Updated on 2026-08-03 GMT+08:00
Obtaining the Custom Domain Name of a Bucket (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
You can configure a custom domain name for an OBS bucket so that you can use the domain name to access OBS.
This API is used to obtain the custom domain name of a bucket.
Restrictions
Method
void get_bucket_custom_domain(const obs_options *options, obs_get_bucket_custom_domain_handler*handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
Context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout interval, and temporary credentials through obs_options.
Restrictions:
None
Value range:
None
Default value:
None
handler
obs_get_bucket_custom_domain_handler *
Yes
Explanation:
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
No
Explanation:
Custom callback data
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_options
Type
Mandatory (Yes/No)
bucket_options
obs_bucket_context
Yes
Explanation:
Bucket settings
Restrictions:
None
Value range:
None
Default value:
None
request_options
obs_http_request_option
Yes
Explanation:
Request-related settings
Restrictions:
None
Value range:
None
Default value:
None
temp_auth
temp_auth_configure*
No
Explanation:
Structure used for temporary signature calculation. Set this parameter to NULL if it is not used.
Restrictions:
None
Value range:
None
Default value:
None
Table 3 obs_bucket_context
Type
Mandatory (Yes/No)
host_name
char *
Yes
Explanation:
Requested host name, used as an address for connecting to OBS. It is the domain name (the endpoint) of the server where the requested resource is stored.
Example: host_name = "obs.ap-southeast-1.myhuaweicloud.com";
Restrictions:
The value does not need to contain http:// or https:// as a prefix, which is controlled using obs_protocol.
Value range:
To view the endpoints available for OBS, see Regions and Endpoints.
Default value:
None
bucket_name
char *
Yes
Explanation:
Bucket name
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Value range:
None
Default value:
None
useCname
bool
No
Explanation:
Whether to use a custom domain name to access OBS
Restrictions:
None
Value range:
true: A custom domain name is used.
false: A custom domain name is not used.
Default value:
false
protocol
obs_protocol
No
Explanation:
Whether to use the HTTP or HTTPS protocol
Restrictions:
None
Value range:
For details, see obs_protocol.
Default value:
OBS_PROTOCOL_HTTPS (HTTPS is used by default.)
access_key
char *
Yes
Explanation:
Access key ID (AK)
Restrictions:
None
Value range:
For details, see Creating Access Keys.
Default value:
None
secret_access_key
char *
Yes
Explanation:
Secret access key (SK)
Restrictions:
None
Value range:
Default value:
None
storage_class
obs_storage_class
No
Explanation:
Bucket storage class that can be specified during bucket creation
Restrictions:
None
Value range:
For details, see obs_storage_class.
Default value:
OBS_STORAGE_CLASS_STANDARD (Standard storage class)
token
char *
No
Explanation:
Security token in temporary credentials
Restrictions:
None
Value range:
Default value:
None
epid
char *
No
Explanation:
Enterprise project ID that can be specified during bucket creation. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service.
Restrictions:
The value is in UUID format. This parameter is not required if you have not enabled an enterprise project.
Example: 9892d768-2d13-450f-aac7-ed0e44c2585f
Default value:
None
bucket_type
obs_bucket_type
No
Explanation:
Whether a bucket is an object bucket or a parallel file system
Restrictions:
None
Value range:
For details, see obs_bucket_type.
Default value:
OBS_BUCKET_OBJECT (object bucket)
bucket_list_type
obs_bucket_list_type
No
Explanation:
Whether to list all buckets, object buckets, or parallel file systems
Restrictions:
None
Value range:
For details, see obs_bucket_list_type.
Table 4 obs_protocol
Constant
Original Value
OBS_PROTOCOL_HTTPS
https
HTTPS is used for access.
OBS_PROTOCOL_HTTP
http
HTTP is used for access.
Table 5 obs_storage_class
Constant
Original Value
STANDARD
Standard storage class.
This class features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
OBS_STORAGE_CLASS_STANDARD_IA
STANDARD_IA
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
OBS_STORAGE_CLASS_GLACIER
GLACIER
Archive storage class.
Used for storing rarely accessed (once a year) data.
Table 6 obs_bucket_type
Constant
Original Value
OBS_BUCKET_OBJECT
OBJECT
Object buckets.
OBS_BUCKET_PFS
POSIX
Parallel file systems.
Table 7 obs_bucket_list_type
Constant
Original Value
OBS_BUCKET_LIST_ALL
No header is sent.
Lists all buckets.
