obs_create_bucket_params
| Parameter | Type | Mandatory (Yes/No) | Description |
| canned_acl | Yes | Explanation: Access control policy. Restrictions: None Value range: None Default value: None | |
| az_redundancy | Yes | Explanation: Multi-AZ redundancy policy specified when a bucket is created. Restrictions: None Value range: Multiple AZs or a single AZ.
| location_constraint | const char * | Yes | Explanation: Region where the bucket is located. To create a 3-AZ bucket, you need to specify a region that supports 3-AZ storage. Restrictions: None Value range: None Default value: None |
