Viewing Event Notification Settings (SDK for C)
You can call get_notification_configuration to view event notification settings of a bucket.
Method
void get_notification_configuration(const obs_options *options,
obs_smn_handler *handler, void *callback_data); Parameter Description
| Field | Type | Mandatory or Optional | Description |
| options | Request for the context of the bucket, see Configuring option (SDK for C) | Mandatory | Bucket parameter |
| handler | obs_smn_handler * | Mandatory | Callback function |
| callback_data | void * | Optional | Callback data |
The following table describes the callback function types of obs_smn_handler.
| Field | Type | Description |
| response_handler | obs_response_handler | Callback function handler for response |
| get_smn_callback_func | obs_smn_callback * | Callback function for obtaining the notification configuration of a bucket |
Code Examples
static void test_get_notification_configuration()
obs_options option;
obs_status ret_status = OBS_STATUS_BUTT;
// Set option.
init_obs_options(&option);
option->bucket_options.hostName = "<your-endpoint>";
option->bucket_options.bucketName = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
// Set callback function.
obs_smn_handler notification_handler_info =
{&response_properties_callback, &response_complete_callback},
&get_notification_info_callback
get_notification_configuration(&option, ¬ification_handler_info, &ret_status);
if (OBS_STATUS_OK == ret_status) {
printf("get_notification_config success.\n");
else {
printf("get_notification_config failed(%s).\n", obs_get_status_name(ret_status));
} What is your overall rating for this page?
