Listing Objects in a Bucket (SDK for C)
If you have any questions during development, post them on the Issues page of GitHub.
Function
This API lists some or all of the objects in a bucket. You can use parameters such as the prefix, number of returned objects, and start position to list objects that meet specified criteria. Returned objects are listed in alphabetical order by object name.
Restrictions
- A maximum of 1,000 objects can be listed for each API call.
- To list objects in a bucket, you must be the bucket owner or have the required permission (obs:bucket:ListBucket in IAM and ListBucket in a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
void list_bucket_objects(const obs_options *options, const char *prefix, const char *marker,
const char *delimiter, int maxkeys, obs_list_objects_handler *handler, void *callback_data); Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | const obs_options* | Yes | Explanation: The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options. Restrictions: None |
| prefix | char * | No | Explanation: Name prefix that the objects to be listed must contain Restrictions: None Value range: None Default value: None |
| marker | char * | No | Explanation: Object name to start with when listing objects. All objects are listed in the lexicographical order. Restrictions: None Value range: None Default value: None |
| delimiter | char * | No | Explanation: The character used to group object names. If the object name contains the value specified by the delimiter parameter, the string from the first character to the first delimiter in the object name (excluding the prefix if prefix is specified) is grouped into one commonPrefix to be returned. For a parallel file system, if this parameter is not specified, all the content in the directory is recursively listed by default, and subdirectories are also listed. In big data scenarios, file systems usually have multiple directory levels and each directory level has a large number of objects. In such case, you are advised to configure [delimiter="/"] to list the content in the current directory but exclude the content in subdirectories, thereby making the listing more efficient. Restrictions: None Value range: None Default value: None |
| maxkeys | int | Yes | Explanation: Maximum number of objects that can be listed. Restrictions: If the specified value is greater than 1000, 1000 is used by default. Value range: An integer from 1 to 1000 Default value: 1000 |
| handler | Yes | Explanation: A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data. Restrictions: None | |
| callback_data | void * | No | Explanation: Custom callback data. Restrictions: None Value range: None Default value: None |
| bucket_options | Yes | Explanation: Bucket settings. Restrictions: None | |
| request_options | Yes | Explanation: Request-related settings. Restrictions: None | |
| temp_auth | No | Explanation: The structure used to calculate a temporary signature. Set it to NULL if it is not used. Restrictions: None |
| host_name | char * | Yes | Explanation: The requested host name, used as an address for connecting to OBS. It is the domain name (the endpoint) of the server where the requested resource is stored. Example: host_name = "obs.ap-southeast-1.myhuaweicloud.com"; Restrictions: The value does not need to contain http:// or https:// as a prefix, which is controlled using obs_protocol. Value range: To view the endpoints available for OBS, see Regions and Endpoints. Default value: None |
| bucket_name | char * | Yes | Explanation: Bucket name. Restrictions:
| useCname | bool | No | Explanation: Whether to use a custom domain name to access OBS. Restrictions: None Value range: true: A custom domain name is used. false: A custom domain name is not used. Default value: false |
| protocol | No | Explanation: Whether to use the HTTP or HTTPS protocol. Restrictions: None Value range: For details, see Table 6. Default value: OBS_PROTOCOL_HTTPS (HTTPS is used by default.) | |
| access_key | char * | Yes | Explanation: Access key ID (AK). Restrictions: None Value range: For details, see Creating Access Keys. Default value: None |
| secret_access_key | char * | Yes | Explanation: Secret access key (SK). Restrictions: None Value range: For details, see Creating Access Keys. Default value: None |
| storage_class | No | Explanation: Bucket storage class that can be specified at bucket creation. Restrictions: None Value range: For details, see Table 4. Default value: OBS_STORAGE_CLASS_STANDARD (Standard storage class) | |
| token | char * | No | Explanation: The security token in temporary credentials. Restrictions: None Value range: For details, see Creating Access Keys. Default value: None |
