Help Center/Object Storage Service/SDK Reference/C/Lifecycle Management (SDK for C)/Configuring Lifecycle Rules for a Bucket (SDK for C)
Updated on 2025-10-21 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub.
Function
You can configure lifecycle rules to periodically delete objects or transition objects between storage classes. For more information, see Lifecycle Management.
This API configures lifecycle rules for a bucket.
Restrictions
  • There is no limit on the number of lifecycle rules in a bucket, but the total size of XML descriptions of all lifecycle rules in a bucket cannot exceed 20 KB.
  • A maximum of 20 lifecycle rules can be configured for a bucket.
  • To configure a lifecycle rule for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutLifecycleConfiguration in IAM or PutLifecycleConfiguration in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
  • The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
  • Expired objects will be permanently deleted and cannot be restored.
  • Multi-AZ redundancy is not available for Archive storage. For this reason, buckets or objects with multi-AZ redundancy cannot be transitioned to the Archive storage class based on a lifecycle rule.
  • The minimum storage duration is 30 days for Infrequent Access storage and 90 days for Archive storage. After an object is transitioned to the Archive storage class, if it stays in this storage class for less than 90 days, you still need to pay for a full 90 days.
Method
void set_bucket_lifecycle_configuration(const obs_options *options,
           obs_lifecycle_conf* bucket_lifecycle_conf, unsigned int blcc_number,
           obs_response_handler *handler, void *callback_data);
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options*
Yes
Explanation:
The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options.
Restrictions:
None
obs_lifecycle_conf *
Yes
Explanation:
For details about the bucket lifecycle configuration, see the following table.
Restrictions:
None
blcc_number
unsigned int
Yes
Explanation:
Number of array members in the array bucket_lifecycle_conf.
Restrictions:
None
Value range:
None
Default value:
None
handler
Yes
Explanation:
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data.
Restrictions:
None
callback_data
void *
No
Explanation:
Custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 2 obs_options
Type
Mandatory (Yes/No)
bucket_options
obs_bucket_context
Yes
Explanation:
Bucket settings.
Restrictions:
None
request_options
obs_http_request_option
Yes
Explanation:
Request-related settings.
Restrictions:
None
temp_auth
temp_auth_configure*
No
Explanation:
The structure used to calculate a temporary signature. Set it to NULL if it is not used.
Restrictions:
None
Table 3 obs_bucket_context
Type
Mandatory (Yes/No)
host_name
char *
Yes
Explanation:
The requested host name, used as an address for connecting to OBS. It is the domain name (the endpoint) of the server where the requested resource is stored.
Example: host_name ="obs.ap-southeast-1.myhuaweicloud.com";
Restrictions:
The value does not need to contain http:// or https:// as a prefix, which is controlled using obs_protocol.
Value range:
To view the endpoints available for OBS, see Regions and Endpoints.
Default value:
None
bucket_name
char *
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets with the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Value range:
None
Default value:
None
useCname
bool
No
Explanation:
Whether to use a custom domain name to access OBS.
Restrictions:
None
Value range:
true: A custom domain name is used.
false: A custom domain name is not used.
Default value:
false
protocol
obs_protocol
No
Explanation:
Whether to use the HTTP or HTTPS protocol.
Restrictions:
None
Value range:
For details, see obs_protocol.
Default value:
OBS_PROTOCOL_HTTPS (HTTPS is used by default.)
access_key
char *
Yes
Explanation:
Access key ID (AK).
Restrictions:
None
Value range:
For details, see Creating Access Keys.
Default value:
None
secret_access_key
char *
Yes
Explanation:
Secret access key (SK).
Restrictions:
None
Value range:
Default value:
None
storage_class
obs_storage_class
No
Explanation:
Bucket storage class that can be specified at bucket creation.
Restrictions:
None
Value range:
For details, see obs_storage_class.
Default value:
Standard storage class
token
char *
No
Explanation:
The security token in temporary credentials.
Restrictions:
None
Value range:
Default value:
None
epid
char *
No
Explanation:
Enterprise project ID that can be specified during bucket creation. If you have enabled EPS, you can obtain the project ID from the EPS console.
