Updated on 2026-08-03 GMT+08:00
Obtaining Back-to-Source by Mirroring Rules (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API is used to obtain the back-to-source by mirroring rules of a specified bucket.
Restrictions
Method
void get_bucket_mirror_back_to_source(const obs_options *options,
    obs_get_bucket_mirror_back_to_source_handler *handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
Context of the requested bucket. You can set the AK, SK, endpoint, bucket, timeout interval, and temporary credentials through obs_options.
Restrictions:
None
Value range:
None
Default value:
None
handler
Table 2*
Yes
Explanation:
Callback structure, which is used to set the callback functions that handle response data.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_get_bucket_mirror_back_to_source_handler
Type
Mandatory (Yes/No)
response_handler
obs_response_handler
Yes
Explanation:
Response callback function structure.
Restrictions:
None
Value range:
None
Default value:
None
get_bucket_mirror_back_to_source_callback
Table 3*
Yes
Explanation:
Pointer to the callback function of the back-to-source by mirroring rules. You can record the content of mirror_back_to_source_rules_return to callback_data in this callback.
Restrictions:
None
Value range:
None
Default value:
None
Table 3 obs_get_bucket_mirror_back_to_source_callback
Type
Mandatory (Yes/No)
Table 4*
Yes
Explanation:
Structure array of the back-to-source by mirroring rules, including id, condition, and redirect.
Restrictions:
The structure and the memory to which the pointer points will be released by the SDK after the callback. Copy them if you need to keep the data.
Value range:
None
Default value:
None
rule_number
unsigned int
Yes
Explanation:
Number of back-to-source by mirroring rules.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Pointer to the custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 4 obs_mirror_back_to_source_rule
Type
Mandatory (Yes/No)
id
char *
Yes
Explanation:
Rule ID, which uniquely identifies a back-to-source by mirroring rule in a bucket.
Restrictions:
None
Value range:
The value can contain 1 to 256 characters.
Default value:
None
condition
Table 5
Yes
Explanation:
Conditions for triggering back to source by mirroring.
Restrictions:
None
Value range:
None
Default value:
None
redirect
Table 6
Yes
Explanation:
Redirection configuration, which specifies the target origin server and redirection behavior during back to source.
Restrictions:
None
Value range:
None
Default value:
None
Table 5 obs_mirror_back_to_source_condition
Type
Mandatory (Yes/No)
http_error_code_returned_equals
char *
Yes
Explanation:
HTTP error code returned by OBS. When OBS returns this error code, back to source by mirroring is triggered.
Restrictions:
None
Value range:
HTTP status code, for example, 404 or 403
Default value:
None
key_prefix_equals
char *
No
Explanation:
Object name prefix. Back to source by mirroring is triggered only for accessed objects whose names contain the specified prefix.
Restrictions:
None
Value range:
None
Default value:
None
Table 6 obs_mirror_back_to_source_redirect
Type
Mandatory (Yes/No)
agency
char *
Yes
Explanation:
Name of the IAM agency, which is used to authorize OBS to access the origin server.
Restrictions:
None
Value range:
None
Default value:
None
public_source
Table 7
Yes
Explanation:
Origin server configuration, which specifies the address of the target origin server for back to source by mirroring.
Restrictions:
None
Value range:
None
Default value:
None
retry_conditions
char **
No
Explanation:
Retry condition list. A retry is performed when a back-to-source request meets the specified conditions.
Restrictions:
A maximum of 20 retry conditions are supported.
Value range:
None
Default value:
None
retry_conditions_number
unsigned int
No
Explanation:
Number of retry conditions.
Restrictions:
None
Value range:
[0, 20]
Default value:
0
pass_query_string
int
No
Explanation:
Whether to transparently transmit query strings to the origin server.
Restrictions:
None
Value range:
  • 0: no
  • 1: yes
Default value:
0
mirror_follow_redirect
int
No
Explanation:
Whether to follow the redirection response from the origin server.
Restrictions:
None
Value range:
  • 0: no
  • 1: yes
Default value:
0
mirror_http_header
Table 9
No
Explanation:
HTTP header configuration, which is used to control the transparent transmission, removal, and setting of HTTP headers in back-to-source requests.
Restrictions:
None
Value range:
None
Default value:
None
replace_key_with
char *
No
Explanation:
Replaces the object name with a specified value during back to source.
Restrictions:
None
Value range:
None
Default value:
None
replace_key_prefix_with
char *
No
Explanation:
Replaces the object name prefix with a specified value during back to source.
Restrictions:
None
Value range:
None
Default value:
None
vpc_endpoint_urn
char *
No
Explanation:
URN of VPC Endpoint. It enables access to the origin server via the VPC Endpoint.
Restrictions:
None
Value range:
None
Default value:
None
redirect_without_referer
int
No
Explanation:
Whether to retrieve data without including the Referer header.
Restrictions:
None
Value range:
  • 0: Referer is included.
  • 1: Referer is not included.
