libcurl Status Codes (SDK for C)
Overview
The OBS SDK FOR C implements HTTP communication based on libcurl. If curl_easy_perform fails to be executed, the SDK records the libcurl status code (CURLcode) and error information in the log. The format is as follows:
curl_easy_perform failed, CURLcode = 6, curl_error_message is 'Could not resolve host', obs_status = NameLookupError(5), curlErrorBuffer = ...
The key fields are described as follows:
| Field | Description |
| CURLcode | Status code returned by libcurl, which is used to locate underlying network, SSL, or protocol errors |
| curl_error_message | Error message provided by libcurl |
| obs_status | OBS status code mapped from CURLcode by the SDK |
| curlErrorBuffer | Detailed error buffer information of libcurl |
Mapping from CURLcode to OBS Status Codes in the SDK
The SDK uses the request_curl_code_to_status function to map CURLcode to OBS status codes. The mapping is as follows:
| CURLcode | Value | curl_error_message | Mapped OBS Status Code | Description |
| CURLE_OK | 0 | No error | OBS_STATUS_OK | Request succeeded. |
| CURLE_OUT_OF_MEMORY | -1 | Out of memory | OBS_STATUS_OutOfMemory | Memory allocation failed. |
| CURLE_COULDNT_RESOLVE_PROXY | 5 | Couldn't resolve proxy name | OBS_STATUS_NameLookupError | Proxy domain name resolution failed. |
| CURLE_COULDNT_RESOLVE_HOST | 6 | Couldn't resolve host name | OBS_STATUS_NameLookupError | Server domain name resolution failed. |
| CURLE_COULDNT_CONNECT | 7 | Failed to connect to host or proxy | OBS_STATUS_FailedToConnect | Connection to the server or proxy failed. |
| CURLE_WRITE_ERROR | 23 | Write error | OBS_STATUS_ConnectionFailed | Data write failed. |
| CURLE_OPERATION_TIMEDOUT | 28 | Operation timeout | OBS_STATUS_ConnectionFailed | Operation timed out. |
| CURLE_PARTIAL_FILE | 18 | Transferred a partial file | OBS_STATUS_PartialFile | The file is not completely transferred. |
| CURLE_SSL_CACERT | 60 | SSL certificate problem | OBS_STATUS_ServerFailedVerification | SSL certificate verification failed. |
| Others | - | - | OBS_STATUS_InternalError | Errors that are not explicitly mapped by the SDK are classified as internal errors. |
Common CURLcode Fault Locating Guide
CURLE_COULDNT_RESOLVE_HOST (6)
Symptom: The log contains "CURLcode = 6, curl_error_message is 'Could not resolve host'".
Possible causes:
- The DNS configuration is incorrect. As a result, the domain name of the OBS server cannot be resolved.
- The network is disconnected or the DNS server is unreachable.
- The host_name parameter is incorrectly configured (for example, the spelling is incorrect or the domain name suffix is missing).
- The DNS server configuration in the /etc/resolv.conf file is incorrect.
Fault locating procedure:
- Check whether the value of options.bucket_options.host_name is correct. It should be the domain name of the OBS server, for example, obs.cn-north-4.myhuaweicloud.com.
- Run the nslookup obs.cn-north-4.myhuaweicloud.com command on the server to verify DNS resolution.
- Check the DNS server configuration in the /etc/resolv.conf file.
- Add the IP address mapping of the OBS server to the /etc/hosts file for temporary verification.
CURLE_COULDNT_CONNECT (7)
Symptom: The log contains "CURLcode = 7, curl_error_message is 'Failed to connect to host or proxy'".
Possible causes:
- The network is disconnected, and the TCP connection to the OBS server cannot be established.
- The firewall or security group rules block outbound access.
- The proxy configuration is incorrect.
- The OBS server ports (80 for HTTP and 443 for HTTPS) are blocked.
- Run the telnet obs.cn-north-4.myhuaweicloud.com 443 command to verify the TCP connectivity.
- Check the firewall rules and security group configurations to ensure that outbound traffic on port 443 is allowed.