Restrictions:
The value needs to be represented as a UUID. This parameter is not required if EPS is not enabled.
Example: 9892d768-2d13-450f-aac7-ed0e44c2585f
Default value:
None
bucket_type
obs_bucket_type
No
Explanation:
Whether a bucket is an object bucket or a parallel file system.
Restrictions:
None
Value range:
For details, see obs_bucket_type.
Default value:
OBS_BUCKET_OBJECT (object bucket)
bucket_list_type
obs_bucket_list_type
No
Explanation:
Whether to list all buckets, object buckets, or parallel file systems.
Restrictions:
None
Value range:
For details, see obs_bucket_list_type.
Table 4 obs_storage_class
Value
OBS_STORAGE_CLASS_STANDARD
Standard storage class.
This class features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response.
OBS_STORAGE_CLASS_STANDARD_IA
Infrequent Access storage class.
Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed.
OBS_STORAGE_CLASS_GLACIER
Archive storage class.
Used for storing rarely accessed (once a year) data.
Table 5 obs_http_request_option
Type
Mandatory (Yes/No)
connect_time
int
Yes
Explanation:
Timeout period for establishing an HTTP/HTTPS connection, in ms.
Restrictions:
None
Value range:
[10000, 60000]
Default value:
60000
max_connected_time
int
Yes
Explanation:
Timeout period (in seconds) of a request.
Restrictions:
None
Value range:
None
Default value:
0 (There is never automatic disconnection.)
proxy_auth
char*
No
Explanation:
Proxy authentication information, in the format username:password
Restrictions:
None
Value range:
None
Default value:
None
proxy_host
char*
No
Explanation:
IP address or host name of the proxy server.
Restrictions:
None
Value range:
None
Default value:
None
Table 6 obs_protocol
Value
OBS_PROTOCOL_HTTPS
HTTPS is used for access.
OBS_PROTOCOL_HTTP
HTTP is used for access.
Table 7 obs_bucket_type
Value
OBS_BUCKET_OBJECT
Object bucket
OBS_BUCKET_PFS
Parallel file system
Table 8 obs_bucket_list_type
Value
OBS_BUCKET_LIST_ALL
Lists all buckets.
OBS_BUCKET_LIST_OBJECT
Lists all object buckets.
OBS_BUCKET_LIST_PFS
Lists all parallel file systems.
Table 9 temp_auth_configure
Type
Mandatory (Yes/No)
expires
long long int
Yes
Explanation:
Validity period of the temporary credentials, in seconds.
Restrictions:
None
Value range:
[0-630720000]
Default value:
None
temp_auth_callback
void(*temp_auth_callback)(char *temp_auth_url,
uint64_t temp_auth_url_len,
char*temp_auth_headers,
uint64_t temp_auth_headers_len,
void*callback_data)
Yes
Explanation:
The pointer to the custom callback function, which is used to record the temporary URL and involved signature header to the custom callback data.
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 10 temp_auth_callback
Type
Mandatory (Yes/No)
temp_auth_url
char *
Yes
Explanation:
Temporary URL. OBS allows you to construct a URL for a specific operation. In such a URL, you use Query parameters to provide authentication information including the user AK, signature, and validity period. Anyone who has the URL can perform the specified operation. After receiving a request made using such a URL, OBS treats the requester as the user who issued the URL and processes the request. For example, if you construct a pre-signed URL for downloading an object and provide it to various users, they can use the URL to download the object without authentication, but they must do so within the validity period specified by the Expires parameter.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_url_len
uint64_t
Yes
Explanation:
Length of the temporary URL.
Restrictions:
None
Value range:
None
Default value:
None
temp_auth_headers
char *
Yes
Explanation:
Headers for temporary authentication.
Restrictions:
None
Value range:
None
Default value:
None
uint64_t
Yes
Explanation:
Number of temporary authentication headers.
Restrictions:
None
Value range:
None
Default value:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 11 obs_response_handler
Type
Mandatory (Yes/No)
properties_callback
obs_response_properties_callback *
Yes
Explanation:
The pointer to the response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data).