OBS_BUCKET_LIST_OBJECT
OBJECT
Lists all object buckets.
OBS_BUCKET_LIST_PFS
POSIX
Lists all parallel file systems.
Table 8 obs_http_request_option
Type
Mandatory (Yes/No)
connect_time
int
Yes
Explanation:
Timeout period for establishing an HTTP/HTTPS connection, in ms.
Restrictions:
None
Value range:
[10000, 60000]
Default value:
60000
max_connected_time
int
Yes
Explanation:
Timeout period (in seconds) of a request.
Restrictions:
None
Value range:
None
Default value:
0 (There is never automatic disconnection.)
proxy_auth
char*
No
Explanation:
Proxy authentication information, in the format username:password
Restrictions:
None
Value range:
None
Default value:
None
proxy_host
char*
No
Explanation:
IP address or host name of the proxy server.
Restrictions:
None
Value range:
None
Default value:
None
Table 9 temp_auth_configure
Type
Mandatory (Yes/No)
expires
long long int
Yes
Explanation:
Validity period of the temporary credentials, in seconds
Restrictions:
None
Value range:
0 to 630720000
Default value:
None
temp_auth_callback
void (*temp_auth_callback)(char *temp_auth_url,
uint64_t temp_auth_url_len,
char*temp_auth_headers,
uint64_t temp_auth_headers_len,
void*callback_data)
Yes
Explanation:
Pointer to the custom callback function, which is used to record the temporary URL and involved signature header to the custom callback data
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 10 temp_auth_callback
Type
Mandatory (Yes/No)
temp_auth_url
char *
Yes
Explanation:
Temporary URL. OBS allows you to construct a URL for a specific operation. In such a URL, you use Query parameters to provide authentication information including the user AK, signature, and validity period. Anyone who has the URL can perform the specified operation. After receiving a request made using such a URL, OBS treats the requester as the user who issued the URL and processes the request. For example, if you construct a pre-signed URL for downloading an object and provide it to various users, they can use the URL to download the object without authentication, but they must do so within the validity period specified by the Expires parameter.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_url_len
uint64_t
Yes
Explanation:
Length of the temporary URL.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_headers
char *
Yes
Explanation:
Headers for temporary authentication.
Restrictions:
None
Value range:
None
Default value:
None
uint64_t
Yes
Explanation:
Length of the buffer for temporary authentication headers, in bytes.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 11 obs_response_handler
Type
Mandatory (Yes/No)
properties_callback
obs_response_properties_callback *
Yes
Explanation:
Details about the request failure, including the error message and resource information. You are advised to record them in callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
complete_callback
obs_response_complete_callback *
Yes
Explanation:
Pointer to the completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
Table 12 obs_response_properties_callback
Type
Mandatory (Yes/No)
properties
const obs_response_properties*
Yes
Explanation:
Parameters in the response headers. You are advised to record them in callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Pointer to the custom callback data
Restrictions:
None
Value range:
None
Default value:
None
Table 13 obs_response_complete_callback
Type
Mandatory (Yes/No)
status
obs_status
Yes
Explanation:
Internal request status code of the SDK
Restrictions:
None
Value range:
For details, see obs_status.
Default value:
None
error_details
const obs_error_details*
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 14 obs_response_properties
Type
Mandatory (Yes/No)
request_id
const char *
No
Explanation:
Value created by OBS to uniquely identify the request. OBS uses this value to locate the fault.
Restrictions:
None
Value range:
None
Default value:
None
request_id2
const char *
No
Explanation:
Special symbol that helps locate faults
Restrictions:
None
Value range:
None
Default value:
None
content_type
const char *
No
Explanation:
MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Restrictions:
None
Value range:
None
Default value:
None
content_length
uint64_t
No
Explanation:
Length of the response body, in bytes
Restrictions:
None
Value range:
None
Default value:
None
server
const char *
No
Explanation:
Server header in an HTTP request
Restrictions:
None
Value range:
None
Default value:
None
etag
const char *
No
Explanation:
Base64-encoded, 128-bit MD5 value of an object. ETag is the unique identifier of the object content. It can be used to determine whether the object content is changed. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the object content, rather than the object metadata. An object created by an upload or copy operation has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
The value must contain 32 characters.
Default value:
None
expiration
const char *
No
Explanation:
Expiration details of an object
Restrictions:
None
Value range:
An integer greater than 0, in days
Default value:
None
website_redirect_location
const char *
No
Explanation:
Indicates where an object request is redirected. If the bucket that contains the object is configured with Website settings, this parameter can be set in the object metadata so that the request for the object can be redirected to another object in the same bucket or an external URL after the website returns a 301 redirect response.
