Updated on 2026-11-17 GMT+08:00
Batch Deleting Objects (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API deletes objects in a batch from a specific bucket. Deleted objects cannot be restored.
In a batch deletion, OBS concurrently deletes the specified objects and returns the deletion result of each object.
Restrictions
  • To delete objects in a batch, you must be the bucket owner or have the required permission (obs:object:DeleteObject in IAM or DeleteObject in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Configuring an Object Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • If versioning is not enabled for a bucket, deleted objects cannot be restored.
  • A maximum of 1,000 objects can be deleted at a time. If you send a request for deleting more than 1,000 objects, OBS returns an error message.
  • After concurrent tasks are assigned, if an internal error occurs during the cyclic deletion of multiple objects, there may be data inconsistency (the index data of an object is deleted but the metadata still exists).
Method
void batch_delete_objects(const obs_options *options, obs_object_info *object_info,
	obs_delete_object_info *delobj,
	obs_put_properties *put_properties,
	obs_delete_object_handler *handler,
	void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options.
Restrictions:
None
object_info
obs_object_info *
Yes
Explanation:
Object name and version ID.
Restrictions:
For a non-versioned object, set the version ID to 0.
delobj
obs_delete_object_info*
Yes
Explanation:
Specifies the number of objects to be deleted and the quiet mode.
Restrictions:
None
put_properties
obs_put_properties*
No
Explanation:
Sets the verification properties of the object to be deleted.
Restrictions:
None
handler
obs_delete_object_handler*
Yes
Explanation:
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data.
Restrictions:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_options
Type
Mandatory (Yes/No)
bucket_options
obs_bucket_context
Yes
Explanation:
Bucket settings.
Restrictions:
None
request_options
obs_http_request_option
Yes
Explanation:
Request-related settings.
Restrictions:
None
temp_auth
temp_auth_configure*
No
Explanation:
The structure used to calculate a temporary signature. Set it to NULL if it is not used.
Restrictions:
None
Table 3 obs_bucket_context
Type
Mandatory (Yes/No)
host_name
char *
Yes
Explanation:
The requested host name, used as an address for connecting to OBS. It is the domain name (the endpoint) of the server where the requested resource is stored.
Example: host_name = "obs.ap-southeast-1.myhuaweicloud.com";
Restrictions:
The value does not need to contain http:// or https:// as a prefix, which is controlled using obs_protocol.
Value range:
To view the endpoints available for OBS, see Regions and Endpoints.
Default value:
None
bucket_name
char *
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket properties comply with those set in the first creation request.
Value range:
None
Default value:
None
useCname
bool
No
Explanation:
Whether to use a custom domain name to access OBS.
Restrictions:
None
Value range:
true: A custom domain name is used.
false: A custom domain name is not used.
Default value:
false
protocol
obs_protocol
No
Explanation:
Whether to use the HTTP or HTTPS protocol.
Restrictions:
None
Value range:
For details, see Table 6.
Default value:
OBS_PROTOCOL_HTTPS (HTTPS is used by default.)
access_key
char *
Yes
Explanation:
Access key ID (AK).
Restrictions:
None
Value range:
For details, see Creating Access Keys.
Default value:
None
secret_access_key
char *
Yes
Explanation:
Secret access key (SK).
Restrictions:
None
Value range:
Default value:
None
storage_class
obs_storage_class
No
Explanation:
Bucket storage class that can be specified at bucket creation.
Restrictions:
None
Value range:
For details, see Table 4.
Default value:
OBS_STORAGE_CLASS_STANDARD (Standard storage class)
token
char *
No
Explanation:
The security token in temporary credentials.
Restrictions:
None
Value range:
Default value:
None
epid
char *
No
Explanation:
Enterprise project ID that can be specified during bucket creation. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service.
Restrictions:
The value needs to be represented as a UUID. This parameter is not required if EPS is not enabled.
Example: 9892d768-2d13-450f-aac7-ed0e44c2585f
Default value:
None
bucket_type
obs_bucket_type
No
Explanation:
Whether a bucket is an object bucket or a parallel file system.
Restrictions:
None
Value range:
For details, see Table 7.
Default value:
OBS_BUCKET_OBJECT (object bucket)
bucket_list_type
obs_bucket_list_type
No
Explanation:
Whether to list all buckets, object buckets, or parallel file systems.
Restrictions:
None
Value range:
For details, see Table 8.
Table 4 obs_storage_class
Constant
Original Value
STANDARD
Standard storage class.
