Help Center/
Object Storage Service/
SDK Reference/
BrowserJS/
Object Download/
Performing a Binary Download
Updated on 2024-04-26 GMT+08:00
If you have any questions during development, post them on the Issues page of GitHub. For details about parameters and usage of each API, see the API Reference.
Sample code:
// Create an instance of ObsClient.
var obsClient = new ObsClient({
// Hard-coded or plaintext AK/SK are risky. For security purposes, encrypt your AK/SK and store them in the configuration file or environment variables. In this example, the AK/SK are stored in environment variables for identity authentication. Before running this example, configure environment variables AccessKeyID and SecretAccessKey.
// The front-end code does not have the process environment variable, so you need to use a module bundler like webpack to define the process variable.
// Obtain an AK/SK pair on the management console. For details, see https://support.huaweicloud.com/intl/en-us/usermanual-ca/ca_01_0003.html.
access_key_id: process.env.AccessKeyID,
secret_access_key: process.env.SecretAccessKey,
// Replace the example endpoint with the actual one in your case.
server: 'https://obs.ap-southeast-1.myhuaweicloud.com'
obsClient.getObject({
Bucket : 'bucketname',
Key : 'objectname',
SaveByType : 'arraybuffer'
}, function (err, result) {
if(err){
console.error('Error-->' + err);
}else{
console.log('Status-->' + result.CommonMsg.Status);
if(result.CommonMsg.Status < 300 && result.InterfaceResult){
// Obtain the object length.
console.log('Object Length:\n');
console.log(result.InterfaceResult.Content.byteLength);
- Set the SaveByType parameter to arraybuffer to use binary download.
- In the returned result of a binary download, InterfaceResult.Content is an instance of ArrayBuffer.
Parent topic: Object Download
