Viewing Lifecycle Rules
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.GetBucketLifecycle to view lifecycle rules.
This example views the lifecycle configuration of bucket bucketname.
The example code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// View the bucket lifecycle.
try
GetBucketLifecycleRequest request = new GetBucketLifecycleRequest();
request.BucketName = "bucketname";
GetBucketLifecycleResponse response = client.GetBucketLifecycle(request);
foreach (LifecycleRule lifecycleRule in response.Configuration.Rules)
Console.WriteLine("Lifecycle rule id: {0}", lifecycleRule.Id);
Console.WriteLine("Lifecycle rule prefix: {0}", lifecycleRule.Prefix);
Console.WriteLine("Lifecycle rule status: {0}", lifecycleRule.Status);
if (null != lifecycleRule.Expiration)
Console.WriteLine("expiration days: {0}", lifecycleRule.Expiration.Days);
if (null != lifecycleRule.NoncurrentVersionExpiration)
Console.WriteLine("NoncurrentVersionExpiration NoncurrentDays: {0}", lifecycleRule.NoncurrentVersionExpiration.NoncurrentDays);
foreach (Transition transition in lifecycleRule.Transitions)
Console.WriteLine("Transition Days : {0}", transition.Days);
Console.WriteLine("Transition StorageClass : {0}", transition.StorageClass);
foreach (NoncurrentVersionTransition noncurrentVersionTransition in lifecycleRule.NoncurrentVersionTransitions)
Console.WriteLine("NoncurrentVersionTransition NoncurrentDays: {0}", noncurrentVersionTransition.NoncurrentDays);
Console.WriteLine("NoncurrentVersionTransition StorageClass : {0}", noncurrentVersionTransition.StorageClass);
Console.WriteLine("Get bucket lifecycle response: {0}", response.StatusCode);
catch (ObsException ex)
Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