Restrictions:
None
complete_callback
obs_response_complete_callback *
Yes
Explanation:
The pointer to the completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data).
Restrictions:
None
Table 12 obs_response_properties_callback
Type
Mandatory (Yes/No)
properties
const obs_response_properties*
Yes
Explanation:
Parameters in the response headers. You are advised to record them to callback_data (custom callback data).
Restrictions:
None
callback_data
void *
Yes
Explanation:
The pointer to the custom callback data.
Restrictions:
None
Value range:
None
Default value:
None
Table 13 obs_response_complete_callback
Type
Mandatory (Yes/No)
status
obs_status
Yes
Explanation:
Internal request status code of the SDK.
Restrictions:
None
Value range:
For details, see obs_status.
error_details
const obs_error_details*
Yes
Explanation:
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 14 obs_response_properties
Type
Mandatory (Yes/No)
request_id
const char *
No
Explanation:
The value created by OBS to uniquely identify the request. OBS uses this value to locate the fault.
Restrictions:
None
Value range:
None
Default value:
None
request_id2
const char *
No
Explanation:
A special symbol that helps troubleshoot.
Restrictions:
None
Value range:
None
Default value:
None
content_type
const char *
No
Explanation:
MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data.
Restrictions:
None
Value range:
None
Default value:
None
content_length
uint64_t
No
Explanation:
The size (in bytes) of the response body.
Restrictions:
None
Value range:
None
Default value:
None
server
const char *
No
Explanation:
Server header in an HTTP request.
Restrictions:
None
Value range:
None
Default value:
None
etag
const char *
No
Explanation:
Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag.
Restrictions:
If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object.
Value range:
The value must contain 32 characters.
Default value:
None
expiration
const char *
No
Explanation:
Expiration details of the object.
Restrictions:
None
Value range:
An integer greater than 0, in days.
Default value:
None
website_redirect_location
const char *
No
Explanation:
Indicates where an object request is redirected. If the bucket that contains the object is configured with Website settings, this parameter can be set in the object metadata so that the request for the object can be redirected to another object in the same bucket or an external URL after the website returns a 301 redirect response.
To another object in the same bucket:
x-obs-website-redirect-location:/anotherPage.html
To an external URL:
x-obs-website-redirect-location:http://www.example.com/
OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation.
Restrictions:
  • The value must start with a slash (/), http://, or https:// and cannot exceed 2 KB.
  • OBS only supports redirection of objects that are in the root directory.
Value range:
None
Default value:
None
version_id
const char *
No
Explanation:
Object version ID.
Restrictions:
If the object has no version ID, the value is NULL.
Value range:
Default value:
None
meta_data_count
int
No
Explanation:
Number of elements in the meta_data array.
Restrictions:
None
Value range:
None
Default value:
None
meta_data
const obs_name_value *
No
Explanation:
Custom metadata of the object. You can add custom metadata headers that start with x-obs-meta- for easy object management. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response.
Restrictions:
None
Value range:
None
Default value:
None
use_server_side_encryption
char
No
Explanation:
If server-side encryption is enabled, this parameter is set to '\1'.
Restrictions:
None
Value range:
None
Default value:
None
allow_origin
const char *
No
Explanation:
Returned if the request origin meets the CORS configured on the server.
Restrictions:
None
Value range:
The value that complies with the CORS
Default value:
None
allow_headers
const char *
No
Explanation:
Returned if the request headers meet the CORS configured on the server.
Restrictions:
At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
Default value:
None
max_age
const char *
No
Explanation:
MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request.
Restrictions:
Each CORS rule can contain at most one MaxAgeSeconds.
Value range:
An integer greater than or equal to 0, in seconds.
Default value:
3000
allow_methods
const char *
No
Explanation:
Indicates that methods in the rule are included in the response if Access-Control-Request-Method in the request meets the CORS configuration requirements when CORS is configured for buckets.
Restrictions:
None
Value range:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Value range:
None
expose_headers
const char *
No
Explanation:
ExposeHeader in the CORS rules of the bucket. It specifies additional headers allowed in the response by a CORS rule. These headers provide extra information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them as additional headers.
