Updated on 2026-07-21 GMT+08:00
Obtaining Upload Progress
If you have any questions during the development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call PutObjectRequest.UploadProgress to register a System.EventHandler callback function to obtain upload progress.
This example uploads local file localfile to bucket bucketname as object objectname and uses System.EventHandler to monitor the upload progress.
The sample code is as follows:
// Initialize configuration parameters.
ObsConfig config = new ObsConfig();
config.Endpoint = "https://your-endpoint";
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
string accessKey= Environment.GetEnvironmentVariable("AccessKeyID", EnvironmentVariableTarget.Machine);
string secretKey= Environment.GetEnvironmentVariable("SecretAccessKey", EnvironmentVariableTarget.Machine);
// Create an ObsClient instance.
ObsClient client = new ObsClient(accessKey, secretKey, config);
// Upload a file.
try
    PutObjectRequest request = new PutObjectRequest()
        BucketName = "bucketname",
        ObjectKey = "objectname",
        FilePath = "localfile",// Path of the local file to be uploaded, in which the file name must be specified
    // Represent the progress by showing how many bytes have been uploaded.
    request.ProgressType = ProgressTypeEnum.ByBytes;
    // Refresh the upload progress each time 1 MB data is uploaded.
    request.ProgressInterval = 1024 * 1024;
    // Register the upload progress callback function.
    request.UploadProgress += delegate(object sender, TransferStatus status){
        // Obtain the average upload rate.
        Console.WriteLine("AverageSpeed: {0}", status.AverageSpeed / 1024  + "KB/S");
        // Obtain the upload progress in percentage.
        Console.WriteLine("TransferPercentage: {0}", status.TransferPercentage);
    PutObjectResponse response = client.PutObject(request);
    Console.WriteLine("put object response: {0}", response.StatusCode);
catch (ObsException ex)
    Console.WriteLine("ErrorCode: {0}", ex.ErrorCode);
    Console.WriteLine("ErrorMessage: {0}", ex.ErrorMessage);
  • You can query the upload progress when uploading an object in streaming, file-based, asynchronous, resumable, or appendable mode, or uploading a part.
