Help Center/ Object Storage Service/ SDK Reference/ C/ Object APIs (SDK for C)/ Basic Operations (SDK for C)/ Object Download (SDK for C)/ Restoring Archive Objects in Batches (SDK for C)
Updated on 2026-11-17 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
Sample code
This example restores Archive objects in batches. Archive objects must be restored before they can be accessed.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 | #include <stdio.h> #include <stdlib.h> #include <string.h> #include <unistd.h> #include <pthread.h> #include "eSDKOBS.h" #define MAX_KEY_LEN 1024 #define MAX_TASK 10000 #define RESTORE_WAIT_SECONDS 6 // Single object restoration task typedef struct { char key[MAX_KEY_LEN]; obs_status status; } restore_task; //Batch restoration result statistics typedef struct { int total; int success; int failed; char failed_keys[100][MAX_KEY_LEN]; int failed_count; pthread_mutex_t mutex; } batch_result; static batch_result g_result = {0, 0, 0, {{0}}, 0, PTHREAD_MUTEX_INITIALIZER}; static restore_task *g_tasks = NULL; static int g_task_count = 0; static int g_task_index = 0; static pthread_mutex_t g_task_mutex = PTHREAD_MUTEX_INITIALIZER; // Response callback function static obs_status restore_properties_callback(const obs_response_properties *properties, void *callback_data) { (void)properties; (void)callback_data; return OBS_STATUS_OK; } // Completion callback function static void restore_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { (void)error; restore_task *task = (restore_task *)callback_data; char *key = task ? task->key : "unknown"; if (task) { task->status = status; } pthread_mutex_lock(&g_result.mutex); if (status == OBS_STATUS_OK) { g_result.success++; printf("[SUCCESS] restore %s\n", key); } else { g_result.failed++; if (g_result.failed_count < 100) { strncpy(g_result.failed_keys[g_result.failed_count], key, MAX_KEY_LEN - 1); g_result.failed_keys[g_result.failed_count][MAX_KEY_LEN - 1] = '\0'; g_result.failed_count++; } printf("[FAILED] restore %s: %s\n", key, obs_get_status_name(status)); } pthread_mutex_unlock(&g_result.mutex); } // Callback data for listing objects typedef struct { restore_task *tasks; int max_count; int current_count; obs_status ret_status; } list_cb_data; // Data callback for listing objects static obs_status list_objects_callback(int is_truncated, const char *next_marker, int contents_count, const obs_list_objects_content *contents, int common_prefixes_count, const char **common_prefixes, void *callback_data) { (void)is_truncated; (void)next_marker; (void)common_prefixes_count; (void)common_prefixes; list_cb_data *data = (list_cb_data *)callback_data; for (int i = 0; i < contents_count && data->current_count < data->max_count; i++) { memset(&data->tasks[data->current_count], 0, sizeof(restore_task)); strncpy(data->tasks[data->current_count].key, contents[i].key, MAX_KEY_LEN - 1); data->tasks[data->current_count].key[MAX_KEY_LEN - 1] = '\0'; data->current_count++; } return OBS_STATUS_OK; } // Object listing completion callback static void list_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { (void)error; list_cb_data *data = (list_cb_data *)callback_data; data->ret_status = status; } // Data structure for restoration status polling typedef struct { char restore_info[128]; obs_status status; } restore_status_data; static obs_status restore_check_properties_callback(const obs_response_properties *properties, void *callback_data) { restore_status_data *data = (restore_status_data *)callback_data; if (data && properties && properties->restore) { strncpy(data->restore_info, properties->restore, sizeof(data->restore_info) - 1); data->restore_info[sizeof(data->restore_info) - 1] = '\0'; } return OBS_STATUS_OK; } static void restore_check_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { (void)error; restore_status_data *data = (restore_status_data *)callback_data; if (data) { data->status = status; } } // Wait until the restoration of a single object is complete. (The restore header in the object metadata is polled.) static void wait_until_restore_complete(const obs_options *options, obs_object_info *object_info) { // Restoration completion marker: The restore header starts with ongoing-request="false" const char *prefix = "ongoing-request=\"false\""; obs_response_handler handler = { restore_check_properties_callback, restore_check_complete_callback }; for (;;) { restore_status_data data; memset(&data, 0, sizeof(data)); data.status = OBS_STATUS_BUTT; get_object_metadata(options, object_info, NULL, &handler, &data); if (data.status != OBS_STATUS_OK) { printf("[WARN] get metadata for restore check failed(%s)\n", obs_get_status_name(data.status)); break; } if (data.restore_info[0] != '\0') { // Exit after the restoration is complete. if (strstr(data.restore_info, prefix) != NULL) { printf("[INFO] %s restore completed: %s\n", object_info->key, data.restore_info); break; } } // Not completed. Wait for a while and continue polling. sleep(RESTORE_WAIT_SECONDS); } } // Worker thread: Claim a task. Restore objects. Then, wait until the restoration is complete. static void *worker_thread(void *arg) { obs_options *options_ptr = (obs_options *)arg; const char *stored_days = "1"; obs_tier tier = OBS_TIER_EXPEDITED; while (1) { pthread_mutex_lock(&g_task_mutex); if (g_task_index >= g_task_count) { pthread_mutex_unlock(&g_task_mutex); break; } int idx = g_task_index++; pthread_mutex_unlock(&g_task_mutex); restore_task *task = &g_tasks[idx]; // Construct object information. obs_object_info object_info; memset(&object_info, 0, sizeof(obs_object_info)); object_info.key = task->key; object_info.version_id = NULL; // Set the response callback. obs_response_handler handler = { restore_properties_callback, restore_complete_callback }; // Submit a restoration request. task->status = OBS_STATUS_BUTT; restore_object(options_ptr, &object_info, stored_days, tier, &handler, task); if (task->status != OBS_STATUS_OK) { // The restore_complete_callback has already recorded the failure. Skip waiting. continue; } // Wait until objects are restored. wait_until_restore_complete(options_ptr, &object_info); } return NULL; } int main() { // This example shows how to restore Archive or Deep Archive objects in batches. Objects in the Archive or Deep Archive storage class are frozen and cannot be directly accessed. // Submit a restoration request first. The objects must be restored before they can be accessed. // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory. const char *BUCKET_NAME = "example-bucket-name"; const char *PREFIX = "test/source/"; int THREAD_NUM = 8; obs_status status = obs_initialize(OBS_INIT_ALL); if (status != OBS_STATUS_OK) { printf("obs_initialize failed: %s\n", obs_get_status_name(status)); return 1; } obs_options options; init_obs_options(&options); // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use. options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. options.bucket_options.access_key = getenv("ACCESS_KEY_ID"); options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); options.bucket_options.bucket_name = (char *)BUCKET_NAME; options.request_options.auth_switch = OBS_OBS_TYPE; printf("\nListing objects with prefix '%s'...\n", PREFIX); // List the objects to be restored by specifying a prefix. g_tasks = (restore_task *)malloc(sizeof(restore_task) * MAX_TASK); if (!g_tasks) { printf("Failed to allocate memory\n"); obs_deinitialize(); return 1; } list_cb_data cb_data = {g_tasks, MAX_TASK, 0, OBS_STATUS_BUTT}; obs_list_objects_handler list_handler = { {NULL, list_complete_callback}, list_objects_callback }; list_bucket_objects(&options, PREFIX, NULL, NULL, 1000, &list_handler, &cb_data); if (cb_data.ret_status != OBS_STATUS_OK) { printf("list_bucket_objects failed: %s\n", obs_get_status_name(cb_data.ret_status)); free(g_tasks); obs_deinitialize(); return 1; } g_task_count = cb_data.current_count; if (g_task_count == 0) { printf("No objects found with prefix '%s'\n", PREFIX); free(g_tasks); obs_deinitialize(); return 0; } printf("Found %d objects to restore\n", g_task_count); g_result.total = g_task_count; g_result.success = 0; g_result.failed = 0; g_result.failed_count = 0; g_task_index = 0; // Submit restoration requests in batches using multiple threads and wait until the restoration is complete. pthread_t threads[THREAD_NUM]; for (int i = 0; i < THREAD_NUM; i++) { pthread_create(&threads[i], NULL, worker_thread, &options); } for (int i = 0; i < THREAD_NUM; i++) { pthread_join(threads[i], NULL); } // Output the batch restoration statistics. printf("\n========== Batch Restore Summary ==========\n"); printf("Total: %d\n", g_result.total); printf("Success: %d\n", g_result.success); printf("Failed: %d\n", g_result.failed); if (g_result.failed_count > 0) { printf("\nFailed objects:\n"); for (int i = 0; i < g_result.failed_count; i++) { printf(" - %s\n", g_result.failed_keys[i]); } } printf("============================================\n"); free(g_tasks); obs_deinitialize(); return 0; } |
Helpful Links
Parent topic: Object Download (SDK for C)
0
3
4
5
6
7
8
9
10
Very dissatisfiedVery satisfied