This class features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
OBS_STORAGE_CLASS_STANDARD_IA
STANDARD_IA
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
OBS_STORAGE_CLASS_GLACIER
GLACIER
Archive storage class.
Used for storing rarely accessed (once a year) data.
Table 5 obs_http_request_option
Type
Mandatory (Yes/No)
connect_time
int
Yes
Explanation:
Timeout period for establishing an HTTP/HTTPS connection, in ms.
Restrictions:
None
Value range:
[10000, 60000]
Default value:
60000
max_connected_time
int
Yes
Explanation:
Timeout period (in seconds) of a request.
Restrictions:
None
Value range:
None
Default value:
0 (There is never automatic disconnection.)
proxy_auth
char*
No
Explanation:
Proxy authentication information, in the format username:password
Restrictions:
None
Value range:
None
Default value:
None
proxy_host
char*
No
Explanation:
IP address or host name of the proxy server.
Restrictions:
None
Value range:
None
Default value:
None
Table 6 obs_protocol
Constant
Original Value
OBS_PROTOCOL_HTTPS
https
HTTPS is used for access.
OBS_PROTOCOL_HTTP
http
HTTP is used for access.
Table 7 obs_bucket_type
Constant
Original Value
OBS_BUCKET_OBJECT
OBJECT
Object buckets.
OBS_BUCKET_PFS
POSIX
Parallel file systems.
Table 8 obs_bucket_list_type
Constant
Original Value
OBS_BUCKET_LIST_ALL
No header is sent.
Lists all buckets.
OBS_BUCKET_LIST_OBJECT
OBJECT
Lists all object buckets.
OBS_BUCKET_LIST_PFS
POSIX
Lists all parallel file systems.
Table 9 temp_auth_configure
Type
Mandatory (Yes/No)
expires
long long int
Yes
Explanation:
Validity period of the temporary credentials, in seconds.
Restrictions:
None
Value range:
[0-630720000]
Default value:
None
temp_auth_callback
void (*temp_auth_callback)(char *temp_auth_url,
uint64_t temp_auth_url_len,
char*temp_auth_headers,
uint64_t temp_auth_headers_len,
void*callback_data)
Yes
Explanation:
The pointer to the custom callback function, which is used to record the temporary URL and involved signature header to the custom callback data.
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 10 temp_auth_callback
Type
Mandatory (Yes/No)
temp_auth_url
char *
Yes
Explanation:
Temporary URL. OBS allows you to construct a URL for a specific operation. In such a URL, you use Query parameters to provide authentication information including the user AK, signature, and validity period. Anyone who has the URL can perform the specified operation. After receiving a request made using such a URL, OBS treats the requester as the user who issued the URL and processes the request. For example, if you construct a pre-signed URL for downloading an object and provide it to various users, they can use the URL to download the object without authentication, but they must do so within the validity period specified by the Expires parameter.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_url_len
uint64_t
Yes
Explanation:
Length of the temporary URL.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_headers
char *
Yes
Explanation:
Headers for temporary authentication.
Restrictions:
None
Value range:
None
Default value:
None
uint64_t
Yes
Explanation:
Length of the buffer for temporary authentication headers, in bytes.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 11 obs_delete_object_info
Type
Mandatory (Yes/No)
keys_number
unsigned int
Yes
Explanation:
Number of deleted object names.
Restrictions:
None
Value range:
None
Default value:
None
quiet
int
No
Explanation:
Specifies whether to use the quiet mode.
Restrictions:
None
Value range:
None
Default value:
None
Table 12 obs_delete_object_handler
Type
Mandatory (Yes/No)
response_handler
obs_response_handler *
Yes
Explanation:
Response callback function structure.
Restrictions:
None
delete_object_data_callback
obs_delete_object_data_callback *
Yes
Explanation:
The pointer to the callback function, where the callback parameters can be recorded in callback_data (custom callback data).
Restrictions:
None
Table 13 obs_response_handler
Type
Mandatory (Yes/No)
properties_callback
obs_response_properties_callback *
Yes
Explanation:
The pointer to the response callback function. In this callback, you can record the content of obs_response_properties into callback_data (custom callback data).
Restrictions:
None
complete_callback
obs_response_complete_callback *
Yes
Explanation:
The pointer to the completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data).
Restrictions:
None
Table 14 obs_response_properties_callback
Type
Mandatory (Yes/No)
properties
const obs_response_properties*
Yes
Explanation:
Parameters in the response headers. You are advised to record them to callback_data (custom callback data).
