Listing Object Versions
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.listVersions to list object versions.
The following table describes the parameters involved in this API.
| Parameter | Description |
| Prefix | Name prefix that the objects to be listed must contain |
| KeyMarker | Object name to start with when listing object versions in a bucket. All object versions whose names follow this parameter are listed in the lexicographical order. |
| MaxKeys | Maximum number of listed object versions. The value ranges from 1 to 1000. If the specified value exceeds 1000, only 1,000 object versions are returned. |
| Delimiter | Character used to group object names. If the object name contains the Delimiter parameter, the character string from the first character to the first delimiter in the object name is grouped under a single result element, CommonPrefix. (If a prefix is specified in the request, the prefix must be removed from the object name.) |
| VersionIdMarker | Object name to start with when listing object versions in a bucket. All object versions are listed in the lexicographical order by object name and version ID. This parameter must be used together with KeyMarker. |
- If the value of VersionIdMarker is not a version ID specified by KeyMarker, VersionIdMarker is ineffective.
- The returned result of ObsClient.listVersions includes the object versions and delete markers.
Listing Object Versions in Simple Mode
The following sample code shows how to list object versions in simple mode. A maximum of 1,000 object versions can be returned.
// Create an instance of ObsClient.
var obsClient = new ObsClient({
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK before storing them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables. Before running the code in this example, configure environment variables AccessKeyID and SecretAccessKey.
// The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
access_key_id: process.env.AccessKeyID,
secret_access_key: process.env.SecretAccessKey,
// Replace the example endpoint with the actual one in your case.
server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
obsClient.listVersions({
Bucket : 'bucketname'
}, function (err, result) {
if(err){
console.log('Error-->' + err);
}else{
console.log('Status-->' + result.CommonMsg.Status);
if(result.CommonMsg.Status < 300 && result.InterfaceResult){
// Obtain object versions.
for(var j in result.InterfaceResult.Versions){
console.log('Version[' + j + ']:');
console.log('Key-->' + result.InterfaceResult.Versions[j]['Key']);
console.log('VersionId-->' + result.InterfaceResult.Versions[j]['VersionId']);
console.log('Owner[ID]-->' + result.InterfaceResult.Versions[j]['Owner']['ID']);
// Obtain delete markers.
for(var i in result.InterfaceResult.DeleteMarkers){
console.log('DeleteMarker[' + i + ']:');
console.log('Key-->' + result.InterfaceResult.DeleteMarkers[i]['Key']);
console.log('VersionId-->' + result.InterfaceResult.DeleteMarkers[i]['VersionId']);
console.log('Owner[ID]-->' + result.InterfaceResult.DeleteMarkers[i]['Owner']['ID']);
- A maximum of 1,000 object versions can be listed each time. If a bucket contains more than 1,000 object versions, InterfaceResult.IsTruncated in the response is true, indicating not all object versions were listed. In such case, you can use InterfaceResult.NextKeyMarker and InterfaceResult.NextVersionIdMarker to obtain the start position for the next listing.
- If you want to obtain all object versions in a specified bucket, you can use the paging mode for listing objects.
Listing Object Versions by Specifying the Number
Sample code:
Bucket : 'bucketname',
MaxKeys : 100
if(err){
}else{
}); Listing Object Versions by Specifying a Prefix
Sample code:
// Set the prefix to prefix and the number to 100.
MaxKeys : 100,
Prefix : 'prefix'
if(err){
}else{
}); Listing Object Versions by Specifying the Start Position
Sample code:
// List 100 object versions whose names are following test in the lexicographical order.
MaxKeys : 100,
KeyMarker : 'test'
if(err){
}else{
}); Listing All Object Versions in Paging Mode
Sample code:
var listAll = function (keyMarker, versionIdMarker) {
MaxKeys : 100,
KeyMarker : keyMarker,
VersionIdMarker : versionIdMarker
if(err){
}else{
if(result.InterfaceResult.IsTruncated === 'true'){
listAll(result.InterfaceResult.NextKeyMarker, result.InterfaceResult.NextVersionIdMarker);
listAll(); Listing All Object Versions in a Folder
There is no folder concept in OBS. All elements in buckets are objects. Folders are actually objects whose sizes are 0 and whose names end with a slash (/). When you set a folder name as the prefix, objects in this folder will be listed. Sample code is as follows:
MaxKeys : 100,
VersionIdMarker : versionIdMarker,
// Set the prefix of the folders to dir/.
Prefix : 'dir/'
if(err){
}else{
listAll(); Listing All Object Versions According to Folders in a Bucket
Sample code:
// Set folder isolators to slashes (/).
Delimiter : '/'
if(err){
}else{
console.log('Objects in the root directory:');
console.log('VersionId-->'+ result.InterfaceResult.DeleteMarkers[i]['VersionId']);
var listVersionsByPrefix = function (commonPrefixes) {
for(var n in commonPrefixes){
Delimiter : '/',
Prefix: commonPrefixes[n]['Prefix']
console.log('Objects in folder:');
console.log('\n');
if(result.InterfaceResult.CommonPrefixes && result.InterfaceResult.CommonPrefixes.length > 0){
listVersionsByPrefix(result.InterfaceResult.CommonPrefixes);
- The previous sample code does not include scenarios where the number of object versions in a folder exceeds 1,000.
- Because objects and sub-folders in a folder are to be listed and all the objects end with a slash (/), Delimiter is always a slash (/).
- In the returned result of each recursion, InterfaceResult.Versions includes the object versions in the folder, InterfaceResult.DeleteMarkers includes the delete markers in the folder, and InterfaceResult.CommonPrefixes includes the sub-folders in the folder.