Default value:
0
mirror_allow_http_method
char **
No
Explanation:
List of allowed HTTP methods.
Restrictions:
A maximum of two HTTP methods are allowed.
Value range:
None
Default value:
None
mirror_allow_http_method_number
unsigned int
No
Explanation:
Number of allowed HTTP methods.
Restrictions:
None
Value range:
[0, 2]
Default value:
0
Table 7 obs_mirror_back_to_source_public_source
Type
Mandatory (Yes/No)
source_endpoint
Table 8
Yes
Explanation:
Origin server endpoint configuration, which specifies the primary and standby origin server addresses.
Restrictions:
None
Value range:
None
Default value:
None
Table 8 obs_mirror_back_to_source_source_endpoint
Type
Mandatory (Yes/No)
master
char **
Yes
Explanation:
List of primary origin server addresses.
Restrictions:
A maximum of five primary origin server addresses are allowed.
master_number
unsigned int
Yes
Explanation:
Number of primary origin server addresses.
Restrictions:
None
Value range:
[1, 5]
Default value:
None
slave
char **
No
Explanation:
List of standby origin server addresses, which are used when the primary origin servers are unavailable.
Restrictions:
A maximum of five standby origin server addresses are allowed.
slave_number
unsigned int
No
Explanation:
Number of standby origin server addresses.
Restrictions:
None
Value range:
[0, 5]
Default value:
0
Table 9 obs_mirror_back_to_source_http_header
Type
Mandatory (Yes/No)
pass_all
int
No
Explanation:
Whether to transparently transmit all HTTP headers to the origin server.
Restrictions:
None
Value range:
  • 0: Do not transparently transmit all headers.
  • 1: Transparently transmit all headers.
Default value:
0
pass
char **
No
Explanation:
List of HTTP headers to be transparently transmitted.
Restrictions:
A maximum of 10 headers are supported.
Value range:
None
Default value:
None
pass_number
unsigned int
No
Explanation:
Number of HTTP headers to be transparently transmitted.
Restrictions:
None
Value range:
[0, 10]
Default value:
0
remove
char **
No
Explanation:
List of HTTP headers to be removed.
Restrictions:
Value range:
None
Default value:
None
remove_number
unsigned int
No
Explanation:
Number of HTTP headers to be removed.
Restrictions:
None
Value range:
[0, 10]
Default value:
0
set
Table 10*
No
Explanation:
List of HTTP headers to be set.
Restrictions:
Value range:
None
Default value:
None
set_number
unsigned int
No
Explanation:
Number of HTTP headers to be set.
Restrictions:
None
Value range:
[0, 10]
Default value:
0
Table 10 obs_mirror_back_to_source_set_http_header
Type
Mandatory (Yes/No)
key
char *
Yes
Explanation:
Name of the HTTP header.
Restrictions:
None
Value range:
None
Default value:
None
value
char *
Yes
Explanation:
Value of the HTTP header.
Restrictions:
None
Value range:
None
Default value:
None
Sample Code
This example obtains the back-to-source by mirroring rules of a bucket.
#include "eSDKOBS.h"
#include <stdio.h>
#include <string.h>
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
obs_status get_mirror_back_to_source_callback(obs_mirror_back_to_source_rule *mirror_back_to_source_rules_return,
    unsigned int rule_number, void *callback_data);
typedef struct MirrorBackInfo {
    unsigned int rule_count;
    obs_status ret_status;
} MirrorBackInfo;
int main()
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    options.bucket_options.bucket_name = "example-bucket-name";
    obs_response_handler response_handler = {&response_properties_callback, &response_complete_callback};
    obs_get_bucket_mirror_back_to_source_handler get_mirror_handler = {
        response_handler,
        &get_mirror_back_to_source_callback
    MirrorBackInfo mirror_info = {0};
    mirror_info.ret_status = OBS_STATUS_BUTT;
    get_bucket_mirror_back_to_source(&options, &get_mirror_handler, &mirror_info);
    if (OBS_STATUS_OK == mirror_info.ret_status) {
        printf("get bucket mirror back to source successfully. rule_count: %u\n", mirror_info.rule_count);
    } else {
        printf("get bucket mirror back to source failed(%s).\n", obs_get_status_name(mirror_info.ret_status));
    obs_deinitialize();
    MirrorBackInfo *info = (MirrorBackInfo *)callback_data;
    info->rule_count = rule_number;
    if (mirror_back_to_source_rules_return) {
        unsigned int i;
        for (i = 0; i < rule_number; i++) {
            obs_mirror_back_to_source_rule *rule = &mirror_back_to_source_rules_return[i];
            printf("rule[%u]: id=%s, agency=%s\n",
                i,
                rule->id ? rule->id : "",
                rule->redirect.agency ? rule->redirect.agency : "");
    return OBS_STATUS_OK;
    (void)properties; (void)callback_data;
    if (callback_data) { ((MirrorBackInfo*)callback_data)->ret_status = status; }
    if (error && error->message) { printf("Error: %s\n", error->message); }