Restrictions:
None
callback_data
void *
Yes
Explanation:
The pointer to the custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 15 obs_response_complete_callback
Type
Mandatory (Yes/No)
status
obs_status
Yes
Explanation:
Internal request status code of the SDK.
Restrictions:
None
Value range:
For details, see Table 19.
error_details
const obs_error_details*
Yes
Explanation:
Details about the request failure, including the error message and resource information. You are advised to record them in callback_data (custom callback data).
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 16 obs_response_properties
Type
Mandatory (Yes/No)
request_id
const char *
No
Explanation:
The value created by OBS to uniquely identify the request. OBS uses this value to locate the fault.
Restrictions:
None
Value range:
None
Default value:
None
request_id2
const char *
No
Explanation:
A special symbol that helps troubleshoot.
Restrictions:
None
Value range:
None
Default value:
None
content_type
const char *
No
Explanation:
MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Restrictions:
None
Value range:
None
Default value:
None
content_length
uint64_t
No
Explanation:
The size (in bytes) of the response body.
Restrictions:
None
Value range:
None
Default value:
None
server
const char *
No
Explanation:
Server header in an HTTP request.
Restrictions:
None
Value range:
None
Default value:
None
etag
const char *
No
Explanation:
Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
The value must contain 32 characters.
Default value:
None
expiration
const char *
No
Explanation:
Expiration details of the object.
Restrictions:
None
Value range:
Time string in ISO 8601 format, for example, Web, 7 Nov 2012 00:00:00 GMT
Default value:
None
website_redirect_location
const char *
No
Explanation:
Indicates where an object request is redirected. If the bucket that contains the object is configured with Website settings, this parameter can be set in the object metadata so that the request for the object can be redirected to another object in the same bucket or an external URL after the website returns a 301 redirect response.
To another object in the same bucket:
x-obs-website-redirect-location:/anotherPage.html
To an external URL:
x-obs-website-redirect-location:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection of objects that are in the root directory.
Value range:
None
Default value:
None
version_id
const char *
No
Explanation:
Object version ID.
Restrictions:
If the object has no version ID, the value is NULL.
Value range:
Default value:
None
meta_data_count
int
No
Explanation:
Number of elements in the meta_data array.
Restrictions:
None
Value range:
None
Default value:
None
meta_data
const obs_name_value *
No
Explanation:
Custom metadata of the object. You can add custom metadata headers that start with x-obs-meta- for easy object management. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response.
Restrictions:
None
use_server_side_encryption
char
No
Explanation:
If server-side encryption is enabled, this parameter is set to '\1'.
Restrictions:
None
Value range:
None
Default value:
None
allow_origin
const char *
No
Explanation:
Indicates that the origin is included in the response if the origin in the request meets the CORS configuration requirements on the server.
Restrictions:
None
Value range:
The value that complies with the CORS
Default value:
None
allow_headers
const char *
No
Explanation:
Indicates that the headers are included in the response if the headers in the request meet the CORS configuration requirements on the server.
Restrictions:
At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
Default value:
None
max_age
const char *
No
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can contain at most one MaxAgeSeconds.
Value range:
An integer greater than or equal to 0, in seconds.
Default value:
3000
allow_methods
const char *
No
Explanation:
Indicates that methods in the rule are included in the response if Access-Control-Request-Method in the request meets the CORS configuration requirements when CORS is configured for buckets.
Restrictions:
None
Value range:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
expose_headers
const char *
No
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies additional headers allowed in the response by a CORS rule. These headers provide extra information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them as additional headers.
Restrictions:
Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
None
Default value:
None
storage_class
const char *
No
Explanation:
Object storage class.
Restrictions:
This header is returned only when the storage class of an object is not Standard.
Value range:
  • WARM (Infrequent Access storage class)
  • COLD (Archive storage class)
Default value:
None
const char *
No
Explanation:
The encryption method used by the server.
Example: x-obs-server-side-encryption:kms
Restrictions:
This header is included in a response if SSE-KMS is used.
Value range:
  • kms (SSE-KMS encryption)
  • obs (SSE-OBS encryption)
Default value:
None
kms_key_id
const char *
No
Explanation:
Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required.
Restrictions:
This header can only be used when you specify kms for the server_side_encryption header.
Value range:
None
Default value:
If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it.
customer_algorithm
const char *
No
Explanation:
Indicates a decryption algorithm. This header is included in a response if SSE-C is used.
