Help Center/ Object Storage Service/ SDK Reference/ C/ Object APIs (SDK for C)/ Configuring WORM Retention for an Object (SDK for C)
Updated on 2026-08-03 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API is used to configure or update the retention period for objects uploaded to a bucket with WORM enabled.
  • If you did not configure a retention period or apply the default bucket-level retention policy when uploading an object, you can call this API to configure a retention period for the object.
  • If you already configured a retention period or applied the default bucket-level retention policy when uploading an object, you can call this API to prolong the retention period for the object.
  • The retention period of an object can only be modified, but not deleted.
Restrictions
Method
void set_object_retention(const obs_options *options, const char *key,
    obs_object_retention *retention, const char *version_id,
    obs_response_handler *handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
Context of the requested bucket. You can set the AK, SK, endpoint, bucket, timeout interval, and temporary credentials through obs_options.
Restrictions:
None
Value range:
None
Default value:
None
key
const char *
Yes
Explanation:
Object name. An object name uniquely identifies an object in a bucket.
Restrictions:
None
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
retention
Table 2*
Yes
Explanation:
Structure of an object WORM retention policy.
Restrictions:
None
Value range:
None
Default value:
None
version_id
const char *
No
Explanation:
Object version ID. If versioning is enabled, you can specify the version ID of an object.
Restrictions:
None
Value range:
None
Default value:
None. By default, the latest version of the object is operated.
handler
Yes
Explanation:
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_object_retention
Type
Mandatory (Yes/No)
mode
char *
Yes
Explanation:
Retention mode.
Restrictions:
None
Value range:
COMPLIANCE: In compliance mode, no user can delete protected objects during the retention period.
Default value:
None
retain_until_date
int64_t
Yes
Explanation:
Retention expiration timestamp, in milliseconds. After the retention period expires, the object is no longer protected by WORM.
Restrictions:
In compliance mode, the retention period can only be prolonged, not shortened.
Value range:
A timestamp later than the current time, in milliseconds
Default value:
None
Sample Code
This example configures a WORM retention policy for an object.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
#include "eSDKOBS.h"
#include <stdio.h>
#include <time.h>
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
int main()
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    options.bucket_options.bucket_name = "example-bucket-name";
    // Configure a WORM retention policy for an object. Use compliance mode and set the retention period to one day.
    time_t now = time(NULL);
    int64_t retain_until_date = (int64_t)now * 1000 + (1 * 24 * 60 * 60 * 1000LL);
    obs_object_retention retention = {0};
    retention.mode = "COMPLIANCE";
    retention.retain_until_date = retain_until_date;
    obs_response_handler response_handler = {&response_properties_callback, &response_complete_callback};
    obs_status ret_status = OBS_STATUS_BUTT;
    set_object_retention(&options, "objectname", &retention, NULL, &response_handler, &ret_status);
    if (OBS_STATUS_OK == ret_status) {
        printf("set object retention successfully.\n");
    } else {
        printf("set object retention failed(%s).\n", obs_get_status_name(ret_status));
    obs_deinitialize();
    (void)properties; (void)callback_data;
    return OBS_STATUS_OK;
    if (callback_data) { *(obs_status*)callback_data = status; }
    if (error && error->message) { printf("Error: %s\n", error->message); }
