Updated on 2026-08-03 GMT+08:00
manager_acl_info
Table 1 manager_acl_info
Type
Mandatory (Yes/No)
object_info
obs_object_info *
Yes
Explanation:
Object name and version ID. If the object is not a versioned object, set version to NULL.
Restrictions:
None
Value range:
None
Default value:
None
owner_id
char *
Yes
Explanation:
Account (domain) ID of the bucket owner.
Restrictions:
None
Value range:
For details about how to obtain the account ID of the bucket owner, see How Do I Get My Account ID and User ID?
Default value:
None
owner_display_name
char *
Yes
Explanation:
Display name of a user
Restrictions:
None
Value range:
None
Default value:
None
acl_grant_count_return
int *
Yes
Explanation:
Length of the acl_grants array.
Restrictions:
None
Value range:
None
Default value:
None
object_delivered
obs_object_delivered
Yes
Explanation:
Whether the bucket ACL is applied to the objects in the bucket.
Restrictions:
None
Value range:
For details, see obs_object_delivered.
Default value:
BUCKET_DELIVERED_FALSE (The ACL of the bucket does not apply to its objects.)
acl_grants
obs_acl_grant *
Yes
Explanation:
Permission information structure.
Restrictions:
None
Value range:
None
Default value:
None