Restrictions:
None
Value range:
AES256 (AES256 decryption algorithm)
Default value:
None
customer_key_md5
const char *
No
Explanation:
Indicates the MD5 value of a key used to decrypt objects. This header is included in a response if SSE-C is used.
Restrictions:
Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Value range:
Base64-encoded MD5 value of the key ID.
Default value:
None
bucket_location
const char *
No
Explanation:
Indicates the region where the bucket resides.
Restrictions:
None
Value range:
None
Default value:
None
obs_version
const char *
No
Explanation:
OBS version of the bucket.
Restrictions:
None
Value range:
  • 3.0: bucket of the latest version
  • --: bucket of an earlier version
Default value:
None
restore
const char *
No
Explanation:
Restoration status of an object.
Examples: ongoing-request="true" (the object is being restored); ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" (the object has been restored) expiry-date indicates when the restored object will expire.
Restrictions:
For an Archive object that is being restored or has been restored, this header is returned.
Value range:
None
Default value:
None
obs_object_type
const char *
No
Explanation:
Type of the object.
Restrictions:
This header is returned only when the object is not a Normal object.
Value range:
Appendable
Default value:
None
obs_next_append_position
const char *
No
Explanation:
Indicates the position to be provided for the next request.
Restrictions:
This header is returned only when the object is an Appendable object.
Value range:
None
Default value:
None
obs_head_epid
const char *
No
Explanation:
Enterprise project ID for the current bucket. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service.
Restrictions:
The value is a UUID. This parameter is not required if you have not enabled an enterprise project.
Value range:
None
Default value:
None
reserved_indicator
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 17 obs_error_details
Type
message
const char*
Explanation:
Error details in the XML error response body.
Restrictions:
None
Value range:
See Error Codes.
Default value:
None
resource
const char*
Explanation:
Bucket or object related to the error.
Restrictions:
None
Value range:
None
Default value:
None
further_details
const char*
Explanation:
The value of the FurtherDetails element in the XML error response body.
Restrictions:
None
Value range:
None
Default value:
None
extra_details_count
int
Explanation:
The number of other elements in the XML error response body.
Restrictions:
None
Value range:
None
Default value:
None
extra_details
obs_name_value*
Explanation:
Values of other elements in the XML error response body.
Restrictions:
None
error_headers_count
int
Explanation:
Number of headers in error_headers.
Restrictions:
None
Value range:
None
Default value:
None
error_headers
char**
Explanation:
All response headers that contain the error.
Restrictions:
None
Value range:
None
Default value:
None
Table 18 obs_name_value
Type
Mandatory (Yes/No)
name
char *
No
Explanation:
Key of a property.
Restrictions:
None
Value range:
None
Default value:
None
value
char *
No
Explanation:
Property value.
Restrictions:
None
Value range:
None
Default value:
None
Table 19 obs_status
Constant
Original Value
OBS_STATUS_OK
0
The request is successful.
OBS_STATUS_InitCurlFailed
Failed to initialize curl.
OBS_STATUS_InternalError
2
Internal error.
OBS_STATUS_OutOfMemory
3
The local memory is insufficient.
OBS_STATUS_FailedToIInitializeRequest
6
Failed to initialize the request.
OBS_STATUS_XmlParseFailure
23
Failed to parse the XML file.
OBS_STATUS_NameLookupError
33
Domain name resolution failed.
OBS_STATUS_FailedToConnect
34
Failed to connect to the server.
OBS_STATUS_ConnectionFailed
36
Network connection failed.
OBS_STATUS_PartialFile
38
Network transmission interrupted.
OBS_STATUS_InvalidParameter
39
Invalid parameter.
OBS_STATUS_NoToken
40
The current number of concurrent tasks exceeds the upper limit (1,000 by default). The token here refers to the concurrent request token, not the security authentication token. You can use the set_online_request_max_count function to adjust the maximum number of concurrent tasks.
OBS_STATUS_OpenFileFailed
41
Failed to open the file.
OBS_STATUS_AccessDenied
43
The request is rejected.
OBS_STATUS_MalformedPolicy
44
The format of the request policy is incorrect.
OBS_STATUS_MalformedXML
45
The XML request format is incorrect.
OBS_STATUS_MethodNotAllowed
46
The request method is not allowed.
OBS_STATUS_SignatureDoesNotMatch
47
The signatures do not match. Check whether the AK, SK, and token are correct.
