Help Center/ Object Storage Service/ SDK Reference/ Android/ FAQ/ How Do I Perform Batch Operations Using the SDK?
Updated on 2026-09-20 GMT+08:00
Currently, the SDK does not provide such APIs. You need to encapsulate the service codes for uploading, downloading, copying, or restoring objects in a batch by yourself. The procedure is as follows:
  1. Call listObjects to list all objects to be downloaded, copied, or restored. For details about the sample code, see Listing Objects. For batch upload, you need to traverse the local files to be uploaded.
  2. Call the API for uploading, downloading, copying, or restoring a single object for the listed objects.
You can use multiple threads to concurrently upload, download, copy, or restore objects to improve efficiency.
Sample Code 1: Uploading Objects in Batches
The following code shows how to upload objects in batches.
// Hard-coded or plaintext AK and SK are risky. For security purposes, encrypt your AK and SK and store them in the configuration file or environment variables.
// In this example, the AK and SK are stored in environment variables. Before running this example, configure environment variables ACCESS_KEY_ID and SECRET_ACCESS_KEY_ID.
// Obtain an AK/SK pair on the management console.
String endPoint = "https://your-endpoint";
// Create an ObsClient instance.
ObsClient obsClient = new ObsClient(ak, sk, endPoint);
try {
    String bucketName = "examplebucket";
    // Define the prefix of objects in a bucket.
    String objectPre = "object/";
    // Folder to be uploaded
    String localDirPath = Environment.getExternalStorageDirectory().getAbsolutePath() + "/localDirPath";
    // Traverse the local folder and upload files one by one.
    File localDir = new File(localDirPath);
    if (localDir != null && localDir.isDirectory()) {
        File[] files = localDir.listFiles();
        if (files != null) {
            int succeedCount = 0;
            int failCount = 0;
            for (File file : files) {
                if (file.isFile()) {
                    try {
                        String objectKey = objectPre + file.getName();
                        PutObjectResult result = obsClient.putObject(bucketName, objectKey, file);
                        Log.i("BatchUpload", "Upload succeeded: " + objectKey);
                        succeedCount++;
                    } catch (ObsException e) {
                        Log.e("BatchUpload", "Upload failed: " + file.getName()
                                + ", Error Code: " + e.getErrorCode()
                                + ", Error Message: " + e.getErrorMessage());
                        failCount++;
            Log.i("BatchUpload", "Batch upload completed. Succeed: " + succeedCount + ", Failed: " + failCount);
    Log.e("BatchUpload", "Response Code: " + e.getResponseCode());
    Log.e("BatchUpload", "Error Message: " + e.getErrorMessage());
    Log.e("BatchUpload", "Error Code:    " + e.getErrorCode());
    Log.e("BatchUpload", "Request ID:    " + e.getErrorRequestId());
    Log.e("BatchUpload", "Host ID:       " + e.getErrorHostId());
} catch (Exception e) {
    Log.e("BatchUpload", "batch upload failed: " + e.getMessage());
  • Network operations must be performed in child threads. Do not call the preceding code in the main thread (UI thread). Otherwise, the NetworkOnMainThreadException exception will be thrown.
  • If there are a large number of local files or the files are large, you are advised to use multiple threads to upload files concurrently to improve efficiency.
  • To upload files in subfolders, you need to recursively traverse the directory structure.
  • If the size of the file to be uploaded is large, you can use the resumable upload API (uploadFile) to replace the object upload API (putObject).
Sample Code 2: Downloading Objects in Batches
The following code shows how to download objects in batches.
final ObsClient obsClient = new ObsClient(ak, sk, endPoint);
try {
    // Local download directory
    String localDownloadDir = Environment.getExternalStorageDirectory().getAbsolutePath() + "/download";
    // 1. List all objects with a specified prefix in the bucket.
    ListObjectsRequest listRequest = new ListObjectsRequest(bucketName);
    listRequest.setPrefix(objectPre);
    ObjectListing result = obsClient.listObjects(listRequest);
    // 2. Download objects one by one.
    for (ObsObject obsObject : result.getObjects()) {
        String objectKey = obsObject.getObjectKey();
        // Skip folders (objects whose names end with a slash (/)).
        if (objectKey.endsWith("/")) {
            continue;
        // Generate local file paths.
