Help Center/ Object Storage Service/ SDK Reference/ C/ Object APIs (SDK for C)/ Configuring Object Lifecycle Rules (SDK for C)
Updated on 2026-08-03 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
Function
Configuring object lifecycle rules is to set the expiration time (using x-obs-expires) for objects. Objects will be automatically deleted by the OBS server after the specified number of days. The OBS SDK for C allows you to configure a lifecycle rule for an object in either of the following ways:
  • Specifying the expiration time during upload: When uploading an object, you can specify the expiration time using the obs_expires field in the obs_put_properties structure. The setting takes effect immediately after the object is uploaded.
  • Setting the expiration time after upload: You can use the set_object_metadata API to modify the expiration time of an existing object.
Restrictions
  • To configure a lifecycle rule for an object, you must be the bucket owner or have permission to upload objects or set object properties. When granted using IAM, the required permission is obs:object:PutObject or obs:object:ModifyObjectMetaData. When granted using a bucket policy, the required permission is PutObject or ModifyObjectMetaData. For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • The unit of obs_expires is day. The expiration time calculated based on the specified number of days cannot be earlier than the current time. For example, if an object was uploaded 10 days ago, you must specify a value greater than or equal to 10.
  • An object will be automatically deleted by the OBS server once it expires. This operation is irreversible.
Method
Scenario 1: configuring a lifecycle rule when uploading an object
When uploading an object, you can set the number of days after which the object expires using the obs_expires field in the obs_put_properties structure. This field applies to all upload APIs (such as put_object, put_object_content, and put_file).
void put_object_content(const obs_options *options, const char *key,
    const char *content, uint64_t content_length,
    obs_put_properties *put_properties,
    server_side_encryption_params *encryption_params,
    obs_put_object_handler *handler, void *callback_data);
Scenario 2: configuring a lifecycle rule after uploading an object
You can call the set_object_metadata API to change the expiration time of an uploaded object. During the change, you need to set the metadata_action field to specify the metadata update policy.
void set_object_metadata(const obs_options *options, obs_object_info *object_info,
    obs_response_handler *handler, void *callback_data);
Request Parameters
The obs_expires field is located in the obs_put_properties structure. You can use init_put_properties to initialize the structure.
Table 1 Lifecycle rule parameters in obs_put_properties
Type
Mandatory (Yes/No)
obs_expires
int64_t
No
Explanation:
Specifies when an object expires. It is measured in days. Once the object expires, it is automatically deleted by the OBS server.
Restrictions:
The value cannot be smaller than the number of days that have passed since the object was created. For example, if the object was uploaded 10 days ago, you cannot specify a value less than 10.
Value range:
The value is an integer greater than 0.
Default value:
-1: The expiration time is not set, and the object will not be automatically deleted.
Table 2 Parameters related to lifecycle rules and metadata operations in obs_put_properties
Type
Mandatory (Yes/No)
obs_expires
int64_t
No
Explanation:
Restrictions:
Value range:
Default value:
-1: The expiration time is not set.
metadata_action
metadata_action_indicator
No
Explanation:
Metadata operation indicator.
Restrictions:
None
Value range:
For details, see metadata_action_indicator.
Default value:
None
Table 3 metadata_action_indicator
Constant
Original Value
OBS_NO_METADATA_ACTION
Default invalid value.
OBS_REPLACE
REPLACE
Uses the complete header carried in the current request to replace the original one and deletes the metadata that is not specified.
OBS_REPLACE_NEW
REPLACE_NEW
The metadata that has an existing value is replaced. A value is assigned to the metadata that does not have a value. The metadata that is not specified remains unchanged. Custom metadata is replaced.
Sample Code - Specifying the Expiration Time When Uploading an Object
This example specifies the expiration time to 30 days when uploading a text file.
#include "eSDKOBS.h"
#include <stdio.h>
#include <string.h>
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
int main()
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    options.bucket_options.bucket_name = "example-bucket-name";
    // Set the upload properties, including the object expiration time.
    obs_put_properties put_properties;
    init_put_properties(&put_properties);
    put_properties.obs_expires = 30;  // The object will be automatically deleted 30 days later.
    const char *content = "Hello, OBS!";
    uint64_t content_length = strlen(content);
    obs_response_handler response_handler = {&response_properties_callback, &response_complete_callback};
    obs_put_object_handler handler = {response_handler, NULL, NULL};
    obs_status ret_status = OBS_STATUS_BUTT;
    put_object_content(&options, "objectname", content, content_length,
                       &put_properties, NULL, &handler, &ret_status);
    if (OBS_STATUS_OK == ret_status) {
        printf("put object with expires successfully.\n");
    } else {
        printf("put object with expires failed(%s).\n", obs_get_status_name(ret_status));
    obs_deinitialize();
    (void)properties; (void)callback_data;
    return OBS_STATUS_OK;
    if (callback_data) { *(obs_status*)callback_data = status; }
    if (error && error->message) { printf("Error: %s\n", error->message); }
Sample Code - Setting the Expiration Time After Uploading an Object
This example sets the expiration time to 30 days for an uploaded object.
#include <stdio.h>
int main()
    // Set the object information.
    obs_object_info object_info = {0};
    object_info.key = "objectname";
    // Set the properties: expiration time and metadata operation policy.
    put_properties.metadata_action = OBS_REPLACE_NEW;  // Add or update specified metadata. Unspecified metadata remains unchanged.
    set_object_metadata(&options, &object_info, &put_properties, NULL, &response_handler, &ret_status);
        printf("set object metadata with expires successfully.\n");
    } else {
        printf("set object metadata with expires failed(%s).\n", obs_get_status_name(ret_status));
    obs_deinitialize();
