Help Center/ Object Storage Service/ SDK Reference/ C/ Data Types/ bucket_website_routingrule
Updated on 2026-08-03 GMT+08:00
Table 1 bucket_website_routingrule
Type
Mandatory (Yes/No)
key_prefix_equals
const char *
Yes
Explanation:
Indicates the object name prefix which the redirection applies to.
For example, to redirect the requests for the object ExamplePage.html, set key_prefix_equals to ExamplePage.html.
Restrictions:
None
Value range:
None
Default value:
None
http_errorcode_returned_equals
const char *
Yes
Explanation:
The HTTP error code for redirection to take effect. If an error code returned is the same as the value specified for this parameter, the redirection rule takes effect.
Examples:
If you want to redirect requests to NotFound.html when an HTTP error code 404 is returned, set http_errorcode_returned_equals to 404 and replace_key_with to NotFound.html.
Restrictions:
None
Value range:
None
Default value:
None
protocol
const char *
Yes
Explanation:
Indicates the protocol (http or https) used for redirecting requests.
Restrictions:
None
Value range:
None
Default value:
None
host_name
const char *
Yes
Explanation:
Indicates the name of the host where requests will be redirected.
Restrictions:
None
Value range:
None
Default value:
None
replace_key_prefix_with
const char *
Yes
Explanation:
The object name prefix used in the redirection. OBS replaces the value of key_prefix_equals with the value of replace_key_prefix_with.
Restrictions:
None
Value range:
None
Default value:
None
replace_key_with
const char *
Yes
Explanation:
The object name prefix used in the redirection. OBS replaces the entire object name in the request with the value of replace_key_with.
Restrictions:
None
Value range:
None
Default value:
None
http_redirect_code
const char *
Yes
Explanation:
Indicates the HTTP status code returned for the redirection request.
Restrictions:
None
Value range:
None
Default value:
None