Restrictions:
Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
None
Default value:
None
storage_class
const char *
No
Explanation:
Object storage class.
Restrictions:
This header is returned only when the storage class of an object is not Standard.
Value range:
  • WARM (Infrequent Access storage class)
  • COLD (Archive storage class)
Default value:
None
const char *
No
Explanation:
The encryption method used by the server.
Example: x-obs-server-side-encryption:kms
Restrictions:
This header is included in a response if SSE-KMS is used.
Value range:
  • kms (SSE-KMS encryption)
  • obs (SSE-OBS encryption)
Default value:
None
kms_key_id
const char *
No
Explanation:
Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required.
Restrictions:
This header can only be used when you specify kms for the server_side_encryption header.
Value range:
None
Default value:
If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it.
customer_algorithm
const char *
No
Explanation:
Indicates a decryption algorithm. This header is included in a response if SSE-C is used.
Restrictions:
None
Value range:
AES256 (AES256 decryption algorithm)
Default value:
None
customer_key_md5
const char *
No
Explanation:
Indicates the MD5 value of a key used to decrypt objects. This header is included in a response if SSE-C is used.
Restrictions:
Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ==.
Value range:
Base64-encoded MD5 value of the key ID.
Default value:
None
bucket_location
const char *
No
Explanation:
Indicates the region where the bucket resides.
Restrictions:
None
Value range:
None
Default value:
None
obs_version
const char *
No
Explanation:
OBS version of the bucket.
Restrictions:
None
Value range:
  • 3.0: bucket of the latest version
  • --: bucket of an earlier version
Default value:
None
restore
const char *
No
Explanation:
Restoration status of an object.
Examples: ongoing-request="true" (the object is being restored); ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" (the object has been restored) expiry-date indicates when the restored object will expire.
Restrictions:
For an Archive object that is being restored or has been restored, this header is returned.
Value range:
None
Default value:
None
obs_object_type
const char *
No
Explanation:
Type of the object.
Restrictions:
This header is returned only when the object is not a Normal object.
Value range:
Appendable
Default value:
None
obs_next_append_position
const char *
No
Explanation:
Indicates the position to be provided for the next request.
Restrictions:
This header is returned only when the object is an Appendable object.
Value range:
None
Default value:
None
obs_head_epid
const char *
No
Explanation:
Enterprise project ID for the current bucket. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service.
Restrictions:
The value is a UUID. This parameter is not required if you have not enabled an enterprise project.
Value range:
None
Default value:
None
reserved_indicator
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 15 obs_error_details
Type
message
const char*
Explanation:
Error details in the XML error response body.
Restrictions:
None
Value range:
See Error Codes.
Default value:
None
resource
const char*
Explanation:
Bucket or object related to the error.
Restrictions:
None
Value range:
None
Default value:
None
further_details
const char*
Explanation:
The value of the FurtherDetails element in the XML error response body.
Restrictions:
None
Value range:
None
Default value:
None
extra_details_count
int
Explanation:
The number of other elements in the XML error response body.
Restrictions:
None
Value range:
None
Default value:
None
extra_details
obs_name_value*
Explanation:
Values of other elements in the XML error response body.
Restrictions:
None
error_headers_count
int
Explanation:
Number of headers in error_headers.
Restrictions:
None
Value range:
None
Default value:
None
error_headers
char**
Explanation:
All response headers that contain the error.
Restrictions:
None
Value range:
None
Default value:
None
Table 16 obs_name_value
Type
Mandatory (Yes/No)
name
char *
No
Explanation:
Key of a property.
Restrictions:
None
Value range:
None
Default value:
None
value
char *
No
Explanation:
Property value.
Restrictions:
None
Value range:
None
Default value:
None
Table 17 obs_status
Value
OBS_STATUS_OK
The request is successful.
OBS_STATUS_InitCurlFailed
Failed to initialize curl.
OBS_STATUS_InternalError
Internal error.
OBS_STATUS_OutOfMemory
The local memory is insufficient.
OBS_STATUS_FailedToIInitializeRequest
Failed to initialize the request.
