Request Parameters for Deleting Bucket Tags
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | const obs_options * | Yes | The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options. |
| handler | Yes | A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data. | |
| callback_data | void * | Yes | Custom callback data. |
