Request parameters for setting event notifications
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | The context of the bucket request. For details, see Configuring option (SDK for C). | Yes | Bucket parameters |
| notification_conf | obs_smn_notification_configuration* | Yes | Indicates the container for configuring the event notification. |
| handler | obs_response_handler * | Yes | Callback function |
| callback_data | void * | No | Callback data |
The following table describes the parameter obs_smn_notification_configuration.
| Parameter | Type | Description |
| topic_conf | obs_smn_topic_configuration* | Container for configuring the event notification topic |
| topic_conf_num | unsigned int | Number of topic_conf |
The following table describes the parameter obs_smn_topic_configuration.
| topic | char * | URN of the event notification topic. After detecting a specific event, OBS sends a message to the topic. |
| id | char * | Unique ID of each event notification. If no ID is specified, the system automatically assigns one. |
| filter_rule | obs_smn_filter_rule * | Container for storing key-value pairs of filtering rules |
| filter_rule_num | unsigned int | Number of filter_rule |
| event | obs_smn_event_enum* | Type of events that requiring notification |
| event_num | unsigned int | Number of event types |
