Obtaining a Versioning Object
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.GetObject to obtain an object version by specifying the version ID (VersionId).
This example downloads object objectname from bucket bucketname by specifying VersionId.
The example code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Obtain versioning objects.
try
GetObjectRequest getObjectRequest = new GetObjectRequest()
BucketName = "bucketname",
ObjectKey = "objectname",
VersionId = "versionId",
using (GetObjectResponse response = client.GetObject(getObjectRequest))
Console.WriteLine("Get object response: {0}", response.StatusCode);
//Save the file locally.
if (!File.Exists("savePath"))
response.WriteResponseStreamToFile("savePath");
catch (ObsException ex)
Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
- If the version ID is null, the object of the latest version will be downloaded, by default.