        String localFilePath = localDownloadDir + "/" + objectKey.substring(objectPre.length());
        DownloadFileRequest downloadRequest = new DownloadFileRequest(bucketName, objectKey);
        downloadRequest.setDownloadFile(localFilePath);
        obsClient.downloadFile(downloadRequest);
        Log.i("BatchDownload", "Downloaded: " + objectKey);
    Log.i("BatchDownload", "Batch download completed");
    Log.e("BatchDownload", "Response Code: " + e.getResponseCode());
    Log.e("BatchDownload", "Error Message: " + e.getErrorMessage());
    Log.e("BatchDownload", "Error Code:    " + e.getErrorCode());
    Log.e("BatchDownload", "Request ID:    " + e.getErrorRequestId());
    Log.e("BatchDownload", "Host ID:       " + e.getErrorHostId());
    Log.e("BatchDownload", "Batch download failed: " + e.getMessage());
  • You can use multiple threads to concurrently download objects to improve efficiency.
  • If there are a large number of objects in the bucket, you need to list all objects in pagination mode. For details, see Listing Objects.
Sample Code 3: Copying Objects in Batches
The following code shows how to copy objects in batches.
try {
    String sourceBucketName = "examplebucket";
    String destBucketName = "destbucket";
    // 1. List all objects with a specified prefix in the source bucket.
    ListObjectsRequest listRequest = new ListObjectsRequest(sourceBucketName);
    // 2. Copy objects one by one.
        // Skip folders.
            continue;
        CopyObjectRequest copyRequest = new CopyObjectRequest(sourceBucketName, objectKey, destBucketName, objectKey);
        obsClient.copyObject(copyRequest);
        Log.i("BatchCopy", "Copied: " + objectKey);
    Log.i("BatchCopy", "Batch copy completed");
    Log.e("BatchCopy", "Response Code: " + e.getResponseCode());
    Log.e("BatchCopy", "Error Message: " + e.getErrorMessage());
    Log.e("BatchCopy", "Error Code:    " + e.getErrorCode());
    Log.e("BatchCopy", "Request ID:    " + e.getErrorRequestId());
    Log.e("BatchCopy", "Host ID:       " + e.getErrorHostId());
    Log.e("BatchCopy", "Batch copy failed: " + e.getMessage());
Sample Code 4: Restoring Objects in Batches
The following code shows how to restore objects with a specified prefix in batches.
try {
    ObjectListing listing = obsClient.listObjects(listRequest);
    // 2. Restore Archive or Deep Archive objects one by one.
    int failCount = 0;
    for (ObsObject obsObject : listing.getObjects()) {
            continue;
        try {
            RestoreObjectRequest request = new RestoreObjectRequest();
            request.setBucketName(bucketName);
            request.setObjectKey(objectKey);
            // Set the retention period of the restored objects.
            request.setRestoreDays(7);
            // Set the restoration speed to the standard mode.
            request.setTier(RestoreTierEnum.STANDARD);
            obsClient.restoreObject(request);
            Log.i("BatchRestore", "Restore succeeded: " + objectKey);
            succeedCount++;
            Log.e("BatchRestore", "Restore failed: " + objectKey
            failCount++;
    Log.i("BatchRestore", "Batch restore completed. Succeed: " + succeedCount + ", Failed: " + failCount);
    Log.e("BatchRestore", "Response Code: " + e.getResponseCode());
    Log.e("BatchRestore", "Error Message: " + e.getErrorMessage());
    Log.e("BatchRestore", "Error Code:    " + e.getErrorCode());
    Log.e("BatchRestore", "Request ID:    " + e.getErrorRequestId());
    Log.e("BatchRestore", "Host ID:       " + e.getErrorHostId());
    Log.e("BatchRestore", "batch restore failed: " + e.getMessage());
The following code shows how to restore objects in batches by object name list.
try {
    // List of objects to be restored
    String[] objectKeys = {"objectname1", "objectname2", "objectname3"};
    int failCount = 0;
    for (String objectKey : objectKeys) {
        try {
            request.setRestoreDays(1);
            // Set the restoration speed to the expedited mode.
            request.setTier(RestoreTierEnum.EXPEDITED);
            succeedCount++;
            failCount++;
