Invalid Proxy Settings (SDK for C)
- When the proxy is configured in a Windows SDK demo, the program reports the following error and the proxy configuration fails.
Root cause: Due to asynchronous updates, the demo header file eSDKOBS.h of certain SDK versions diverges from the SDK eSDKOBS.h, rendering the proxy settings in the option invalid.
Solution:
- Replace yourSDKpath\source\eSDK_OBS_API\eSDK_OBS_API_C++\inc\eSDKOBS.h with yourSDKpath\source\eSDK_OBS_API\eSDK_OBS_API_C++\build\obs\demo\eSDKOBS.h.
- Modify the demo as instructed here to adapt to the changes of eSDKOBS.h. (The adaptation of version 3.22.7 is used as an example. The adaptation process of other versions may differ.)
In the yourSDKpath\source\eSDK_OBS_API\eSDK_OBS_API_C++\build\obs\demo\ demo_windows.cpp file, in line 4749, add obs_upload_file_server_callback server_callback; in line 4750, add , server_callback after the fourth parameter in the upload_file function. See the following figure.
- The proxy is configured but the connection still fails.
Root cause: The proxy might not be configured in the get_api_version function of the SDK request.c.
Solution:
Configure the proxy (add the CURLOPT_PROXY and CURLOPT_PROXYUSERPWD items for curl) in the get_api_version function by referring to the method for configuring the proxy in the setup_curl function of the SDK request.c.