The request is redirected to another object in the bucket:
x-obs-website-redirect-location:/anotherPage.html
The request is redirected to an external URL:
x-obs-website-redirect-location:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection for objects in the root directory of a bucket.
Value range:
None
Default value:
None
version_id
const char *
No
Explanation:
Object version ID
Restrictions:
If an object has no version ID, the value is NULL.
Value range:
Default value:
None
meta_data_count
int
No
Explanation:
Number of elements in the meta_data array
Restrictions:
None
Value range:
None
Default value:
None
meta_data
const obs_name_value *
No
Explanation:
Custom metadata of an object. You can add custom metadata headers that start with x-obs-meta- for easy object management. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response.
Restrictions:
None
Value range:
None
Default value:
None
use_server_side_encryption
char
No
Explanation:
If server-side encryption is enabled, this parameter is set to '\1'.
Restrictions:
None
Value range:
None
Default value:
None
allow_origin
const char *
No
Explanation:
Indicates that the origin is included in the response if the origin in the request meets the CORS configuration requirements on the server.
Restrictions:
None
Value range:
The value that complies with the CORS
Default value:
None
allow_headers
const char *
No
Explanation:
Indicates that the headers are included in the response if the headers in the request meet the CORS configuration requirements on the server.
Restrictions:
At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
Default value:
None
max_age
const char *
No
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the duration your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can contain at most one MaxAgeSeconds.
Value range:
An integer greater than or equal to 0, in seconds
Default value:
3000
allow_methods
const char *
No
Explanation:
Indicates that methods in the rule are included in the response if Access-Control-Request-Method in the request meets the CORS configuration requirements on the server.
Restrictions:
None
Value range:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
expose_headers
const char *
No
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies the CORS-allowed additional headers in the response. These headers provide additional information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them in this parameter.
Restrictions:
Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
None
Default value:
None
storage_class
const char *
No
Explanation:
Object storage class
Restrictions:
This header is returned only when the storage class of an object is not Standard.
Value range:
  • WARM (Infrequent Access storage)
  • COLD (Archive storage)
Default value:
None
const char *
No
Explanation:
Server-side encryption method
Example: x-obs-server-side-encryption:kms
Restrictions:
This header is included in a response if SSE-KMS is used.
Value range:
  • kms (SSE-KMS encryption)
  • obs (SSE-OBS encryption)
Default value:
None
kms_key_id
const char *
No
Explanation:
Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required.
Restrictions:
This header can only be used when you specify kms for the server_side_encryption header.
Value range:
None
Default value:
If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is no default master key, OBS will create one and use it.
customer_algorithm
const char *
No
Explanation:
Decryption algorithm. This header is included in a response if SSE-C is used.
Restrictions:
None
Value range:
AES256 (AES256 decryption algorithm)
Default value:
None
customer_key_md5
const char *
No
Explanation:
MD5 value of the key used for decryption. This header is included in a response if SSE-C is used.
Restrictions:
Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ==
Value range:
Base64-encoded MD5 value of the key ID
Default value:
None
bucket_location
const char *
No
Explanation:
Bucket location
Restrictions:
None
Value range:
None
Default value:
None
obs_version
const char *
No
Explanation:
OBS version of a bucket
Restrictions:
None
Value range:
  • 3.0: bucket of the latest version
  • --: bucket of an earlier version
Default value:
None
restore
const char *
No
Explanation:
Restoration status of an object
Examples: ongoing-request="true" (the object is being restored); ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" (the object has been restored) expiry-date indicates when the restored object will expire.
Restrictions:
For an Archive object that is being restored or has been restored, this header is returned.
Value range:
None
Default value:
None
obs_object_type
const char *
No
Explanation:
Object type
Restrictions:
This header is returned only when the object type is not Normal.
Value range:
Appendable
Default value:
None
obs_next_append_position
const char *
No
Explanation:
Position to be provided for the next request
Restrictions:
This header is returned only when an object is appendable.
Value range:
None
Default value:
None
obs_head_epid
const char *
No
Explanation:
Enterprise project ID for the current bucket. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service.
Restrictions:
Value range:
None
Default value:
None
reserved_indicator
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 15 obs_error_details
Type
message
const char*
Explanation:
Error details in the XML error response body
Restrictions:
None
Value range:
See Error Codes.