| epid | char * | No | Explanation: Enterprise project ID that can be specified during bucket creation. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service. Restrictions: The value needs to be represented as a UUID. This parameter is not required if EPS is not enabled. Example: 9892d768-2d13-450f-aac7-ed0e44c2585f Default value: None |
| bucket_type | No | Explanation: Whether a bucket is an object bucket or a parallel file system. Restrictions: None Value range: For details, see Table 7. Default value: OBS_BUCKET_OBJECT (object bucket) | |
| bucket_list_type | No | Explanation: Whether to list all buckets, object buckets, or parallel file systems. Restrictions: None Value range: For details, see Table 8. |
| Constant | Original Value | Description |
| OBS_STORAGE_CLASS_STANDARD | STANDARD | Standard storage class. This class features low access latency and high throughput and is used for storing massive, frequently accessed (multiple times a month) or small objects (< 1 MB) requiring quick response. |
| OBS_STORAGE_CLASS_STANDARD_IA | STANDARD_IA | Infrequent Access storage class. Used for storing data that is semi-frequently accessed (fewer than 12 times a year) but becomes instantly available when needed. |
| OBS_STORAGE_CLASS_GLACIER | GLACIER | Archive storage class. Used for storing rarely accessed (once a year) data. |
| connect_time | int | Yes | Explanation: Timeout period for establishing an HTTP/HTTPS connection, in ms. Restrictions: None Value range: [10000, 60000] Default value: 60000 |
| max_connected_time | int | Yes | Explanation: Timeout period (in seconds) of a request. Restrictions: None Value range: None Default value: 0 (There is never automatic disconnection.) |
| proxy_auth | char* | No | Explanation: Proxy authentication information, in the format username:password Restrictions: None Value range: None Default value: None |
| proxy_host | char* | No | Explanation: IP address or host name of the proxy server. Restrictions: None Value range: None Default value: None |
| OBS_PROTOCOL_HTTPS | https | HTTPS is used for access. |
| OBS_PROTOCOL_HTTP | http | HTTP is used for access. |
| OBS_BUCKET_OBJECT | OBJECT | Object buckets. |
| OBS_BUCKET_PFS | POSIX | Parallel file systems. |
| OBS_BUCKET_LIST_ALL | No header is sent. | Lists all buckets. |
| OBS_BUCKET_LIST_OBJECT | OBJECT | Lists all object buckets. |
| OBS_BUCKET_LIST_PFS | POSIX | Lists all parallel file systems. |
| expires | long long int | Yes | Explanation: Validity period of the temporary credentials, in seconds. Restrictions: None Value range: [0-630720000] Default value: None |
| temp_auth_callback | void (*temp_auth_callback)(char *temp_auth_url, uint64_t temp_auth_url_len, char*temp_auth_headers, uint64_t temp_auth_headers_len, void*callback_data) | Yes | Explanation: The pointer to the custom callback function, which is used to record the temporary URL and involved signature header to the custom callback data. Restrictions: None |
| callback_data | void * | Yes | Explanation: Custom callback data. Restrictions: None Value range: None Default value: None |
| temp_auth_url | char * | Yes | Explanation: Temporary URL. OBS allows you to construct a URL for a specific operation. In such a URL, you use Query parameters to provide authentication information including the user AK, signature, and validity period. Anyone who has the URL can perform the specified operation. After receiving a request made using such a URL, OBS treats the requester as the user who issued the URL and processes the request. For example, if you construct a pre-signed URL for downloading an object and provide it to various users, they can use the URL to download the object without authentication, but they must do so within the validity period specified by the Expires parameter. Restrictions: None Value range: None Default value: None |
| temp_auth_url_len | uint64_t | Yes | Explanation: Length of the temporary URL. Restrictions: None Value range: None Default value: None |
| temp_auth_headers | char * | Yes | Explanation: Headers for temporary authentication. Restrictions: None Value range: None Default value: None |
| temp_auth_headers_len | uint64_t | Yes | Explanation: Length of the buffer for temporary authentication headers, in bytes. Restrictions: None Value range: None Default value: None |
| response_handler | Yes | Explanation: Response callback function structure. Restrictions: None | |
| list_Objects_callback | Yes | Explanation: Callback function pointer, which is used to copy the data to be uploaded to the data upload buffer. Restrictions: None |