OBS_STATUS_ServiceUnavailable
48
Server exception.
OBS_STATUS_SlowDown
49
The request frequency is too high.
Table 20 obs_object_info
Type
Mandatory (Yes/No)
key
char *
Yes
Explanation:
Object name
Restrictions:
None
Value range:
None
Default value:
None
version_id
char *
No
Explanation:
Object version ID. If the object is not a versioned object, set version_id to NULL.
Restrictions:
None
Value range:
None
Default value:
None
Table 21 obs_put_properties
Type
Mandatory (Yes/No)
content_type
char *
Yes
Explanation:
It specifies the file type of an object when it is downloaded.
Restrictions:
None
Value range:
See the Content-Type values defined in HTTP.
Default value:
None
md5
char *
Yes
Explanation:
Indicates the base64-encoded digest of the object data. It is provided for the OBS server to verify data integrity. The OBS server will compare this MD5 value with the MD5 value calculated based on the object data. If the two values are not the same, HTTP status code 400 is returned.
Restrictions:
The MD5 value of the object must be Base64 encoded. If the MD5 value is not specified, the OBS server will not verify the MD5 value of the object.
Value range:
Base64-encoded 128-bit MD5 value of the request body calculated according to RFC 1864.
Example: n58IG6hfM7vqI4K0vnWpog==
Default value:
None
cache_control
char *
Yes
Explanation:
It specifies the cache behavior of the web page when an object is downloaded.
Restrictions:
None
Value range:
See the Cache-Control values defined in HTTP.
Default value:
None
content_disposition_filename
char *
Yes
Explanation:
It specifies the name of an object when it is downloaded. For example, if the value is set to test.txt, that is equivalent to adding the Content-Disposition: attachment; filename=test.txt header.
Restrictions:
None
Value range:
See the Content-Disposition values defined in HTTP.
Default value:
None
content_encoding
char *
Yes
Explanation:
It specifies the content encoding format when an object is downloaded.
Restrictions:
None
Value range:
See the Content-Encoding values defined in HTTP.
Default value:
None
char *
Yes
Explanation:
If the bucket is configured with website hosting, the request for obtaining the object can be redirected to another object in the bucket or an external URL.
To an external URL:
Restrictions:
Value range:
None
Default value:
None
get_conditions
obs_get_conditions *
No
Explanation:
Prerequisites and a set of behavior parameters for operations such as uploading, copying, and downloading objects.
Restrictions:
None
start_byte
uint64_t
No
Explanation:
Where the copy starts in the object
Restrictions:
None
Value range:
0 (included) to the object length minus 1 (not included), in bytes
Default value:
0 (The copy starts from the first byte of the object.)
byte_count
uint64_t
No
Explanation:
Specifies the copy length.
Restrictions:
  • Value: an integer greater than 0
  • If the sum of start_byte and byte_count is greater than the object length minus 1, the object length minus 1 is used. The unit is byte.
Value range:
None
Default value:
None
upload_limit
uint64_t
No
Explanation:
Bandwidth limit for single connection requests.
Restrictions:
None
Value range:
819200 to 838860800, in bit/s
Default value:
None
expires
int64_t
No
Explanation:
Value of the Expires header in the OBS request. It specifies the cache expiration time of the web page when the object is downloaded.
Restrictions:
None
Value range:
None
Default value:
None
obs_expires
int64_t
No
Explanation:
Specifies when an object expires. It is measured in days. Once the object expires, it is automatically deleted.
Restrictions:
The value must be greater than the number of days that have passed since the object was created. For example, if the object was uploaded 10 days ago, you must specify a value greater than 10.
Value range:
The value is an integer greater than 0.
Default value:
None
canned_acl
obs_canned_acl
No
Explanation:
Access control policy
Restrictions:
None
Value range:
For details, see Table 22.
az_redundancy
obs_az_redundancy
No
Explanation:
Data redundancy type that can be specified during bucket creation.
Restrictions:
None
Value range:
meta_data_count
int
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
meta_data
obs_name_value*
No
Explanation:
Custom metadata of the object. OBS allows you to use custom metadata to manage objects. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response.
Restrictions:
  • If a request carries this header field, the response message must contain this header field.
  • The total size of all custom metadata cannot exceed 8 KB. To measure the size, calculate the sum of bytes of all UTF-8 encoded keys and values.
  • The custom metadata keys are case-insensitive, but are stored in lowercase by OBS. The key values are case-sensitive.