Default value:
None
resource
const char*
Explanation:
Bucket or object related to an error
Restrictions:
None
Value range:
None
Default value:
None
further_details
const char*
Explanation:
Value of the FurtherDetails element in the XML error response body
Restrictions:
None
Value range:
None
Default value:
None
extra_details_count
int
Explanation:
Number of other elements in the XML error response body
Restrictions:
None
Value range:
None
Default value:
None
extra_details
obs_name_value*
Explanation:
Values of other elements in the XML error response body
Restrictions:
None
error_headers_count
int
Explanation:
Number of headers in error_headers
Restrictions:
None
Value range:
None
Default value:
None
error_headers
char**
Explanation:
All response headers that contain the error
Restrictions:
None
Value range:
None
Default value:
None
Table 16 obs_name_value
Type
Mandatory (Yes/No)
name
char *
No
Explanation:
Key of a property.
Restrictions:
None
Value range:
None
Default value:
None
value
char *
No
Explanation:
Property value.
Restrictions:
None
Value range:
None
Default value:
None
Table 17 obs_status
Constant
Original Value
OBS_STATUS_OK
0
The request is successful.
OBS_STATUS_InitCurlFailed
Failed to initialize curl.
OBS_STATUS_InternalError
2
Internal error.
OBS_STATUS_OutOfMemory
3
The local memory is insufficient.
OBS_STATUS_FailedToIInitializeRequest
6
Failed to initialize the request.
OBS_STATUS_XmlParseFailure
23
Failed to parse the XML file.
OBS_STATUS_NameLookupError
33
Domain name resolution failed.
OBS_STATUS_FailedToConnect
34
Failed to connect to the server.
OBS_STATUS_ConnectionFailed
36
Network connection failed.
OBS_STATUS_PartialFile
38
Network transmission interrupted.
OBS_STATUS_InvalidParameter
39
Invalid parameter.
OBS_STATUS_NoToken
40
The current number of concurrent tasks exceeds the upper limit (1,000 by default). The token here refers to the concurrent request token, not the security authentication token. You can use the set_online_request_max_count function to adjust the maximum number of concurrent tasks.
OBS_STATUS_OpenFileFailed
41
Failed to open the file.
OBS_STATUS_AccessDenied
43
The request is rejected.
OBS_STATUS_MalformedPolicy
44
The format of the request policy is incorrect.
OBS_STATUS_MalformedXML
45
The XML request format is incorrect.
OBS_STATUS_MethodNotAllowed
46
The request method is not allowed.
OBS_STATUS_SignatureDoesNotMatch
47
The signatures do not match. Check whether the AK, SK, and token are correct.
OBS_STATUS_ServiceUnavailable
48
Server exception.
OBS_STATUS_SlowDown
49
The request frequency is too high.
Table 18 obs_get_bucket_custom_domain_handler
Type
Mandatory (Yes/No)
response_handler
obs_response_handler *
Yes
Explanation:
Response callback function structure
Restrictions:
None
Value range:
None
Default value:
None
get_bucket_custom_domain_callback
obs_get_bucket_custom_domain_callback *
Yes
Explanation:
Pointer to the callback function. The parameters in the callback can be recorded in callback_data (custom callback data).
Restrictions:
None
Value range:
None
Default value:
None
Table 19 obs_get_bucket_custom_domain_callback
Type
Mandatory (Yes/No)
domains_count
int
Yes
Explanation:
Length of a bucket's custom domain name list
Restrictions:
None
Value range:
None
Default value:
None
domains_list
obs_name_value *
Yes
Explanation:
Bucket's custom domain name list
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 20 obs_domain_response
Type
domain_name
const char *
Custom domain name
create_time
const char *
Creation time
certificate_id
const char*
Certificate ID
Sample Code
This example obtains the custom domain name of a bucket.
#include "eSDKOBS.h"
#include <stdio.h>
#include <stdlib.h>
// The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data).
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void get_bucket_custom_domain_callback(int domains_count, obs_domain_response* domains_list, void* callback_data);
typedef struct bucket_custom_domain_data
    obs_status ret_status;
    obs_domain_response domains_list[100];
    int domains_count;
}bucket_custom_domain_data;
int main()
    // The following code shows how to obtain the custom domain name of a bucket.
    // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory.
    obs_status ret_status = obs_initialize(OBS_INIT_ALL);
    if (OBS_STATUS_OK != ret_status)
        printf("obs_initialize failed(%s).\n", obs_get_status_name(ret_status));
        return -1;
    obs_options options;
    // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class).
    init_obs_options(&options);
    options.bucket_options.host_name = "obs.cn-north-4.myhuaweicloud.com";
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Specify the bucket name, for example, example-bucket-name.
    char * bucket_name = "example-bucket-name";
    options.bucket_options.bucket_name = bucket_name;
    // Set the response callback function.
    obs_get_bucket_custom_domain_handler get_bucket_custom_domain_handler = {
            &response_properties_callback,
            &response_complete_callback
        &get_bucket_custom_domain_callback
    bucket_custom_domain_data custom_domain_data = { 0 };
    custom_domain_data.ret_status = OBS_STATUS_BUTT;
    get_bucket_custom_domain(&options, &get_bucket_custom_domain_handler, &custom_domain_data);
    // Check whether the request is successful.
    if (custom_domain_data.ret_status == OBS_STATUS_OK) {
        printf("Get bucket custom domain successfully.");
    else
        printf("Get bucket custom domain failed(%s).\n",
            obs_get_status_name(custom_domain_data.ret_status));
    // Release the allocated global resources.
    obs_deinitialize();
    obs_domain_response* domains_list, void* callback_data) {
    if (callback_data) {
        bucket_custom_domain_data *custom_domain_data = (bucket_custom_domain_data *)callback_data;
        int i = 0;
        for (; i < domains_count; ++i) {
            printf("Domain[%d].name : %s\n", i, domains_list[i].domain_name);
            printf("Domain[%d].certificate_id : %s\n", i, domains_list[i].certificate_id);
            printf("Domain[%d].create_time : %s\n", i, domains_list[i].create_time);
            printf("\n");
    else {
        printf("Callback_data is NULL");
    return;
    if (properties == NULL)
        printf("error! obs_response_properties is null!");
        return OBS_STATUS_OK;
    // Print the response.
#define print_nonnull(name, field)                                 \
    do {                                                           \
        if (properties-> field) {                                  \
            printf("%s: %s\n", name, properties->field);          \
    } while (0)
    print_nonnull("request_id", request_id);
    print_nonnull("request_id2", request_id2);
    print_nonnull("content_type", content_type);
    if (properties->content_length) {
        printf("content_length: %llu\n", properties->content_length);
    print_nonnull("server", server);
    print_nonnull("ETag", etag);
    print_nonnull("expiration", expiration);
    print_nonnull("website_redirect_location", website_redirect_location);
    print_nonnull("version_id", version_id);
    print_nonnull("allow_origin", allow_origin);
    print_nonnull("allow_headers", allow_headers);
    print_nonnull("max_age", max_age);
    print_nonnull("allow_methods", allow_methods);
    print_nonnull("expose_headers", expose_headers);
    print_nonnull("storage_class", storage_class);
    print_nonnull("server_side_encryption", server_side_encryption);
    print_nonnull("kms_key_id", kms_key_id);
    print_nonnull("customer_algorithm", customer_algorithm);
    print_nonnull("customer_key_md5", customer_key_md5);
    print_nonnull("bucket_location", bucket_location);
    print_nonnull("obs_version", obs_version);
    print_nonnull("restore", restore);
    print_nonnull("obs_object_type", obs_object_type);
    print_nonnull("obs_next_append_position", obs_next_append_position);
    print_nonnull("obs_head_epid", obs_head_epid);
    print_nonnull("reserved_indicator", reserved_indicator);
    int i;
    for (i = 0; i < properties->meta_data_count; i++) {
        printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name,
            properties->meta_data[i].value);
// The completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data).
        custom_domain_data->ret_status = status;
    else {
    if (error && error->message) {
        printf("Error Message: \n   %s\n", error->message);
    if (error && error->resource) {
        printf("Error Resource: \n  %s\n", error->resource);
    if (error && error->further_details) {
        printf("Error further_details: \n   %s\n", error->further_details);
    if (error && error->extra_details_count) {
        int i;
        for (i = 0; i < error->extra_details_count; i++) {
            printf("Error Extra Detail(%d):\n   %s:%s\n", i, error->extra_details[i].name,
                error->extra_details[i].value);
    if (error && error->error_headers_count) {
        int i;
        for (i = 0; i < error->error_headers_count; i++) {
            const char *errorHeader = error->error_headers[i];
            printf("Error Headers(%d):\n    %s\n", i, errorHeader == NULL ? "NULL Header" : errorHeader);
