Request Parameters for Server-Side Encryption
| Parameter | Type | Mandatory (Yes/No) | Description |
| encryption_type | No | Explanation: Encryption type. Restrictions: None Value range: None Default value: None | |
| kms_server_side_encryption | char * | No | Explanation: Indicates that SSE-KMS is used for server-side encryption. Restrictions: None Value range:
| kms_key_id | char * | No | Explanation: Key ID. If the SSE-KMS encryption is used with a specified key, the key ID is required. Restrictions: This header can only be used when you specify kms for the kms_server_side_encryption header. Default value: If you specify kms for encryption but do not specify a key ID, the default master key will be used. If there is not a default master key, OBS will create one and use it. |
| ssec_customer_algorithm | char * | No | Explanation: Indicates the algorithm used to encrypt an object. Restrictions: The header is used only in SSE-C mode. Value range: AES256 (AES256 encryption algorithm) Default value: None |
| ssec_customer_key | char * | No | Explanation: Indicates the key used to encrypt an object. Restrictions: The header is used only in SSE-C mode. Value range: Base64-encoded 256-bit key Default value: None |
| des_ssec_customer_algorithm | char * | No | Explanation: Indicates the algorithm used to decrypt a source object. Restrictions: The header is used only in SSE-C mode. Value range: None Default value: None |
| des_ssec_customer_key | char * | No | Explanation: Indicates the key used to decrypt the source object. Restrictions: The header is used only in SSE-C mode. Value range: None Default value: None |