  • Both custom metadata keys and their values must conform to US-ASCII standards. If non-ASCII or unrecognizable characters are required, they must be encoded and decoded in URL or Base64 on the client, because the server does not perform such operations.
metadata_action
metadata_action_indicator
No
Explanation:
Metadata operation directive.
Restrictions:
None
Value range:
For details, see Table 24.
server_callback
obs_upload_file_server_callback
No
Explanation:
Parameters related to server callback.
Restrictions:
None
Table 22 obs_canned_acl
Constant
Original Value
OBS_CANNED_ACL_PRIVATE
private
Private read and write. A bucket or object can only be accessed by its owner.
OBS_CANNED_ACL_PUBLIC_READ
public-read
Public read and private write. If this permission is granted for a bucket, anyone can read the object list, multipart uploads, bucket metadata, and object versions in the bucket. If this permission is granted for an object, everyone can obtain the content and metadata of the object.
OBS_CANNED_ACL_PUBLIC_READ_WRITE
public-read-write
Public read and write. If this permission is granted for a bucket, everyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart uploads. If this permission is granted for an object, everyone can obtain the content and metadata of the object.
OBS_CANNED_ACL_BUCKET_OWNER_FULL_CONTROL
bucket-owner-full-control
If this permission is granted for an object, only the bucket and object owners have the full control over the object. By default, if you upload an object to a bucket of any other user, the bucket owner does not have the permissions on your object. After you grant this permission to the bucket owner, the bucket owner can have full control over your object. For example, if user A uploads object x to user B's bucket, user B does not have the control over object x. If user A sets bucket-owner-full-control for object x, user B then has the control over object x. This permission is supported only by S3 APIs.
OBS_CANNED_ACL_PUBLIC_READ_DELIVERED
public-read-delivered
Public read on a bucket and its objects. If this permission is granted for a bucket, everyone can read the object list, multipart uploads, and bucket metadata, and can also read the content and metadata of the objects in the bucket. This permission cannot be granted for objects.
OBS_CANNED_ACL_PUBLIC_READ_WRITE_DELIVERED
public-read-write-delivered
Public read and write on a bucket and its objects. If this permission is granted for a bucket, everyone can read the object list, multipart uploads, and bucket metadata, and can upload or delete objects, initiate multipart uploads, upload parts, assemble parts, copy parts, and abort multipart uploads. They can also read the content and metadata of the objects in the bucket. This permission cannot be granted for objects.
Table 23 obs_get_conditions
Type
Mandatory (Yes/No)
start_byte
uint64_t
No
Explanation:
Start position for object download.
Restrictions:
None
Value range:
Default value:
0 (indicating that the download starts from the first byte of the object)
byte_count
uint64_t
No
Explanation:
Specifies the length to be downloaded.
Restrictions:
Value range:
None
Default value:
None
download_limit
uint64_t
No
Explanation:
Restrictions:
None
Value range:
Default value:
None
if_modified_since
int64_t
No
Explanation:
The request succeeds if the object has been modified since the specified time; otherwise, an error is returned.
Restrictions:
None
Value range:
None
Default value:
None
if_not_modified_since
int64_t
No
Explanation:
The request succeeds if the object has not been modified since the specified time; otherwise, an error is returned.
Restrictions:
None
Value range:
None
Default value:
None
if_match_etag
char *
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded or copied is the same as the preset ETag, the request succeeds. Otherwise, an error is returned.
Restrictions:
None
Value range:
Default value:
None
if_not_match_etag
char *
No
Explanation:
Preset ETag. If the ETag of the object to be downloaded or copied is different from the preset ETag, the request succeeds. Otherwise, an error is returned.
Restrictions:
None
Value range:
Default value:
None
image_process_config
image_process_configure *
No
Explanation:
Image processing parameters.
Restrictions:
None
Table 24 metadata_action_indicator
Constant
Original Value
OBS_NO_METADATA_ACTION
Default invalid value.
OBS_REPLACE
REPLACE
Uses the complete header carried in the current request to replace the original one and deletes the metadata that is not specified.
OBS_REPLACE_NEW
REPLACE_NEW
The metadata that has an existing value is replaced. A value is assigned to the metadata that does not have a value. The metadata that is not specified remains unchanged. Custom metadata is replaced.
Table 25 obs_upload_file_server_callback
Type
Mandatory (Yes/No)
callback_url
char *
Yes
Explanation:
After an object is uploaded successfully, OBS sends a callback request to the URL using the POST method.
