Request parameters for creating a parallel file system
| Parameter | Type | Mandatory (Yes/No) | Description |
| options | const obs_options * | Yes | The context of the requested bucket. Refer to Configuring option (SDK for C) to set the AK, SK, endpoint, bucket, timeout, and temporary credentials through obs_options. |
| canned_acl | Yes | Access control policy | |
| location_constraint | char * | No | Bucket location |
| handler | Yes | A callback structure where all members are pointers to callback functions, used to set the callback functions that handle response data. You can set a callback function to copy the response data from the server to your custom callback_data. | |
| callback_data | void * | No | Custom callback data. |
| param | obs_create_bucket_params * | Yes | This field is used only in the create_bucket_with_params interface. The request body contains:
