Log Analysis
Log Path
Log files of OBS .NET SDK are saved in the path, usually the save directory of executable files of the project, specified in configuration file Log4Net.config.
Log Level
When current logs cannot be used to troubleshoot system faults, you can change the log level to obtain more information. You can obtain the most information in DEBUG logs and the least information in ERROR logs.
Log level description:
- DEBUG: debugging level
- INFO: information level
- WARN: warning level
- ERROR: error level
Analysis Method
To analyze and locate a problem or view the running status, you can find the related log file based on the date and view the running status or view logs in the log file for troubleshooting.
The procedure is as follows:
- Find related logs.
Find related API logs in the log file directory based on the time when the exception occurred and the operation. The following is an example of error logs:
2018-05-23 21:55:02,103 [9] INFO - ListObjectsRequest begin. 2018-05-23 21:55:02,526 [9] INFO - Send http request end, cost 385 ms 2018-05-23 21:55:02,536 [9] ERROR - Rethrowing as a ObsException error in PerformRequest Request error, StatusCode:404, ErrorCode:NoSuchBucket, ErrorMessage:The specified bucket does not exist, RequestId:0403000001638D4819383F2D4A2B2C50, HostId:N8OMsHew7O/LMHua8qpm49geWphVJI6l2mnnzUIYwQwHAuzJw/kmV+O4iIcf0GRR 2018-05-23 21:55:02,548 [9] ERROR - ListObjectsRequest exception code: NoSuchBucket, with message: Request error 2018-05-23 21:55:02,553 [9] INFO - ListObjectsRequest end, cost 449 ms
- Analyze the cause based on the error logs.
Assuming that the error code you obtain from the log file is NoSuchBucket, you can check it from the table in OBS Server-Side Error Codes and know the error information is "The specified bucket does not exist."