| properties_callback | Yes | Explanation: The pointer to the response callback function. In this callback, you can record the content of obs_response_properties into callback_data (custom callback data). Restrictions: None | |
| complete_callback | Yes | Explanation: The pointer to the completion callback function. The content of obs_status and obs_error_details in the callback can be recorded in callback_data (custom callback data). Restrictions: None |
| properties | const obs_response_properties* | Yes | Explanation: Parameters in the response headers. You are advised to record them to callback_data (custom callback data). Restrictions: None |
| callback_data | void * | Yes | Explanation: The pointer to the custom callback data. Restrictions: None Value range: None Default value: None |
| status | Yes | Explanation: Internal request status code of the SDK. Restrictions: None Value range: For details, see Table 18. | |
| error_details | const obs_error_details* | Yes | Explanation: Details about the request failure, including the error message and resource information. You are advised to record them in callback_data (custom callback data). Restrictions: None |
| request_id | const char * | No | Explanation: The value created by OBS to uniquely identify the request. OBS uses this value to locate the fault. Restrictions: None Value range: None Default value: None |
| request_id2 | const char * | No | Explanation: A special symbol that helps troubleshoot. Restrictions: None Value range: None Default value: None |
| content_type | const char * | No | Explanation: MIME type of the object. MIME type is a standard way of describing a data type and is used by the browser to decide how to display data. Restrictions: None Value range: None Default value: None |
| content_length | uint64_t | No | Explanation: The size (in bytes) of the response body. Restrictions: None Value range: None Default value: None |
| server | const char * | No | Explanation: Server header in an HTTP request. Restrictions: None Value range: None Default value: None |
| etag | const char * | No | Explanation: Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag. Restrictions: If an object is encrypted using server-side encryption, the ETag is not the MD5 value of the object. Value range: The value must contain 32 characters. Default value: None |
| expiration | const char * | No | Explanation: Expiration details of the object. Restrictions: None Value range: Time string in ISO 8601 format, for example, Web, 7 Nov 2012 00:00:00 GMT Default value: None |
| website_redirect_location | const char * | No | Explanation: Indicates where an object request is redirected. If the bucket that contains the object is configured with Website settings, this parameter can be set in the object metadata so that the request for the object can be redirected to another object in the same bucket or an external URL after the website returns a 301 redirect response. To another object in the same bucket: x-obs-website-redirect-location:/anotherPage.html To an external URL: x-obs-website-redirect-location:http://www.example.com/ OBS obtains the specified value from the header and stores it in the object metadata WebsiteRedirectLocation. Restrictions:
| version_id | const char * | No | Explanation: Object version ID. Restrictions: If the object has no version ID, the value is NULL. Value range: The value must contain 32 characters. Default value: None |
| meta_data_count | int | No | Explanation: Number of elements in the meta_data array. Restrictions: None Value range: None Default value: None |
| meta_data | const obs_name_value * | No | Explanation: Custom metadata of the object. You can add custom metadata headers that start with x-obs-meta- for easy object management. When you retrieve or query the metadata of the object, the added custom metadata headers will be returned in the response. Restrictions: None |
| use_server_side_encryption | char | No | Explanation: If server-side encryption is enabled, this parameter is set to '\1'. Restrictions: None Value range: None Default value: None |
| allow_origin | const char * | No | Explanation: Indicates that the origin is included in the response if the origin in the request meets the CORS configuration requirements on the server. Restrictions: None Value range: The value that complies with the CORS Default value: None |
| allow_headers | const char * | No | Explanation: Indicates that the headers are included in the response if the headers in the request meet the CORS configuration requirements on the server. Restrictions: At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Value range: The value that complies with the CORS Default value: None |