OBS_STATUS_ConnectionFailed
Network connection failed.
OBS_STATUS_XmlParseFailure
Failed to parse the XML file.
OBS_STATUS_NameLookupError
Domain name resolution failed.
OBS_STATUS_FailedToConnect
Failed to connect to the server.
OBS_STATUS_PartialFile
Network transmission.
OBS_STATUS_InvalidParameter
Invalid parameter.
OBS_STATUS_NoToken
The current number of concurrent tasks exceeds the maximum number (1000 by default). Use the set_online_request_max_count function to adjust the maximum number of concurrent tasks.
OBS_STATUS_OpenFileFailed
Failed to open the file.
OBS_STATUS_AccessDenied
The request is rejected.
OBS_STATUS_MalformedPolicy
The format of the request policy is incorrect.
OBS_STATUS_MalformedXML
The XML request format is incorrect.
OBS_STATUS_MethodNotAllowed
The request method is not allowed.
OBS_STATUS_SignatureDoesNotMatch
The signatures do not match. Check whether the AK, SK, and token are correct.
OBS_STATUS_ServiceUnavailable
Server exception.
OBS_STATUS_SlowDown
The request frequency is too high.
Table 18 obs_lifecycle_conf
Type
Mandatory (Yes/No)
date
const char *
Yes if there is no days and no transition, noncurrent_version_days, or noncurrent_version_transition
Explanation:
Indicates the time when the object expiration rule of the latest version takes effect.
Restrictions:
The value must be compatible with the ISO 8601 format and must indicate 00:00 (UTC time).
Value range:
None
Default value:
None
days
const char *
Yes if there is no date and no transition, noncurrent_version_days, or noncurrent_version_transition
Explanation:
Number of days (since the object creation) after which the expiration rule will take effect.
Restrictions:
This parameter is only available for the latest object version.
Value range:
None
Default value:
None
id
const char *
No
Explanation:
ID of a rule.
Restrictions:
None
Value range:
The value is a string of a maximum of 255 characters.
Default value:
None
prefix
const char *
Yes
Explanation:
Object name prefix. It identifies the objects the rule applies to.
Restrictions:
None
Value range:
None
Default value:
None
status
const char *
Yes
Explanation:
Whether the rule is enabled
Restrictions:
None
Value range:
  • Enabled
  • Disabled
Default value:
None
const char *
No
Explanation:
The expiration time of objects' historical versions. If versioning is enabled or suspended for a bucket, you can set this parameter to delete historical versions of objects that match the lifecycle rule.
Restrictions:
This parameter is only available for historical object versions.
Value range:
None
Default value:
None
transition
obs_lifecycle_transtion *
Yes if there is no date, days, noncurrent_version_transition, or noncurrent_version_days
Explanation:
Transition time and the object storage class after transition
Restrictions:
Value range:
None
Default value:
None
transition_num
unsigned int
Yes if transition is specified
Explanation:
Number of array members in the transition array.
Restrictions:
None
Value range:
None
Default value:
None
obs_lifecycle_noncurrent_transtion*
Yes if there is no date, days, transition, or noncurrent_version_days
Explanation:
Transition time of historical object versions and the object storage class after transition.
Restrictions:
None
Value range:
None
Default value:
None
noncurrent_version_transition_num
unsigned int
Yes if noncurrent_version_transition is specified
Explanation:
Number of array members in the array noncurrent_version_transition.
