Updated on 2026-09-20 GMT+08:00
Truncating an Object
Function
This API truncates an object in the PFS.
Restrictions
Method
obsClient.truncateObject(TruncateObjectRequest request)
Request Parameters
Table 1 List of request parameters
Type
Mandatory (Yes/No)
request
Yes
Explanation:
Request parameters for truncating an object. For details, see Table 2.
Table 2 TruncateObjectRequest
Type
Mandatory (Yes/No)
bucketName
String
Yes
Explanation:
Bucket name.
Restrictions:
  • A bucket name must be unique across all accounts and regions.
  • A bucket name:
    • Must be 3 to 63 characters long and start with a digit or letter. Lowercase letters, digits, hyphens (-), and periods (.) are allowed.
    • Cannot be formatted as an IP address.
    • Cannot start or end with a hyphen (-) or period (.).
    • Cannot contain two consecutive periods (..), for example, my..bucket.
    • Cannot contain a period (.) and a hyphen (-) adjacent to each other, for example, my-.bucket or my.-bucket.
  • If you repeatedly create buckets of the same name in the same region, no error will be reported and the bucket attributes comply with those set in the first creation request.
Default value:
None
objectKey
String
Yes
Explanation:
Name of a file object. An object is uniquely identified by an object name in a bucket. An object name is a complete path that does not contain the bucket name.
For example, if the address for accessing the object is examplebucket.obs.ap-southeast-1.myhuaweicloud.com/folder/test.txt, the object name is folder/test.txt.
Value range:
The value must contain 1 to 1,024 characters.
Default value:
None
newLength
long
Yes
Explanation:
Size of the file after being truncated.
Default value:
None
Responses
Table 3 TruncateObjectResult
Type
statusCode
int
Explanation:
HTTP status code.
Value range:
A status code is a group of digits that can be 2xx (indicating successes) or 4xx or 5xx (indicating errors). It indicates the status of a response.
For more information, see Status Code.
Default value:
None
responseHeaders
Map<String, Object>
Explanation:
Response header list, composed of tuples. In a tuple, the String key indicates the name of the header, and the Object value indicates the value of the header.
Default value:
None
Sample Code
This example truncates object objectname in parallel file system examplebucket to 1024L.
import android.util.Log;
import com.obs.services.ObsClient;
import com.obs.services.exception.ObsException;
import com.obs.services.model.TruncateObjectRequest;
import com.obs.services.model.TruncateObjectResult;
public class TruncateObjectDemo {
    private static final String TAG = "TruncateObjectDemo";
    public void truncateObject() {
       // Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables. In this example, the AK and SK are stored in environment variables for identity authentication. Before running the code in this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
        // Obtain an AK/SK pair on the management console.
        // Enter the endpoint corresponding to the bucket. CN North-Beijing4 is used here as an example. Replace it with the one currently in use.
        String endPoint = "https://your-endpoint";
        // Create an ObsClient instance.
        ObsClient obsClient = new ObsClient(ak, sk, endPoint);
        try {
            // Truncate an object.
            TruncateObjectRequest request = new TruncateObjectRequest();
            request.setBucketName("examplebucket");
            request.setObjectKey("objectname");
            request.setNewLength(1024L);
            TruncateObjectResult result = obsClient.truncateObject(request);
            Log.i(TAG, "truncateObject successfully");
            Log.i(TAG, "HTTP Code: " + result.getStatusCode());
        } catch (ObsException e) {
            Log.e(TAG, "truncateObject failed");
            // Request failed. Print the HTTP status code.
            Log.e(TAG, "HTTP Code:" + e.getResponseCode());
            // Request failed. Print the server-side error code.
            Log.e(TAG, "Error Code:" + e.getErrorCode());
            // Request failed. Print the error details.
            Log.e(TAG, "Error Message:" + e.getErrorMessage());
            // Request failed. Print the request ID.
            Log.e(TAG, "Request ID:" + e.getErrorRequestId());
            Log.e(TAG, "Host ID:" + e.getErrorHostId());
        } catch (Exception e) {
            // Print other error information.
            Log.e(TAG, e.getMessage());