| max_age | const char * | No | Explanation: MaxAgeSeconds in the CORS rules of the bucket. It specifies the time your client can cache the response for a cross-origin request. Restrictions: Each CORS rule can contain at most one MaxAgeSeconds. Value range: An integer greater than or equal to 0, in seconds. Default value: 3000 |
| allow_methods | const char * | No | Explanation: Indicates that methods in the rule are included in the response if Access-Control-Request-Method in the request meets the CORS configuration requirements when CORS is configured for buckets. Restrictions: None Value range:
| expose_headers | const char * | No | Explanation: ExposeHeader in the CORS rules of the bucket. It specifies additional headers allowed in the response by a CORS rule. These headers provide extra information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them as additional headers. Restrictions: Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed. Value range: None Default value: None |
| storage_class | const char * | No | Explanation: Object storage class. Restrictions: This header is returned only when the storage class of an object is not Standard. Value range:
| server_side_encryption | const char * | No | Explanation: The encryption method used by the server. Example: x-obs-server-side-encryption:kms Restrictions: This header is included in a response if SSE-KMS is used. Value range:
| kms_key_id | const char * | No | Explanation: Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required. Restrictions: This header can only be used when you specify kms for the server_side_encryption header. Value range: None Default value: If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it. |
| customer_algorithm | const char * | No | Explanation: Indicates a decryption algorithm. This header is included in a response if SSE-C is used. Restrictions: None Value range: AES256 (AES256 decryption algorithm) Default value: None |
| customer_key_md5 | const char * | No | Explanation: Indicates the MD5 value of a key used to decrypt objects. This header is included in a response if SSE-C is used. Restrictions: Base64-encoded MD5 value of the key, for example, 4XvB3tbNTN+tIEVa0/fGaQ==. Value range: Base64-encoded MD5 value of the key ID. Default value: None |
| bucket_location | const char * | No | Explanation: Indicates the region where the bucket resides. Restrictions: None Value range: None Default value: None |
| obs_version | const char * | No | Explanation: OBS version of the bucket. Restrictions: None Value range:
| restore | const char * | No | Explanation: Restoration status of an object. Examples: ongoing-request="true" (the object is being restored); ongoing-request="false", expiry-date="Wed, 7 Nov 2012 00:00:00 GMT" (the object has been restored) expiry-date indicates when the restored object will expire. Restrictions: For an Archive object that is being restored or has been restored, this header is returned. Value range: None Default value: None |
| obs_object_type | const char * | No | Explanation: Type of the object. Restrictions: This header is returned only when the object is not a Normal object. Value range: Appendable Default value: None |
| obs_next_append_position | const char * | No | Explanation: Indicates the position to be provided for the next request. Restrictions: This header is returned only when the object is an Appendable object. Value range: None Default value: None |
| obs_head_epid | const char * | No | Explanation: Enterprise project ID for the current bucket. Users who have enabled the enterprise project function can obtain the ID from the enterprise project service. Restrictions: The value is a UUID. This parameter is not required if you have not enabled an enterprise project. Value range: None Default value: None |
| reserved_indicator | const char * | No | Explanation: A special symbol that helps troubleshoot. Restrictions: None Value range: None Default value: None |
| Parameter | Type | Description |
| message | const char* | Explanation: Error details in the XML error response body. Restrictions: None Value range: See Error Codes. Default value: None |
| resource | const char* | Explanation: Bucket or object related to the error. Restrictions: None Value range: None Default value: None |
| further_details | const char* | Explanation: The value of the FurtherDetails element in the XML error response body. Restrictions: None Value range: None Default value: None |
| extra_details_count | int | Explanation: The number of other elements in the XML error response body. Restrictions: None Value range: None Default value: None |
