Listing Files in a Parallel File System (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
You can call list_bucket_objects to list files in a parallel file system.
Restrictions
- A maximum of 1,000 files can be listed for each API call.
- To list files in a parallel file system, you must be the owner of the parallel file system or have the required permission (obs:bucket:ListBucket granted using IAM or ListBucket granted using a policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
1 2 | void list_bucket_objects(const obs_options *options, const char *prefix, const char *marker, const char *delimiter, int maxkeys, obs_list_objects_handler *handler, void *callback_data); |
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | const obs_options * | Yes | The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options. |
| prefix | char * | No | Prefix that the names of objects to list must contain. |
| marker | char * | No | Object name to start with when listing objects. All objects are listed in the lexicographical order. |
| delimiter | char * | No | The character used to group object names. If the object name contains the value specified by the delimiter parameter, the string from the first character to the first delimiter in the object name (excluding the prefix if prefix is specified) is grouped into one commonPrefix to be returned. For a parallel file system, if this parameter is not specified, all the content in the directory is recursively listed by default, including the content in subdirectories. In big data scenarios, file systems usually have multiple directory levels with a huge number of objects. In this case, you are advised to configure [delimiter="/"] to list only the objects in the current directory with no subdirectories included, making your listing more efficient. |
| maxkeys | int | Yes | Maximum number of objects listed in the response body. The value ranges from 1 to 1000. If the value exceeds 1000, only 1,000 objects are returned. |
| handler | obs_list_objects_handler * | Yes | A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data. |
| callback_data | void * | No | Custom callback data. |
Sample Code
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 | #include "eSDKOBS.h" #include <stdio.h> #include <time.h> #include <sys/stat.h> // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data); void listobjects_complete_callback(obs_status status, const obs_error_details *error, void *callback_data); typedef struct list_object_callback_data { int is_truncated; char next_marker[1024]; int keyCount; int allDetails; obs_status ret_status; } list_object_callback_data; obs_status list_objects_callback(int is_truncated, const char *next_marker, int contents_count, const obs_list_objects_content *contents, int common_prefixes_count, const char **common_prefixes, void *callback_data); int main() { // The following code shows how to use the list_bucket_objects function to list objects in a bucket: // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory. obs_status ret_status = obs_initialize(OBS_INIT_ALL); if (OBS_STATUS_OK != ret_status) { printf("obs_initialize failed(%s).\n", obs_get_status_name(ret_status)); return -1; } obs_options options; // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class). init_obs_options(&options); // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation. options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. options.bucket_options.access_key = getenv("ACCESS_KEY_ID"); options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); // Specify the bucket name, for example, example-bucket-name. char * bucket_name = "example-bucket-name"; options.bucket_options.bucket_name = bucket_name; // Set the response callback function. obs_list_objects_handler list_bucket_objects_handler = { { &response_properties_callback, &listobjects_complete_callback }, &list_objects_callback }; // Customize callback data. list_object_callback_data data; memset(&data, 0, sizeof(list_object_callback_data)); data.allDetails = 1; const char* prefix = NULL; const char* marker = NULL; const char* delimiter = "/"; int maxkeys = 1000; // List objects. list_bucket_objects(&options, prefix, marker, delimiter, maxkeys, &list_bucket_objects_handler, &data); if (OBS_STATUS_OK == data.ret_status) { printf("list bucket objects successfully. \n"); } else { printf("list bucket objects failed(%s).