; import com.obs.services.model.BucketStorageInfo; public class GetBucketStorageInfo001 { public static void main(String[] args) { // Obtain an AK/SK pair using environment variables or import the AK/SK pair in other ways. Using hard coding may result in leakage. // Obtain an AK/SK pair on the management console. String ak = System.getenv("ACCESS_KEY_ID"); String sk = System.getenv("SECRET_ACCESS_KEY_ID"); // (Optional) If you are using a temporary AK/SK pair and a security token to access OBS, you are advised not to use hard coding, which may result in information leakage. // Obtain an AK/SK pair and a security token using environment variables or import them in other ways. // String securityToken = System.getenv("SECURITY_TOKEN"); // Enter the endpoint corresponding to the bucket. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. String endPoint = "https://obs.ap-southeast-1.myhuaweicloud.com"; // Obtain an endpoint using environment variables or import it in other ways. //String endPoint = System.getenv("ENDPOINT"); // Create an ObsClient instance. // Use the permanent AK/SK pair to initialize the client. ObsClient obsClient = new ObsClient(ak, sk,endPoint); // Use the temporary AK/SK pair and security token to initialize the client. // ObsClient obsClient = new ObsClient(ak, sk, securityToken, endPoint); try { // Example bucket name String exampleBucket = "examplebucket"; // Obtain the bucket storage information. BucketStorageInfo storageInfo = obsClient.getBucketStorageInfo(exampleBucket); System.out.println("GetBucketStorageInfo successfully"); System.out.println("GetObjectNumber:" + storageInfo.getObjectNumber()); System.out.println("GetStorageSize:" + storageInfo.getSize() + " bytes"); } catch (ObsException e) { System.out.println("GetBucketStorageInfo failed"); // Request failed. Print the HTTP status code. System.out.println("HTTP Code:" + e.getResponseCode()); // Request failed. Print the server-side error code. System.out.println("Error Code:" + e.getErrorCode()); // Request failed. Print the error details. System.out.println("Error Message:" + e.getErrorMessage()); // Request failed. Print the request ID. System.out.println("Request ID:" + e.getErrorRequestId()); System.out.println("Host ID:" + e.getErrorHostId()); e.printStackTrace(); } catch (Exception e) { System.out.println("GetBucketStorageInfo failed"); // Print other error information. e.printStackTrace(); } } } |