| extra_details | Explanation: Values of other elements in the XML error response body. Restrictions: None | |
| error_headers_count | int | Explanation: Number of headers in error_headers. Restrictions: None Value range: None Default value: None |
| error_headers | char** | Explanation: All response headers that contain the error. Restrictions: None Value range: None Default value: None |
| name | char * | No | Explanation: Key of a property. Restrictions: None Value range: None Default value: None |
| value | char * | No | Explanation: Property value. Restrictions: None Value range: None Default value: None |
| OBS_STATUS_OK | 0 | The request is successful. |
| OBS_STATUS_InitCurlFailed | 1 | Failed to initialize curl. |
| OBS_STATUS_InternalError | 2 | Internal error. |
| OBS_STATUS_OutOfMemory | 3 | The local memory is insufficient. |
| OBS_STATUS_FailedToIInitializeRequest | 6 | Failed to initialize the request. |
| OBS_STATUS_XmlParseFailure | 23 | Failed to parse the XML file. |
| OBS_STATUS_NameLookupError | 33 | Domain name resolution failed. |
| OBS_STATUS_FailedToConnect | 34 | Failed to connect to the server. |
| OBS_STATUS_ConnectionFailed | 36 | Network connection failed. |
| OBS_STATUS_PartialFile | 38 | Network transmission interrupted. |
| OBS_STATUS_InvalidParameter | 39 | Invalid parameter. |
| OBS_STATUS_NoToken | 40 | The current number of concurrent tasks exceeds the upper limit (1,000 by default). The token here refers to the concurrent request token, not the security authentication token. You can use the set_online_request_max_count function to adjust the maximum number of concurrent tasks. |
| OBS_STATUS_OpenFileFailed | 41 | Failed to open the file. |
| OBS_STATUS_AccessDenied | 43 | The request is rejected. |
| OBS_STATUS_MalformedPolicy | 44 | The format of the request policy is incorrect. |
| OBS_STATUS_MalformedXML | 45 | The XML request format is incorrect. |
| OBS_STATUS_MethodNotAllowed | 46 | The request method is not allowed. |
| OBS_STATUS_SignatureDoesNotMatch | 47 | The signatures do not match. Check whether the AK, SK, and token are correct. |
| OBS_STATUS_ServiceUnavailable | 48 | Server exception. |
| OBS_STATUS_SlowDown | 49 | The request frequency is too high. |
| is_truncated | int | Yes | Explanation: Whether the result is truncated. Restrictions: None Value range:
| next_marker | const char * | Yes | Explanation: Object name to start with for the next object listing request. This parameter is returned if some listing results were not returned. You can set key_marker of the next request to the returned value to list the remaining results. Restrictions: This parameter is only available for listing objects with multiple versions. Value range: The value can contain 1 to 1,024 characters. Default value: None |
| contents_count | const char * | Yes | Explanation: Start position for the next request for listing objects. It must be used together with next_key_marker. This parameter is returned if some listing results were not returned. You can set version_id_marker of the next request to the returned value to list the remaining results. Restrictions: This parameter is only available for listing objects with multiple versions. Value range: The value must contain 32 characters. Default value: None |
| contents | const obs_list_objects_content * | Yes | Explanation: Information about the listed objects. Restrictions: None |
| common_prefixes_count | int | Yes | Explanation: Number of common prefixes. Restrictions: None Value range: None Default value: None |
| common_prefixes | const char ** | Yes | Explanation: List of object name prefixes grouped according to the delimiter parameter (if specified) Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
| key | const char * | No | Explanation: Object name. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name. For example, if the access path is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
| last_modified | int64_t | No | Explanation: Time when the object was last modified, in UTC. Restrictions: None Value range: The value can contain 1 to 1,024 characters. Default value: None |
| etag | const char * | No | Explanation: Base64-encoded, 128-bit MD5 value of an object. It uniquely identifies the content of an object and can be used to check the object integrity. For example, if the ETag is A when an object is uploaded and is B when the object is downloaded, it indicates that the object content has been changed. The ETag value is a hash of the object. The ETag reflects changes to the contents of the object, not its metadata. An object created by an upload or copy operation has a unique ETag after MD5 encryption. Restrictions: None Value range: The value must contain 32 characters. Default value: None |
