Huawei Cloud Astro Canvas
Huawei Cloud Astro Zero
CodeArts Governance
Cloud Container Instance (CCI)
Cloud Transformation
Well-Architected Framework
Cloud Adoption Framework
On this page
Show all
Obtaining Object Properties
Updated on 2024-12-03 GMT+08:00
NOTICE:
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
You can call ObsClient.getObjectMetadata to obtain properties of an object, including the length, MIME type, and customized metadata.
This example obtains the metadata of objectname in bucketname.
The example code is as follows:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
    // Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
    // The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
    // Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
    access_key_id: process.env.AccessKeyID,
    secret_access_key: process.env.SecretAccessKey,
    // Replace the example endpoint with the actual one in your case.
    server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
obsClient.getObjectMetadata({
       Bucket : 'bucketname',
       Key : 'objectname'
}, function (err, result){
       if(err){
          console.error('Error-->' + err);
       }else{
          console.log('Status-->' + result.CommonMsg.Status);
          if(result.CommonMsg.Status < 300 && result.InterfaceResult){
              console.log(result.InterfaceResult.ContentType);
              console.log(result.InterfaceResult.ContentLength);
              console.log(result.InterfaceResult.Metadata['property']);
  • To obtain the customized metadata of an object, you need to add the additional headers that are allowed to be carried in responses to the CORS configurations. For example, you can add x-obs-meta-property to enable the query of property.
