Updated on 2026-11-17 GMT+08:00
obs_bucket_cors_conf
Table 1 obs_bucket_cors_conf
Type
Mandatory (Yes/No)
id
const char *
No
Explanation:
The ID of a CORS rule.
Restrictions:
None
Value range:
A string of 1 to 255 characters.
Default value:
None
allowed_method
const char **
Yes
Explanation:
The allowed HTTP methods (types of operations on buckets and objects) for a cross-origin request.
Restrictions:
None
Value range:
The following HTTP methods are supported:
  • GET
  • PUT
  • HEAD
  • POST
  • DELETE
Default value:
None
allowed_method_number
unsigned int
No
Explanation:
Number of the allowed_method elements.
Restrictions:
None
Value range:
None
Default value:
None
allowed_origin
const char **
No
Explanation:
The origin that is allowed to access the bucket.
Restrictions:
Only English domain names are supported. Regular expressions are used to match. Each rule allows at most one asterisk (*). For example, https://*.vbs.example.com.
Value range:
The value must comply with the CORS protocol and contain 0 to 20480 characters.
Default value:
None
allowed_origin_number
unsigned int
No
Explanation:
Number of the allowed_origin elements.
Restrictions:
None
Value range:
None
Default value:
None
allowed_header
const char **
No
Explanation:
The allowed headers for Access-Control-Request-Headers in a CORS configuration request. If a CORS request contains Access-Control-Request-Headers, this request is considered valid only when it matches the configuration of allowed_header. The matching is based on regular expressions.
Restrictions:
At most one asterisk (*) is allowed. Spaces, ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
Default value:
None
allowed_header_number
unsigned int
No
Explanation:
Number of the allowed_header elements.
Restrictions:
None
Value range:
None
Default value:
None
max_age_seconds
const char *
No
Explanation:
The duration the response can be cached on the client.
Restrictions:
Each CORS rule can contain at most one max_age_seconds.
Value range:
An integer greater than or equal to 0, in seconds.
Default value:
3000
expose_header
const char **
No
Explanation:
It specifies additional headers a CORS rule allows in a response, which can be used to provide extra information to clients. By default, a browser can access only headers Content-Length and Content-Type. If the browser needs to access other headers, you need to configure them as additional headers.
Restrictions:
Spaces, asterisks (*), ampersands (&), colons (:), less-than signs (<), and full-width characters are not allowed.
Value range:
The value that complies with the CORS
Default value:
None
expose_header_number
unsigned int
No
Explanation:
Number of the expose_header elements.
Restrictions:
None
Value range:
None
Default value:
None