Restrictions:
None
Value range:
None
Default value:
None
Table 19 obs_lifecycle_transtion
Type
Mandatory (Yes/No)
date
const char *
Yes if the obs_lifecycle_transtion.days element is absent
Explanation:
Restrictions:
Value range:
None
Default value:
None
days
const char *
Yes if the obs_lifecycle_transtion.date element is absent
Explanation:
Restrictions:
Value range:
None
Default value:
None
storage_class
obs_storage_class
Yes
Explanation:
The storage class to which the latest object version will be changed
Restrictions:
None
Value range:
Table 20 obs_lifecycle_noncurrent_transtion
Type
Mandatory (Yes/No)
const char *
Yes
Explanation:
Number of days an object is historical before the specified transition rule takes effect
Restrictions:
Value range:
None
Default value:
None
storage_class
obs_storage_class
Yes
Explanation:
The storage class to which historical versions will be changed
Restrictions:
None
Value range:
Table 21 obs_response_handler
Type
Mandatory (Yes/No)
properties_callback
Yes
Explanation:
Restrictions:
None
complete_callback
Yes
Explanation:
Restrictions:
None
Table 22 obs_response_properties_callback
Type
Mandatory (Yes/No)
properties
Yes
Explanation:
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 23 obs_response_complete_callback
Type
Mandatory (Yes/No)
status
obs_status
Yes
Explanation:
Restrictions:
None
Value range:
error_details
Yes
Explanation:
Restrictions:
None
callback_data
void *
Yes
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 24 obs_response_properties
Type
Mandatory (Yes/No)
request_id
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
request_id2
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
content_type
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
content_length
uint64_t
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
server
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
etag
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
None
expiration
const char *
No
Explanation:
Restrictions:
None
Value range:
Default value:
None
const char *
No
Explanation:
To an external URL:
Restrictions:
Value range:
None
Default value:
None
version_id
const char *
No
Explanation:
Object version ID.
Restrictions:
Value range:
Default value:
None
meta_data_count
int
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
meta_data
No
Explanation:
Restrictions:
None
char
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
allow_origin
const char *
No
Explanation:
Restrictions:
None
Value range:
Default value:
None
allow_headers
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
None
max_age
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
3000
allow_methods
const char *
No
Explanation:
Restrictions:
None
Value range:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Value range:
None
expose_headers
const char *
No
Explanation:
Restrictions:
Value range:
None
Default value:
None
storage_class
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
None
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
None
kms_key_id
const char *
No
Explanation:
Restrictions:
Value range:
None
Default value:
customer_algorithm
const char *
No
Explanation:
Restrictions:
None
Value range:
Default value:
None
customer_key_md5
const char *
No
Explanation:
Restrictions:
Value range:
Default value:
None
bucket_location
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
obs_version
const char *
No
Explanation:
Restrictions:
None
Value range:
Default value:
None
restore
const char *
No
Explanation:
Restrictions:
Value range:
None
Default value:
None
obs_object_type
const char *
No
Explanation:
Type of the object.
Restrictions:
Value range:
Appendable
Default value:
None
const char *
No
Explanation:
Restrictions:
Value range:
None
Default value:
None
obs_head_epid
const char *
No
Explanation:
Restrictions:
Value range:
None
Default value:
None
reserved_indicator
const char *
No
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 25 obs_error_details
Type
message
const char*
Explanation:
Restrictions:
None
Value range:
See Error Codes.
Default value:
None
resource
const char*
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
further_details
const char*
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
extra_details_count
int
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
extra_details
obs_name_value*
Explanation:
Restrictions:
None
error_headers_count
int
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
error_headers
char**
Explanation:
Restrictions:
None
Value range:
None
Default value:
None
Table 26 obs_name_value
Type
Mandatory (Yes/No)
name
char *
No
Explanation:
Key of a property.
Restrictions:
None
Value range:
None
Default value:
None
value
char *
No
Explanation:
Property value.
Restrictions:
None
Value range:
None
Default value:
None
Table 27 obs_status
Value
OBS_STATUS_OK
Internal error.
Invalid parameter.
OBS_STATUS_NoToken
Server exception.
OBS_STATUS_SlowDown
Code Examples: Setting the Object Expiration Time
This example sets the expiration time for the latest and historical object versions.