\n", obs_get_status_name(data.ret_status)); } // Release the allocated global resources. obs_deinitialize(); } // The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data) { if (properties == NULL) { printf("error! obs_response_properties is null!"); return OBS_STATUS_OK; } // Print the response. #define print_nonnull(name, field) \ do { \ if (properties-> field) { \ printf("%s: %s\n", name, properties->field); \ } \ } while (0) print_nonnull("request_id", request_id); print_nonnull("request_id2", request_id2); print_nonnull("content_type", content_type); if (properties->content_length) { printf("content_length: %llu\n", properties->content_length); } print_nonnull("server", server); print_nonnull("ETag", etag); print_nonnull("expiration", expiration); print_nonnull("website_redirect_location", website_redirect_location); print_nonnull("version_id", version_id); print_nonnull("allow_origin", allow_origin); print_nonnull("allow_headers", allow_headers); print_nonnull("max_age", max_age); print_nonnull("allow_methods", allow_methods); print_nonnull("expose_headers", expose_headers); print_nonnull("storage_class", storage_class); print_nonnull("server_side_encryption", server_side_encryption); print_nonnull("kms_key_id", kms_key_id); print_nonnull("customer_algorithm", customer_algorithm); print_nonnull("customer_key_md5", customer_key_md5); print_nonnull("bucket_location", bucket_location); print_nonnull("obs_version", obs_version); print_nonnull("restore", restore); print_nonnull("obs_object_type", obs_object_type); print_nonnull("obs_next_append_position", obs_next_append_position); print_nonnull("obs_head_epid", obs_head_epid); print_nonnull("reserved_indicator", reserved_indicator); int i; for (i = 0; i < properties->meta_data_count; i++) { printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name, properties->meta_data[i].value); } return OBS_STATUS_OK; } void print_error_details(const obs_error_details *error) { if (error && error->message) { printf("Error Message: \n %s\n", error->message); } if (error && error->resource) { printf("Error Resource: \n %s\n", error->resource); } if (error && error->further_details) { printf("Error further_details: \n %s\n", error->further_details); } if (error && error->extra_details_count) { int i; for (i = 0; i < error->extra_details_count; i++) { printf("Error Extra Detail(%d):\n %s:%s\n", i, error->extra_details[i].name, error->extra_details[i].value); } } if (error && error->error_headers_count) { int i; for (i = 0; i < error->error_headers_count; i++) { const char *errorHeader = error->error_headers[i]; printf("Error Headers(%d):\n %s\n", i, errorHeader == NULL ? "NULL Header" : errorHeader); } } } void listobjects_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { if (callback_data) { list_object_callback_data *data = (list_object_callback_data *)callback_data; data->ret_status = status; } else { printf("Callback_data is NULL"); } print_error_details(error); } static void printListBucketHeader(int allDetails) { printf("%-50s %-20s %-5s", " Key", " Last Modified", "Size"); if (allDetails) { printf(" %-34s %-64s %-12s %-12s", " ETag", " Owner ID", "Display Name", "StorageClass"); } printf("\n"); printf("-------------------------------------------------- " "-------------------- -----"); if (allDetails) { printf(" ---------------------------------- " "-------------------------------------------------" "--------------- ------------ ------------"); } printf("\n"); } obs_status list_objects_callback(int is_truncated, const char *next_marker, int contents_count, const obs_list_objects_content *contents, int common_prefixes_count, const char **common_prefixes, void *callback_data) { list_object_callback_data *data = (list_object_callback_data *)callback_data; data->is_truncated = is_truncated; if ((!next_marker || !next_marker[0]) && contents_count) { next_marker = contents[contents_count - 1].key; } if (next_marker) { snprintf(data->next_marker, sizeof(data->next_marker), "%s", next_marker); } else { data->next_marker[0] = 0; } if (contents_count && !data->keyCount) { printListBucketHeader(data->allDetails); } int i; for (i = 0; i < contents_count; i++) { const obs_list_objects_content *content = &(contents[i]); char timebuf[256] = { 0 }; time_t t = (time_t)content->last_modified; strftime(timebuf, sizeof(timebuf), "%Y-%m-%dT%H:%M:%SZ", gmtime(&t)); char sizebuf[16] = { 0 }; if (content->size < 100000) { sprintf_s(sizebuf, sizeof(sizebuf), "%5llu", (unsigned long long) content->size); } else if (content->size < (1024 * 1024)) { sprintf_s(sizebuf, sizeof(sizebuf), "%4lluK", ((unsigned long long) content->size) / 1024ULL); } else if (content->size < (10 * 1024 * 1024)) { float f = content->size; f /= (1024 * 1024); sprintf_s(sizebuf, sizeof(sizebuf), "%1.2fM", f); } else if (content->size < (1024 * 1024 * 1024)) { sprintf_s(sizebuf, sizeof(sizebuf), "%4lluM", ((unsigned long long) content->size) / (1024ULL * 1024ULL)); } else { float f = (content->size / 1024); f /= (1024 * 1024); sprintf_s(sizebuf, sizeof(sizebuf), "%1.2fG", f); } printf("%-50s %s %s", content->key, timebuf, sizebuf); if (data->allDetails) { printf(" %-36s %-64s %-20s %-16s %-16s", content->etag, content->owner_id ? content->owner_id : "", content->owner_display_name ? content->owner_display_name : "", content->storage_class ? content->storage_class : "", content->type ? content->type : "" ); } printf("\n"); } data->keyCount += contents_count; for (i = 0; i < common_prefixes_count; i++) { printf("\nCommon Prefix: %s\n", common_prefixes[i]); } printf("contents_count:%d\n", contents_count); return OBS_STATUS_OK; } |
