Updated on 2026-08-03 GMT+08:00
Deleting a Bucket Inventory Rule (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API is used to delete an inventory rule of a bucket based on the specified rule ID. After the inventory rule is deleted, OBS will no longer generate inventory files for the rule.
Restrictions
Method
void delete_bucket_inventory(const obs_options *options, const char *inventory_id,
    obs_response_handler *handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
Context of the requested bucket. You can set the AK, SK, endpoint, bucket, timeout interval, and temporary credentials through obs_options.
Restrictions:
None
Value range:
None
Default value:
None
inventory_id
const char *
Yes
Explanation:
Inventory rule ID, which identifies the inventory rule to be deleted.
Restrictions:
None
Value range:
None
Default value:
None
handler
Yes
Explanation:
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Sample Code
This example deletes an inventory rule of a bucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
#include "eSDKOBS.h"
#include <stdio.h>
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
int main()
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    options.bucket_options.bucket_name = "example-source-bucket";
    obs_response_handler response_handler = {&response_properties_callback, &response_complete_callback};
    obs_status ret_status = OBS_STATUS_BUTT;
    delete_bucket_inventory(&options, "inventory1", &response_handler, &ret_status);
    if (OBS_STATUS_OK == ret_status) {
        printf("delete bucket inventory successfully.\n");
    } else {
        printf("delete bucket inventory failed(%s).\n", obs_get_status_name(ret_status));
    obs_deinitialize();
    (void)properties; (void)callback_data;
    return OBS_STATUS_OK;
    if (callback_data) { *(obs_status*)callback_data = status; }
    if (error && error->message) { printf("Error: %s\n", error->message); }
