Configuring Direct Reading for a Bucket
Function
This API is used to configure direct reading for a bucket.
Restrictions
- To configure direct reading for a bucket, you must be the bucket owner or have the required permission (obs:bucket:PutDirectColdAccessConfiguration granted using IAM or PutDirectColdAccessConfiguration granted using a bucket policy). For details, see Introduction to OBS Access Control, IAM Custom Policies, and Creating a Custom Bucket Policy.
- The mapping between OBS regions and endpoints must comply with what is listed in Regions and Endpoints.
Method
ObsClient.setBucketDirectColdAccess(params)
Request Parameters
| Parameter | Type | Mandatory (Yes/No) | Description |
| Bucket | String | Yes | Explanation: Bucket name Restrictions:
Default value: None |
| Status | String | No | Explanation: Direct reading status of a bucket Value range:
Responses
| Parameter | Type | Description |
| Status | number | Explanation: HTTP status code returned by the OBS server Value range: A status code is a group of digits indicating the status of a response. It ranges from 2xx (indicating successes) to 4xx or 5xx (indicating errors). For details, see Status Codes. |
| Code | string | Explanation: Error code returned by the OBS server |
| Message | string | Explanation: Error description returned by the OBS server |
| HostId | string | Explanation: Request server ID returned by the OBS server |
| RequestId | string | Explanation: Request ID returned by the OBS server |
| Id2 | string | Explanation: Request ID2 returned by the OBS server |
| Indicator | string | Explanation: Error code details returned by the OBS server |
