Updated on 2026-07-21 GMT+08:00
Performing a Multipart Copy
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
As a special case of multipart upload, multipart copy implements multipart upload by copying the whole or part of an object in a bucket. You can call ObsClient.CopyPart to copy parts.
This example copies object sourceobjectname from bucket sourcebucketname to bucket destbucketname as object destobjectname.
The sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an instance of ObsClient.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Copy parts.
try
    CopyPartRequest request = new CopyPartRequest();
    request.BucketName = "bucketname";
    request.ObjectKey = "objectname";
    request.UploadId = "uploadId";
    request.PartNumber = 1;
    request.SourceBucketName = "sourcebucketname";
    request.SourceObjectKey = "sourceobjectname";
    CopyPartResponse response = client.CopyPart(request);
    Console.WriteLine("Copy part response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
