Help Center/ Object Storage Service/ SDK Reference/ C/ Parameters/ Request Parameters for Setting Object Properties
Updated on 2026-08-03 GMT+08:00
Table 1 List of request parameters
Type
Mandatory (Yes/No)
options
const obs_options *
Yes
The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options.
object_info
obs_object_info *
Yes
Object name and version ID. For non-multi-version objects, set version to 0.
put_properties
obs_put_properties*
Yes
Properties of the uploaded object
encryption_params
server_side_encryption_params *
No
Parameters related to server-side encryption
handler
obs_response_handler *
Yes
A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data.
callback_data
void *
No
Custom callback data.
