Updated on 2026-08-03 GMT+08:00
Listing Bucket Inventory Rules (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API is used to list all inventory rules of a specified bucket.
Restrictions
Method
void list_bucket_inventory(const obs_options *options,
    obs_list_bucket_inventory_handler *handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
Context of the requested bucket. You can set the AK, SK, endpoint, bucket, timeout interval, and temporary credentials through obs_options.
Restrictions:
None
Value range:
None
Default value:
None
handler
Table 2*
Yes
Explanation:
Callback structure, which is used to set the callback functions that handle response data.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_list_bucket_inventory_handler
Type
Mandatory (Yes/No)
response_handler
obs_response_handler
Yes
Explanation:
Response callback function structure.
Restrictions:
None
Value range:
None
Default value:
None
list_bucket_inventory_callback
Table 3*
Yes
Explanation:
Pointer to the inventory rule list callback function. You can record the content of inventory_list to callback_data in this callback.
Restrictions:
None
Value range:
None
Default value:
None
Table 3 obs_list_bucket_inventory_callback
Type
Mandatory (Yes/No)
inventory_list
Table 4**
Yes
Explanation:
Inventory rule array. Each element in the array points to an inventory rule.
Restrictions:
The array and the memory to which the pointer points will be released by the SDK after the callback. Copy them if you need to keep the data.
Value range:
None
Default value:
None
inventory_count
unsigned int
Yes
Explanation:
Number of inventory rules.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Pointer to the custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 4 obs_inventory_configuration
Type
Mandatory (Yes/No)
id
char *
Yes
Explanation:
Inventory rule ID, which uniquely identifies an inventory rule in a bucket.
Restrictions:
None
Value range:
The value can contain 1 to 64 characters.
Default value:
None
destination
Table 5*
Yes
Explanation:
Destination bucket configuration, which specifies the location for storing inventory files.
Restrictions:
None
Value range:
None
Default value:
None
schedule
char *
Yes
Explanation:
Generation frequency of inventories.
Restrictions:
None
Value range:
  • Daily
  • Weekly
Default value:
None
format
char *
Yes
Explanation:
Inventory file format.
Restrictions:
None
Value range:
CSV
Default value:
None
included_object_versions
char *
Yes
Explanation:
Object versions included in the inventories.
Restrictions:
None
Value range:
  • All: All versions are included.
  • Current: Only the current versions are included.
Default value:
None
filter
Table 6*
No
Explanation:
Filter. Inventories are generated only for objects with the specified prefix.
Restrictions:
None
Value range:
None
Default value:
None
optional_fields
Table 7*
No
Explanation:
Optional fields included in the inventories.
Restrictions:
None
Value range:
None
Default value:
None
is_enabled
bool
Yes
Explanation:
Whether the inventory rule is enabled.
Restrictions:
None
Value range:
  • true: enabled
  • false: disabled
Default value:
false
Table 5 obs_inventory_destination
Type
Mandatory (Yes/No)
bucket
char *
Yes
Explanation:
Name of the bucket for storing inventory files.
Restrictions:
The destination bucket must already exist, and the source bucket owner must have the write permission on the destination bucket.
Value range:
None
Default value:
None
prefix
char *
No
Explanation:
Prefix of the inventory files in the destination bucket.
Restrictions:
None
Value range:
None
Default value:
None
Table 6 obs_inventory_filter
Type
Mandatory (Yes/No)
prefix
char *
No
Explanation:
Object prefix. Inventories are generated only for objects with this prefix.
Restrictions:
None
Value range:
None
Default value:
None
Table 7 obs_inventory_optional_fields
Type
Mandatory (Yes/No)
field_count
unsigned int
Yes
Explanation:
Number of optional fields.
Restrictions:
None
Value range:
None
Default value:
None
fields
char **
Yes
Explanation:
Array of optional fields.
Restrictions:
None
Value range:
Size, LastModifiedDate, StorageClass, ETag, IsMultipartUploaded, ReplicationStatus, and EncryptionStatus
Default value:
None
Sample Code
This example lists all inventory rules of a bucket.
 3
 4
 5
 6
 7
 8
 9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
38
39
40
41
42
43
44
45
46
47
48
49
50
51
52
53
54
55
56
57
58
59
60
61
62
63
64
65
66
#include "eSDKOBS.h"
#include <stdio.h>
#include <string.h>
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
obs_status list_inventory_callback(obs_inventory_configuration **inventory_list,
    unsigned int inventory_count, void *callback_data);
typedef struct InventoryListInfo {
    unsigned int inventory_count;
    obs_status ret_status;
} InventoryListInfo;
int main()
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    options.bucket_options.bucket_name = "example-source-bucket";
    obs_response_handler response_handler = {&response_properties_callback, &response_complete_callback};
    obs_list_bucket_inventory_handler list_inventory_handler = {
        response_handler,
        &list_inventory_callback
    InventoryListInfo info = {0};
    info.ret_status = OBS_STATUS_BUTT;
    list_bucket_inventory(&options, &list_inventory_handler, &info);
    if (OBS_STATUS_OK == info.ret_status) {
        printf("list bucket inventory successfully. count: %u\n", info.inventory_count);
    } else {
        printf("list bucket inventory failed(%s).\n", obs_get_status_name(info.ret_status));
    obs_deinitialize();
    InventoryListInfo *info = (InventoryListInfo *)callback_data;
    info->inventory_count = inventory_count;
    unsigned int i;
    for (i = 0; i < inventory_count; i++) {
        obs_inventory_configuration *config = inventory_list[i];
        if (config) {
            printf("inventory[%u]: id=%s, schedule=%s, enabled=%s\n",
                i,
                config->id ? config->id : "",
                config->schedule ? config->schedule : "",
                config->is_enabled ? "true" : "false");
    return OBS_STATUS_OK;
    (void)properties; (void)callback_data;
    if (callback_data) { ((InventoryListInfo*)callback_data)->ret_status = status; }
    if (error && error->message) { printf("Error: %s\n", error->message); }
