Setting Event Notifications (SDK for C)
You can call set_notification_configuration to set event notifications for a bucket.
Method
void set_notification_configuration(const obs_options *options,
obs_smn_notification_configuration* notification_conf, obs_response_handler *handler,
void *callback_data); Parameter Description
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | The context of the bucket request. For details, see Configuring option (SDK for C). | Mandatory | Bucket parameter |
| notification_conf | obs_smn_notification_configuration* | Mandatory | Indicates the container for configuring the event notification. |
| handler | obs_response_handler * | Mandatory | Callback function |
| callback_data | void * | Optional | Callback data |
The following table describes the parameter obs_smn_notification_configuration.
| Parameter | Type | Mandatory (Yes/No) Description |
| topic_conf | obs_smn_topic_configuration* | Container for configuring the event notification topic |
| topic_conf_num | unsigned int | Number of topic_conf |
The following table describes the parameter obs_smn_topic_configuration.
| topic | char * | URN of the event notification topic. After detecting a specific event in the bucket, OBS sends a message to the topic. |
| id | char * | Unique ID of each event notification. If no ID is specified, the system automatically assigns one. |
| filter_rule | obs_smn_filter_rule * | Container that defines key-value pairs of filter rules |
| filter_rule_num | unsigned int | Number of filter_rule |
| event | obs_smn_event_enum* | Type of events that need to be notified |
| event_num | unsigned int | Number of event types |
Code Examples
static void test_set_notification_configuration()
obs_options option;
obs_status ret_status = OBS_STATUS_BUTT;
obs_smn_notification_configuration notification_conf;
obs_smn_topic_configuration topic_conf;
obs_smn_event_enum topic1_event[2];
obs_smn_filter_rule filter_rule;
// Set option.
init_obs_options(&option);
option->bucket_options.hostName = "<your-endpoint>";
option->bucket_options.bucketName = "<Your bucketname>";
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
option.bucket_options.access_key = getenv("ACCESS_KEY_ID");
option.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
// Set callback function.
obs_response_handler response_handler =
NULL, &response_complete_callback
// Set the unique ID of the notification configuration.
topic_conf.id = "Id001";
// Set the URN of the event notification topic.
topic_conf.topic = "urn:smn:southchina:ea79855fbe0642718cb4df1551c3cb4e:test_cwx298983";
// Set the event types for notification.
topic_conf.event = topic1_event;
topic_conf.event[0] = SMN_EVENT_OBJECT_CREATED_ALL;
topic_conf.event[1] = SMN_EVENT_OBJECT_CREATED_POST;
topic_conf.event_num = 2;
// Set filtering rules for notification objects.
filter_rule.name = OBS_SMN_FILTER_PREFIX;
filter_rule.value = "aaa";
topic_conf.filter_rule = &filter_rule;
topic_conf.filter_rule_num = 1;
memset(¬ification_conf, 0, sizeof(obs_smn_notification_configuration));
notification_conf.topic_conf = &topic_conf;
notification_conf.topic_conf_num = 1;
set_notification_configuration(&option, ¬ification_conf, &response_handler, &ret_status);
if (OBS_STATUS_OK == ret_status) {
printf("set_notification_configuration success.\n");
else {
printf("set_notification_configuration failed(%s).\n",
obs_get_status_name(ret_status));
} Feedback
