Help Center/ Object Storage Service/ SDK Reference/ C/ Parameters/ Request Parameters for Configuring CORS for a Bucket
Updated on 2026-08-03 GMT+08:00
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options *
Yes
The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options.
obs_cors_conf_info
obs_bucket_cors_conf *
Yes
CORS rule content.
conf_num
unsigned int
Yes
Number of array members in the array obs_cors_conf_info.
handler
obs_response_handler *
Yes
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data.
callback_data
void *
No
Custom callback data.