  3
  4
  5
  6
  7
  8
  9
 10
 11
 12
 13
 14
 15
 16
 17
 18
 19
 20
 21
 22
 23
 24
 25
 26
 27
 28
 29
 30
 31
 32
 33
 34
 35
 36
 37
 38
 39
 40
 41
 42
 43
 44
 45
 46
 47
 48
 49
 50
 51
 52
 53
 54
 55
 56
 57
 58
 59
 60
 61
 62
 63
 64
 65
 66
 67
 68
 69
 70
 71
 72
 73
 74
 75
 76
 77
 78
 79
 80
 81
 82
 83
 84
 85
 86
 87
 88
 89
 90
 91
 92
 93
 94
 95
 96
 97
 98
 99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
#include "eSDKOBS.h"
#include <stdio.h>
// The response callback function. The content of properties in the callback can be recorded in callback_data (custom callback data).
obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data);
// The completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data).
void response_complete_callback(obs_status status, const obs_error_details *error, void *callback_data);
int main()
    // The following code shows how to set the expiration time for the latest and historical object versions:
    // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory.
    obs_initialize(OBS_INIT_ALL);
    obs_options options;
    // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class).
    init_obs_options(&options);
    // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one in your actual situation.
    options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com";
    // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
    // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY.
    options.bucket_options.access_key = getenv("ACCESS_KEY_ID");
    options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY");
    // Specify the bucket name, for example, example-bucket-name.
    char * bucketName = "example-bucket-name";
    options.bucket_options.bucket_name = bucketName;
    obs_response_handler response_handler = { &response_properties_callback, &response_complete_callback };
    obs_lifecycle_conf bucket_lifecycle_conf;
    memset(&bucket_lifecycle_conf, 0, sizeof(obs_lifecycle_conf));
    //Lifecycle rule ID
    bucket_lifecycle_conf.id = "test1";
    // Specify the prefix as "test".
    bucket_lifecycle_conf.prefix = "test";
    // Specify that objects whose names contain the specified prefix will expire 10 days after creation.
    bucket_lifecycle_conf.days = "10";
    // Specify that objects whose names contain the specified prefix will expire 20 days after becoming historical versions.
    bucket_lifecycle_conf.noncurrent_version_days = "20";
    // Enable the lifecycle rule.
    bucket_lifecycle_conf.status = "Enabled";
    obs_status  ret_status = OBS_STATUS_BUTT;
    set_bucket_lifecycle_configuration(&options, &bucket_lifecycle_conf, 1,
        &response_handler, &ret_status);
    if (OBS_STATUS_OK == ret_status) {
        printf("set bucket lifecycle configuration success.\n");
    else
        printf("set bucket lifecycle configuration failed(%s).\n",
            obs_get_status_name(ret_status));
    // Release the allocated global resources.
    obs_deinitialize();
    if (properties == NULL)
        printf("error! obs_response_properties is null!");
        if (callback_data != NULL)
            obs_sever_callback_data *data = (obs_sever_callback_data *)callback_data;
            printf("server_callback buf is %s, len is %llu",
                data->buffer, data->buffer_len);
            return OBS_STATUS_OK;
        else {
            printf("error! obs_sever_callback_data is null!");
// Print the response.
#define print_nonnull(name, field)                                 \
    do {                                                           \
        if (properties-> field) {                                  \
            printf("%s: %s\n", name, properties->field);          \
    } while (0)
    print_nonnull("request_id", request_id);
    print_nonnull("request_id2", request_id2);
    print_nonnull("content_type", content_type);
    if (properties->content_length) {
        printf("content_length: %llu\n", properties->content_length);
    print_nonnull("server", server);
    print_nonnull("ETag", etag);
    print_nonnull("expiration", expiration);
    print_nonnull("website_redirect_location", website_redirect_location);
    print_nonnull("version_id", version_id);
    print_nonnull("allow_origin", allow_origin);
    print_nonnull("allow_headers", allow_headers);
    print_nonnull("max_age", max_age);
    print_nonnull("allow_methods", allow_methods);
