Updated on 2026-07-21 GMT+08:00
Checking Whether an Object Exists
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.HeadObject to check whether a specified object exists.
The sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Check whether the specified object exists.
try
    HeadObjectRequest request = new HeadObjectRequest()
        BucketName = "bucketName",
        ObjectKey = "objectKey"
    bool response = client.HeadObject(request);
    Console.WriteLine("Head object response: {0}", response);
catch (ObsException ex)
    Console.WriteLine("Exception errorcode: {0}, when head object.", ex.ErrorCode);
    Console.WriteLine("Exception errormessage: {0}", ex.ErrorMessage);
  • If an exception is thrown and the returned HTTP status code is 404, the bucket does not exist.