| size | uint64_t | No | Explanation: Object size in bytes. Restrictions: None Value range: None Default value: None |
| owner_id | const char * | No | Explanation: Domain ID (account ID) of the object owner. Restrictions: None Value range: None Default value: None |
| storage_class | const char * | No | Explanation: Object storage class. Restrictions: None Value range: None Default value: None |
| type | const char * | No | Explanation: Object type. This parameter is returned when the object type is not Normal. Restrictions: None Value range: None Default value: None |
Code Examples: Listing Objects
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 | #include "eSDKOBS.h" #include <stdio.h> #include <time.h> #include <sys/stat.h> // The response callback function. In this callback, you can record the content of properties into callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data); void listobjects_complete_callback(obs_status status, const obs_error_details *error, void *callback_data); typedef struct list_object_callback_data { int is_truncated; char next_marker[1024]; int keyCount; int allDetails; obs_status ret_status; } list_object_callback_data; obs_status list_objects_callback(int is_truncated, const char *next_marker, int contents_count, const obs_list_objects_content *contents, int common_prefixes_count, const char **common_prefixes, void *callback_data); int main() { // The following code shows how to use the list_bucket_objects function to list objects in a bucket: // Call the obs_initialize method at the program entry to initialize global resources such as the network and memory. obs_status ret_status = obs_initialize(OBS_INIT_ALL); if (OBS_STATUS_OK != ret_status) { printf("obs_initialize failed(%s).\n", obs_get_status_name(ret_status)); return -1; } obs_options options; // Create and initialize options, including the access domain name (host_name), access keys (access_key_id and access_key_secret), bucket name (bucket_name), and bucket storage class (storage_class). init_obs_options(&options); // Enter the endpoint corresponding to the bucket for host_name. CN-Hong Kong is used here as an example. Replace it with the one currently in use. options.bucket_options.host_name = "obs.ap-southeast-1.myhuaweicloud.com"; // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. // In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure local environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY. options.bucket_options.access_key = getenv("ACCESS_KEY_ID"); options.bucket_options.secret_access_key = getenv("SECRET_ACCESS_KEY"); // Specify the bucket name, for example, example-bucket-name. char * bucket_name = "example-bucket-name"; options.bucket_options.bucket_name = bucket_name; // Set the response callback function. obs_list_objects_handler list_bucket_objects_handler = { { &response_properties_callback, &listobjects_complete_callback }, &list_objects_callback }; // Customize callback data. list_object_callback_data data; memset(&data, 0, sizeof(list_object_callback_data)); data.allDetails = 1; const char* prefix = NULL; const char* marker = NULL; const char* delimiter = "/"; int maxkeys = 1000; // List objects. list_bucket_objects(&options, prefix, marker, delimiter, maxkeys, &list_bucket_objects_handler, &data); if (OBS_STATUS_OK == data.ret_status) { printf("list bucket objects successfully. \n"); } else { printf("list bucket objects failed(%s).\n", obs_get_status_name(data.ret_status)); } // Release the allocated global resources. obs_deinitialize(); } // The response callback function. In this callback, you can record the content of properties into callback_data (custom callback data). obs_status response_properties_callback(const obs_response_properties *properties, void *callback_data) { if (properties == NULL) { printf("error! obs_response_properties is null!"); return OBS_STATUS_OK; } // Print the response. #define print_nonnull(name, field) \ do { \ if (properties-> field) { \ printf("%s: %s\n", name, properties->field); \ } \ } while (0) print_nonnull("request_id", request_id); print_nonnull("request_id2", request_id2); print_nonnull("content_type", content_type); if (properties->content_length) { printf("content_length: %llu\n", properties->content_length); } print_nonnull("server", server); print_nonnull("ETag", etag); print_nonnull("expiration", expiration); print_nonnull("website_redirect_location", website_redirect_location); print_nonnull("version_id", version_id); print_nonnull("allow_origin", allow_origin); print_nonnull("allow_headers", allow_headers); print_nonnull("max_age", max_age); print_nonnull("allow_methods", allow_methods); print_nonnull("expose_headers", expose_headers); print_nonnull("storage_class", storage_class); print_nonnull("server_side_encryption", server_side_encryption); print_nonnull("kms_key_id", kms_key_id); print_nonnull("customer_algorithm", customer_algorithm); print_nonnull("customer_key_md5", customer_key_md5); print_nonnull("bucket_location", bucket_location); print_nonnull("obs_version", obs_version); print_nonnull("restore", restore); print_nonnull("obs_object_type", obs_object_type); print_nonnull("obs_next_append_position", obs_next_append_position); print_nonnull("obs_head_epid", obs_head_epid); print_nonnull("reserved_indicator", reserved_indicator); int i; for (i = 0; i < properties->meta_data_count; i++) { printf("x-obs-meta-%s: %s\n", properties->meta_data[i].name, properties->meta_data[i].value); } return OBS_STATUS_OK; } void print_error_details(const obs_error_details *error) { if (error && error->message) { printf("Error Message: \n %s\n", error->message); } if (error && error->resource) { printf("Error Resource: \n %s\n", error->resource); } if (error && error->further_details) { printf("Error further_details: \n %s\n", error->further_details); } if (error && error->extra_details_count) { int i; for (i = 0; i < error->extra_details_count; i++) { printf("Error Extra Detail(%d):\n %s:%s\n", i, error->extra_details[i].name, error->extra_details[i].value); } } if (error && error->error_headers_count) { int i; for (i = 0; i < error->error_headers_count; i++) { const char *errorHeader = error->error_headers[i]; printf("Error Headers(%d):\n %s\n", i, errorHeader == NULL ? "NULL Header" : errorHeader); } } } void listobjects_complete_callback(obs_status status, const obs_error_details *error, void *callback_data) { if (callback_data) { list_object_callback_data *data = (list_object_callback_data *)callback_data; data->ret_status = status; } else { printf("Callback_data is NULL"); } print_error_details(error); } static void printListBucketHeader(int allDetails) { printf("%-50s %-20s %-5s", " Key", " Last Modified", "Size"); if (allDetails) { printf(" %-34s %-64s %-12s %-12s", " ETag", " Owner ID", "Display Name", "StorageClass"); } printf("\n"); printf("-------------------------------------------------- " "-------------------- -----"); if (allDetails) { printf(" ---------------------------------- " "-------------------------------------------------" "--------------- ------------ ------------"); } printf("\n"); } obs_status list_objects_callback(int is_truncated, const char *next_marker, int contents_count, const obs_list_objects_content *contents, int common_prefixes_count, const char **common_prefixes, void *callback_data) { list_object_callback_data *data = (list_object_callback_data *)callback_data; data->is_truncated = is_truncated; if ((!next_marker || !next_marker[0]) && contents_count) { next_marker = contents[contents_count - 1].key; } if (next_marker) { snprintf(data->next_marker, sizeof(data->next_marker), "%s", next_marker); } else { data->next_marker[0] = 0; } if (contents_count && !data->keyCount) { printListBucketHeader(data->allDetails); } int i; for (i = 0; i < contents_count; i++) { const obs_list_objects_content *content = &(contents[i]); char timebuf[256] = { 0 }; time_t t = (time_t)content->last_modified; strftime(timebuf, sizeof(timebuf), "%Y-%m-%dT%H:%M:%SZ", gmtime(&t)); char sizebuf[16] = { 0 }; if (content->size < 100000) { sprintf_s(sizebuf, sizeof(sizebuf), "%5llu", (unsigned long long) content->size); } else if (content->size < (1024 * 1024)) { sprintf_s(sizebuf, sizeof(sizebuf), "%4lluK", ((unsigned long long) content->size) / 1024ULL); } else if (content->size < (10 * 1024 * 1024)) { float f = content->size; f /= (1024 * 1024); sprintf_s(sizebuf, sizeof(sizebuf), "%1.2fM", f); } else if (content->size < (1024 * 1024 * 1024)) { sprintf_s(sizebuf, sizeof(sizebuf), "%4lluM", ((unsigned long long) content->size) / (1024ULL * 1024ULL)); } else { float f = (content->size / 1024); f /= (1024 * 1024); sprintf_s(sizebuf, sizeof(sizebuf), "%1.2fG", f); } printf("%-50s %s %s", content->key, timebuf, sizebuf); if (data->allDetails) { printf(" %-36s %-64s %-20s %-16s %-16s", content->etag, content->owner_id ? content->owner_id : "", content->owner_display_name ? content->owner_display_name : "", content->storage_class ? content->storage_class : "", content->type ? content->type : "" ); } printf("\n"); } data->keyCount += contents_count; for (i = 0; i < common_prefixes_count; i++) { printf("\nCommon Prefix: %s\n", common_prefixes[i]); } printf("contents_count:%d\n", contents_count); return OBS_STATUS_OK; } |
