Help Center/
Object Storage Service/
SDK Reference/
.NET/
Troubleshooting/
SDK Common Response Headers
After you call an API in an instance of ObsClient, a sub-class of ObsWebServiceResponse will be returned.
It includes HTTP/HTTPS response headers.
This example obtains request-id from the common response headers when creating a bucket.
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Create a bucket.
try
CreateBucketRequest request = new CreateBucketRequest()
BucketName = "bucketname",
ObsWebServiceResponse response = client.CreateBucket(request);
// Obtain the request ID from the common response headers.
Console.WriteLine("RequestId: {0}", response.RequestId);
foreach(KeyValuePair<string,string> entry in res.Headers)
Console.WriteLine("{0}:{1}", entry.Key, entry.Value);
catch (ObsException ex)
Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
Parent topic: Troubleshooting