You can specify a maximum of 10 URLs. Use semicolons (;) to separate URLs.
URL-encoding is required.
Restrictions:
None
Value range:
None
Default value:
None
callback_host
char *
No
Explanation:
Value of the host header in the callback request. If this parameter is not specified, the value of host parsed from the callbackUrl parameter is used.
Restrictions:
None
Value range:
None
Default value:
None
callback_body_type
char *
No
Explanation:
Value of the Content-Type header in the callback request.
Restrictions:
None
Value range:
  • application/x-www-form-urlencoded
  • application/json
Default value:
If no value is specified, the default value application/json is used.
Table 26 image_process_configure
Type
Mandatory (Yes/No)
image_process_mode
image_process_mode_type
No
Explanation:
Restrictions:
None
Value range:
For details, see Table 27.
cmds_stylename
char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 27 image_process_mode_type
Constant
Original Value
obs_image_process_invalid_mode
obs_image_process_cmd
Image processing parameters start with image.
obs_image_process_style
style
Image processing parameters start with style.
Table 28 obs_delete_object_data_callback
Type
Mandatory (Yes/No)
contents_count
int
Yes
Explanation:
Length of the buffer.
Restrictions:
None
Value range:
None
Default value:
None
contents
obs_delete_objects *
Yes
Explanation:
Buffer for storing the data to be uploaded. The data to be uploaded is copied to this buffer.
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 29 obs_delete_objects
Type
Mandatory (Yes/No)
key
constchar*
Yes
Explanation:
Each object name in the deletion result. An object name is a complete path that does not contain the bucket name.
For example, if the access path is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Restrictions:
The name of each object in a bucket must be unique.
Value range:
The value can contain 1 to 1,024 characters.
Default value:
None
code
constchar*
No
Explanation:
Error code of a deletion failure.
Restrictions:
None
Value range:
None
Default value:
None
message
constchar*
No
Explanation:
Error message of a deletion failure.
Restrictions:
None
Value range:
None
Default value:
None
delete_marker
constchar*
No
Explanation:
OBS returns true for this parameter in the response when a delete marker is created or deleted for a versioning-enabled bucket.
Restrictions:
None
Value range:
None
Default value:
None
delete_marker_version_id
constchar*
No
Explanation:
Version ID of a delete marker to create or delete.
OBS returns this element in the response when a delete marker is created or deleted for a versioning-enabled bucket. This element will be returned in either of the following cases:
  • You send a delete request specifying an object's name without providing a version ID. In this case, OBS creates a delete marker and returns its version ID in the response.
  • You send a delete request specifying both an object's name and its version ID, but this version ID points to a delete marker. In this case, OBS deletes the delete marker and returns its version ID in the response.
Restrictions:
None
Value range:
None
Default value:
None
Code Examples: Batch Deleting Objects
This example calls batch_delete_objects to delete multiple objects.
  3
  4
  5
  6
  7
  8
  9
 10
 11
 12
 13
 14
 15
 16
 17
 18
 19
 20
 21
 22
 23
 24
 25
 26
 27
 28
 29
 30
 31
 32
 33
 34
 35
 36
 37
 38
 39
 40
 41
 42
 43
 44
 45
 46
 47
 48
 49
 50
 51
 52
 53
 54
 55
 56
 57
 58
 59
 60
 61
 62
 63
 64
 65
 66
 67
 68
 69
 70
 71
 72
 73
 74
 75
 76
 77
 78
 79
 80
 81
 82
 83
 84
 85
 86
 87
 88
 89
 90
 91
 92
 93
 94
 95
 96
 97
 98
 99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
158
159
160
161
162
#include "eSDKOBS.h"
#include <stdio.h>
#include <sys/stat.h>
// The response callback function. In this callback, you can record the content of properties into callback_data (custom callback data).
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
void response_complete_callback(obs_status status,
    const obs_error_details *error,
obs_status delete_objects_data_callback(int contentsCount,
    obs_delete_objects *delobjs,
    void *callbackData);
int main()
    // The following code shows how to use batch_delete_objects to delete multiple objects:
    // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory.
    obs_status ret_status = obs_initialize(OBS_INIT_ALL);
    if (OBS_STATUS_OK != ret_status)
        printf("obs_initialize failed(%s).\n", obs_get_status_name(ret_status));
        return -1;
    obs_options options;
    // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class).