- If a proxy is used, check whether options.request_options.proxy_host is correctly configured.
- Run the curl -v https://obs.cn-north-4.myhuaweicloud.com command to test the connectivity.
CURLE_OPERATION_TIMEDOUT (28)
Symptom: The log contains "CURLcode = 28, curl_error_message is 'Operation timeout'".
Possible causes:
- The network latency is too high, and the request is not completed within the specified timeout interval.
- The timeout interval specified for uploading or downloading large files is too short.
- The server responds slowly.
- The rate limit is too low. As a result, the transmission times out.
- Check whether options.request_options.connect_time (connection timeout interval, in seconds) is set properly.
- Check the settings of options.request_options.speed_time and speed_limit.
- For large file transfer, increase the values of connect_time and max_connected_time.
- Check the network bandwidth and latency.
CURLE_SSL_CACERT (60)
Symptom: The log contains "CURLcode = 60, curl_error_message is 'SSL certificate problem'".
Possible causes:
- The server does not have the CA certificate package.
- The certificate file specified by options.request_options.server_cert_path does not exist or is in an incorrect format.
- A man-in-the-middle (MITM) attack occurs or the certificate is tampered with.
- libcurl is not properly linked with OpenSSL during compilation.
- Run the ls /etc/ssl/certs/ command to check whether the CA certificate package is installed.
- If server_cert_path is set, verify the certificate file path and certificate format.
- Run the curl -v https://obs.cn-north-4.myhuaweicloud.com command to verify the SSL handshake.
- To skip certificate verification (only in the test environment), check whether related options are enabled during compilation.
CURLE_PARTIAL_FILE (18)
Symptom: The log contains "CURLcode = 18, curl_error_message is 'Transferred a partial file'".
Possible causes:
- The network is disconnected during transmission.
- The connection is closed on the server in advance.
- The disk space is insufficient. As a result, the write operation fails.
- The connection is unstable when a large file is downloaded.
- Check the network stability.
- Check whether the disk space is insufficient.
- Use the resumable download API (download_file) to download large files.
- Check whether the value of Content-Length returned by the server is the same as the actual data volume.
CURLE_WRITE_ERROR (23)
Symptom: The log contains "CURLcode = 23, curl_error_message is 'Write error'".
Possible causes:
- The callback function returns an error, causing the write operation to be aborted.
- Data fails to be written to the local disk.
- An exception occurs during the execution of the callback function.
- Check the logic of the put_object_data_callback or get_object_data_callback callback function.
- Verify that the callback function returns the correct value. (The upload callback should return the number of written bytes. Any non-zero status code indicates an error.)
- Check the disk space and file permissions.
CURLE_OUT_OF_MEMORY (-1/other values)
Symptom: The log contains "CURLcode = -1" or memory-related errors.
Possible causes:
- The available system memory is insufficient.
- The buffer fails to be allocated when a large file is uploaded.
- The available memory decreases due to memory leakage.
- Run the free -m command to check the system memory usage.
- Use multipart upload instead of one-off upload to upload large files.
- Check whether memory leakage occurs.
- Adjust the value of options.request_options.buffer_size.
CURLE_COULDNT_RESOLVE_PROXY (5)
Symptom: The log contains "CURLcode = 5, curl_error_message is 'Couldn't resolve proxy name'."
Possible causes:
- The proxy server domain name is incorrectly configured.
- The proxy server domain name cannot be resolved.
- Check the options.request_options.proxy_host configuration format. The format must be hostname:port or http://hostname:port.
- Run the nslookup command to verify the proxy domain name resolution.
- If no proxy is required, ensure that proxy_host is not set.
CURLcode Troubleshooting Procedure in Logs
- Find CURLcode = X in the SDK logs.
- Based on X, refer to this document to determine the error type.
- Locate and rectify the fault according to the corresponding locating procedure.
- If the returned CURLcode is not in the mapping table of this document, the error is not explicitly mapped. In this case, the SDK returns OBS_STATUS_InternalError. For details, see the official libcurl documentation.