    print_nonnull("expose_headers", expose_headers);
    print_nonnull("storage_class", storage_class);
    print_nonnull("server_side_encryption", server_side_encryption);
    print_nonnull("kms_key_id", kms_key_id);
    print_nonnull("customer_algorithm", customer_algorithm);
    print_nonnull("customer_key_md5", customer_key_md5);
    print_nonnull("bucket_location", bucket_location);
    print_nonnull("obs_version", obs_version);
    print_nonnull("restore", restore);
    print_nonnull("obs_object_type", obs_object_type);
    print_nonnull("obs_next_append_position", obs_next_append_position);
    print_nonnull("obs_head_epid", obs_head_epid);
    print_nonnull("reserved_indicator", reserved_indicator);
    int i;
    for (i = 0; i < properties->meta_data_count; i++) {
        printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name,
            properties->meta_data[i].value);
    if (callback_data) {
        obs_status *ret_status = (obs_status *)callback_data;
        *ret_status = status;
    } else {
        printf("Callback_data is NULL");
    if (error && error->message) {
        printf("Error Message: \n   %s\n", error->message);
    if (error && error->resource) {
        printf("Error Resource: \n  %s\n", error->resource);
    if (error && error->further_details) {
        printf("Error further_details: \n   %s\n", error->further_details);
    if (error && error->extra_details_count) {
        int i;
        for (i = 0; i < error->extra_details_count; i++) {
            printf("Error Extra Detail(%d):\n   %s:%s\n", i, error->extra_details[i].name,
                   error->extra_details[i].value);
    if (error && error->error_headers_count) {
        int i;
        for (i = 0; i < error->error_headers_count; i++) {
            const char *errorHeader = error->error_headers[i];
            printf("Error Headers(%d):\n    %s\n", i, errorHeader == NULL ? "NULL Header" : errorHeader);
Code Examples: Configuring the Object Transition Policy
This example sets the transition policy for the latest and historical object versions.
  3
  4
  5
  6
  7
  8
  9
 10
 11
 12
 13
 14
 15
 16
 17
 18
 19
 20
 21
 22
 23
 24
 25
 26
 27
 28
 29
 30
 31
 32
 33
 34
 35
 36
 37
 38
 39
 40
 41
 42
 43
 44
 45
 46
 47
 48
 49
 50
 51
 52
 53
 54
 55
 56
 57
 58
 59
 60
 61
 62
 63
 64
 65
 66
 67
 68
 69
 70
 71
 72
 73
 74
 75
 76
 77
 78
 79
 80
 81
 82
 83
 84
 85
 86
 87
 88
 89
 90
 91
 92
 93
 94
 95
 96
 97
 98
 99
100
101
102
103
104
105
106
107
108
109
110
111
112
113
114
115
116
117
118
119
120
121
122
123
124
125
126
127
128
129
130
131
132
133
134
135
136
137
138
139
140
141
142
143
144
145
146
147
148
149
150
151
152
153
154
155
156
157
#include <stdio.h>
int main()
    // The following code shows how to set the transition policy for the latest and historical object versions:
    //Lifecycle rule ID
    bucket_lifecycle_conf.id = "test3";
    bucket_lifecycle_conf.prefix = "bcd";
    // Specify that objects whose names contain the specified prefix will expire 30 days after creation.
    bucket_lifecycle_conf.days = "30";
    obs_lifecycle_transtion transition;
    memset(&transition, 0, sizeof(obs_lifecycle_transtion));
    // Specify that objects whose names contain the specified prefix will be transitioned 10 days after creation.
    transition.days = "10";
    // Specify the storage class of the object after transition.
    transition.storage_class = OBS_STORAGE_CLASS_STANDARD_IA;
    bucket_lifecycle_conf.transition = &transition;
    bucket_lifecycle_conf.transition_num = 1;
    obs_lifecycle_noncurrent_transtion noncurrent_transition;
    memset(&noncurrent_transition, 0, sizeof(obs_lifecycle_noncurrent_transtion));
    // Specify that object versions whose names contain the specified prefix will be transitioned 30 days after becoming historical versions.
    noncurrent_transition.noncurrent_version_days = "30";
    // Specify the storage class of object versions whose names contain the specified prefix after transition.
    noncurrent_transition.storage_class = OBS_STORAGE_CLASS_STANDARD_IA;
    bucket_lifecycle_conf.noncurrent_version_transition = &noncurrent_transition;
    bucket_lifecycle_conf.noncurrent_version_transition_num = 1;
    else
    obs_deinitialize();
        else {
    do {                                                           \
    } while (0)
    int i;
    } else {
        int i;
        int i;