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Specify the bucket name, for example, example-bucket-name.
    char * bucket_name = "example-bucket-name";
    options.bucket_options.bucket_name = bucket_name;
    // Information about the objects to be deleted in a batch.
    obs_object_info objectinfo[100];
    objectinfo[0].key = "example_get_file_test_delete1";
    objectinfo[0].version_id = NULL;
    objectinfo[1].key = "example_get_file_test_delete2";
    objectinfo[1].version_id = "versionid2";
    obs_delete_object_info delobj;
    memset(&delobj, 0, sizeof(obs_delete_object_info));
    delobj.keys_number = 2;
    // Set the response callback function.
    obs_delete_object_handler handler =
        {&response_properties_callback, &response_complete_callback},
        &delete_objects_data_callback
    ret_status = OBS_STATUS_BUTT;
    // Delete the objects in a batch.
    batch_delete_objects(&options, objectinfo, &delobj, 0, &handler, &ret_status);
    if (OBS_STATUS_OK == ret_status) {
        printf("test batch_delete_objects successfully. \n");
    else
        printf("test batch_delete_objects failed(%s).\n", obs_get_status_name(ret_status));
    // Release the allocated global resources.
    obs_deinitialize();
    void *callbackData)
    int i;
    for (i = 0; i < contentsCount; i++) {
        const obs_delete_objects*content = &(delobjs[i]);
        printf("delete object result:\nobject key:%s\nerror code:%s\nerror message:%s\ndelete marker:%s\ndelete marker version_id:%s\n",
                content->key, content->code, content->message, content->delete_marker, content->delete_marker_version_id);
    return OBS_STATUS_OK;
    if (properties == NULL)
        printf("error! obs_response_properties is null!");
    // Print the response.
#define print_nonnull(name, field)                                 \
    do {                                                           \
        if (properties-> field) {                                  \
            printf("%s: %s\n", name, properties->field);          \
    } while (0)
    print_nonnull("request_id", request_id);
    print_nonnull("request_id2", request_id2);
    print_nonnull("content_type", content_type);
    if (properties->content_length) {
        printf("content_length: %llu\n", properties->content_length);
    print_nonnull("server", server);
    print_nonnull("ETag", etag);
    print_nonnull("expiration", expiration);
    print_nonnull("website_redirect_location", website_redirect_location);
    print_nonnull("version_id", version_id);
    print_nonnull("allow_origin", allow_origin);
    print_nonnull("allow_headers", allow_headers);
    print_nonnull("max_age", max_age);
    print_nonnull("allow_methods", allow_methods);
    print_nonnull("expose_headers", expose_headers);
    print_nonnull("storage_class", storage_class);
    print_nonnull("server_side_encryption", server_side_encryption);
    print_nonnull("kms_key_id", kms_key_id);
    print_nonnull("customer_algorithm", customer_algorithm);
    print_nonnull("customer_key_md5", customer_key_md5);
    print_nonnull("bucket_location", bucket_location);
    print_nonnull("obs_version", obs_version);
    print_nonnull("restore", restore);
    print_nonnull("obs_object_type", obs_object_type);
    print_nonnull("obs_next_append_position", obs_next_append_position);
    print_nonnull("obs_head_epid", obs_head_epid);
    print_nonnull("reserved_indicator", reserved_indicator);
    int i;
    for (i = 0; i < properties->meta_data_count; i++) {
        printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name,
            properties->meta_data[i].value);
void print_error_details(const obs_error_details *error) {
    if (error && error->message) {
        printf("Error Message: \n   %s\n", error->message);
    if (error && error->resource) {
        printf("Error Resource: \n  %s\n", error->resource);
    if (error && error->further_details) {
        printf("Error further_details: \n   %s\n", error->further_details);
    if (error && error->extra_details_count) {
        int i;
        for (i = 0; i < error->extra_details_count; i++) {
            printf("Error Extra Detail(%d):\n   %s:%s\n", i, error->extra_details[i].name,
                error->extra_details[i].value);
    if (error && error->error_headers_count) {
        int i;
        for (i = 0; i < error->error_headers_count; i++) {
            const char *errorHeader = error->error_headers[i];
            printf("Error Headers(%d):\n    %s\n", i, errorHeader == NULL ? "NULL Header" : errorHeader);
    if (callback_data)
        obs_status *ret_status = (obs_status *)callback_data;
        *ret_status = status;
    else {
        printf("Callback_data is NULL");
    print_error_details(error);
